POV-Ray : Newsgroups : povray.off-topic : An unusual prime number algorithm Server Time
20 Oct 2026 03:19:55 EDT (-0400)
  An unusual prime number algorithm (Message 1 to 8 of 8)
Subject: An unusual prime number algorithm
Date: 2 Dec 2007 07:10:45
Message: <4752a0c5@news.povray.org>
I posted this in one of the Haskell groups a few days ago - but it's
actually not to do with Haskell particularly, so...
I've stumbled on a slightly unusual way to find prime numbers. It goes
like this. Suppose you're sitting here seiving prime numbers. We start
by deleting 2 and all its multiples. That leaves us with a pattern like
this:
Ignoring 1, the next place that has a dash is 3, so 3 is the next prime
number. Deleting 3 and all its multiples, we get
In other words, an infinite list of twin "primes". Well anyway, the next
uncrossed number is 5, so 5 is prime. Deletin 5 and all its multiplies
yields
And so forth. At each stage, we get a longer repeating pattern. If you
take each of these lines and snip it down to just 1 repartition, you get
Initial: (-)
After 2: (-#)
After 3: (-###-#)
After 5: (-#####-###-#-###-#-###-#####-#)
The first pattern is 1 units long, the next is 2*1 = 2 units long, the
next is 3*2 = 6 units long, and the last one is 5*6 = 30 units long. The
"after 7" pattern is 7*30 = 210 units long, so I won't bother writing it
out here. ;-)
You can use all this to write an algorithm for finding primes. Basically
start with some pattern, find the next prime P (first uncrossed square
ignoring 1), repeat the pattern P times, seive out all multiplies of P,
go back to step 1. (In practice, you have to start from the "after 3"
pattern for this to work properly.)
Initial:  -###-#
Find   P: 5
Repeat P: -###-#-###-#-###-#-###-#-###-#
Seive  P: -#####-###-#-###-#-###-#####-#
Find   P: 7
etc.
Actually, every dash in the grid (up to sqrt(grid size) is a prime
number). So after less than a dozen iterations of this (very simple)
algorithm, you can find all primes below 1,000,000. (!)
(Notice that the "normal" seiving algorithm keeps 5 and deletes only
higher multiples of it. My algorithm deletes 5 itself as well. It must
for the algorithm to work right...)
Subject: Re: An unusual prime number algorithm
Date: 2 Dec 2007 12:23:30
Message: <4752ea12@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
  That last pattern is wrong. The first incorrectly (non-)marked place
is at 25. It also marks 41 as non-prime even though it is.
  Anyways, using the correct patterns, wuldn't it be better to preserve
the info about which of those are the primes?
  If we mark untested numbers with '-', primes with '!' and non-primes
with '#' then that would become:
etc.
  In the end you end up with:
  OTOH using this algorithm you basically need to fix the number of
primes you want to calculate. It also requires random access so it's
not very usable with linked lists.
Date: 2 Dec 2007 14:09:39
Message: <475302f3$1@news.povray.org>
Right. Well I typed these out by hand, so if there are errors then it's
because my typing is inaccurate. :-S
> etc.
Well, then you'd need more bits per number. (I'm using a simple bitmap
at the moment.) Still, it could work...
Yeah, pretty much.
For finding "really big" prime numbers, it seems that space rather than
time is going to be the issue. The algorithm more or less forces you to
go up in predetermined step sizes. I would think you'll run out of RAM
fairly quickly.
It's not entirely clear to me that this algorithm is any faster or
otherwise "better" than the normal seiving algorithm. (As in, if you
want all primes below N, find all primes below sqrt(N) and then sieve a
larger list from 1 to N. And possibly find the smaller primes list by
the same method recursively.)
It's certainly an "unusual" algorithm though. At least, I've not seen it
before...
Date: 2 Dec 2007 18:27:10
Message: <47533f4e@news.povray.org>
  Not really, because the end result only has '#' and '!'. You simply
have to keep an index to the next untested value in a variable.
Date: 2 Dec 2007 19:43:51
Message: <47535147$1@news.povray.org>
> this:
> yields
> Initial: (-)
> After 2: (-#)
> After 3: (-###-#)
> out here. ;-)
> Initial:  -###-#
> Find   P: 5
> Find   P: 7
> etc.
The pattern that you have to keep and process for each prime grows
factorially.  Doesn't look too big for small n but it certainly takes
off quickly.
So by the time that you are able to deliver say the 1000th prime number,
the pattern would be *rather* large.  And you need to keep maintaining
the growing pattern to continue delivering the 1001st, 1002nd etc.
If you choose to stop accumulating the pattern at some point then you
are back to classic Sieve of Eratosthenes with a slightly different way
to build up the array to its desired size.
I know you were just offering an insight not thinking it was actually
practical.
How about we call this Orchid's Algorithm - because it is 'bloomin
ridiculous' :)
Date: 3 Dec 2007 04:43:11
Message: <4753cfaf$1@news.povray.org>
...and *this* is why Warp is a high-end games programmer and I'm not.
Heh. ._.
Date: 3 Dec 2007 04:44:08
Message: <4753cfe8$1@news.povray.org>
> ridiculous' :)
Ooo... I *like* that! :-D
Date: 3 Dec 2007 06:14:11
Message: <4753E504.8090708@hotmail.com>
but take care that when concatenating the strings you set all fields
below that number to # first.
