POV-Ray : Newsgroups : povray.off-topic : Auto-skipping in WinXP? Server Time
20 Oct 2026 03:19:56 EDT (-0400)
  Auto-skipping in WinXP? (Message 1 to 37 of 37)
Subject: Auto-skipping in WinXP?
Date: 1 Dec 2007 23:14:02
Message: <4752310a@news.povray.org>
I've got a few thousand files I'm copying from a data CD to a WinXP box.
Duplicate copies of 90% of them already exist on the WinXP box.
When I had the same scenario on my linux boxes, Konqueror quite
intelligently gave me an "Autoskip" option.
I really don't want to blithely copy everything again--to rewrite existing
files, in case there's a chance the CD version isn't as good, and other
reasons.
How can I autoskip in Windoze?
Subject: Re: Auto-skipping in WinXP?
Date: 1 Dec 2007 23:22:09
Message: <475232f1$1@news.povray.org>
When it asks the first time if you want to clobber files with the same
name, and offers "Yes", "No", and "Yes to all", hold down the shift key
and click "No".  I think it's the shift key.
Saw that on the intraweb somewhere, and it works. Not documented, but
works. :-)
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 2 Dec 2007 03:45:10
Message: <47527096@news.povray.org>
Correct. And it's a legitimate reason to berate MS. One would have thunk an
OS would provide the very basic file management functions and options
transparently. Similarly, the fact that up until Vista, a locked/missing
file will abort the whole copy operation is also inexcusable.
Date: 2 Dec 2007 04:53:56
Message: <475280B4.6080900@hotmail.com>
> reasons.
Total Commander (http://www.ghisler.com/) is just a bit more
intelligent. It'll ask you for instance if you want to overwrite files
with earlier date stamps only.
If you want to stick to windows the shift-NO is indeed an option.
Date: 2 Dec 2007 04:56:58
Message: <4752816B.9070500@hotmail.com>
Wow, they fixed that? How do they handle out of space nowadays? Do you
finally get time to clean up and continue?
Date: 2 Dec 2007 12:03:01
Message: <4752e545@news.povray.org>
  I thought Windows was supposed to be user-friendly?
  In Linux obscure key combinations are usually at least *documented*
somewhere.
Date: 2 Dec 2007 13:17:30
Message: <4752f6ba$1@news.povray.org>
> somewhere.
QOTD.
Laugh alone and the world thinks you're an idiot.
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 2 Dec 2007 14:22:45
Message: <47530605$1@news.povray.org>
> existing files, in case there's a chance the CD version isn't as good,
> and other reasons.
Maybe use rsync instead?  There are versions of rsync for Windows...
Jim
Date: 2 Dec 2007 14:30:40
Message: <475307e0$1@news.povray.org>
> somewhere.
I wouldn't even say "usually", but "always" - in the end, you can always
derive that knowledge from the source (who says source code isn't
documentation? ;-) )
If we had access to the Windows source, we could then call that
functionality "documented" as well.
Jim
Date: 2 Dec 2007 14:54:42
Message: <47530d82$1@news.povray.org>
Rsync rocks. I used it from cygwin.
Date: 2 Dec 2007 15:07:47
Message: <47531093$1@news.povray.org>
More so than Linux IME.  Example: Add a URL-based installation source
via YaST.  How long does it take you to figure out the copy/paste added
a space on the end of the URL, and YaST is too stupid to strip trailing
spaces from the URL?
How long does it take, for that matter, to figure out how to copy and/or
paste for each particular program. :-)
> somewhere.
It might be documented somewhere. I just saw the documentation in
Google, same place I get Linux documentation. ;-)
Date: 2 Dec 2007 15:29:38
Message: <475315b2$1@news.povray.org>
> somewhere.
MS seems to think that the appropriate place to handle files is from
within the applications that create them.  The ability to grab your data
at the file level appears to be something that MS doesn't want the
common user to be able to to at will.  Take, for instance, the way they
make it easy to put streaming video into a page, without giving you an
easy way to save that video to where you can find it whenever you want
it, so that you don't have to download it every time you want to view it.
The reason you have just the three choices is, I suspect, because the
MessageBoxEx() API call allows for only up to three buttons, and the
programmerswho wrote Windows Explorer were too lazy to whip up a dialog
box with the necessary number of buttons.
John
Date: 2 Dec 2007 15:37:51
Message: <4753179f$1@news.povray.org>
When I have to use Windows, I always make sure cygwin is installed.  It
might have a fair bit of overhead, but it's nice to have an environment
that is familiar to work in - too many times I type "ls" in a command box
because I spent all my time using Linux...
Jim
Date: 2 Dec 2007 16:06:15
Message: <47531e47$1@news.povray.org>
*Apart* from cygwin, I have gnuwin32 tools on my PATH, so I actually
type ls on the Windows command prompt and it works. Then when I'm
removing malware from friends' computers over VNC (I do that often,
sigh), I do the following:
C:\Windows> ls
"ls" command not found
C:\Windows> ARGH
"ARGH" command not found
C:\Windows> dir
[actual directory contents]
Date: 2 Dec 2007 17:44:44
Message: <4753355c$1@news.povray.org>
In X, highlight to copy and middle mouse to paste. Works across almost
all programs. On a bare terminal, write it down on paper and save
yourself the trouble.
Date: 2 Dec 2007 18:20:36
Message: <47533dc4@news.povray.org>
  YaST is not Linux. You can't blame Linux for the problems of some
third-party software you are running in it.
  In the Windows case in question it was a core feature of Windows.
  And besides, if you don't like how YaST works, take the source and make
it better. Attempt to do that with Windows core features...
  I always copypaste in the same way everywhere. I don't remember a
program where it wouldn't work.
  (Sure, it's not immediately obvious how it's done, I admit that...)
Date: 2 Dec 2007 18:21:40
Message: <47533e04@news.povray.org>
  Actually in a bare terminal you can run software which allows copy-pasting
of text on the terminal (using cursor key combinations, etc). Not the
handiest possible way, but perfectly possible.
Date: 2 Dec 2007 18:23:28
Message: <47533e70@news.povray.org>
John VanSickle <evi### [at] hotmailcom> wrote:
> and the
  I perfectly understand that, knowing how extraordinaly difficult it is
to write even the simplest of dialogs using the Windows API...
Date: 2 Dec 2007 19:29:32
Message: <47534dec$1@news.povray.org>
Especially when you have a huge overhead of (say) translating it to 100
languages, formal QA, etc etc etc that you have to pay for. Bad decision
anyway. :-)
Date: 2 Dec 2007 19:41:43
Message: <475350c7@news.povray.org>
Ah, now I hadn't even considered using the gnuwin32 tools (just because I
so rarely use Windows anymore - in VMware when I need it, natively on one
machine if I want to extract video from my DVR (because there's no
current Linux analogue that I've found) and that machine runs Linux
natively 99% of the time, and my kid's machine because he likes using the
latest Windows games.
Was a time when I had a machine that ran Windows natively pretty
constantly, but it's been several years since that machine was Windows-
only. :-)
But I'll definitely check out the gnuwin32 tools for my VM - that'll be
very handy. :-)
Jim
Date: 2 Dec 2007 19:43:53
Message: <47535149$1@news.povray.org>
Sure I can. :-)   Especially since it's the installer for the version of
Linux I use. Yes, yes, I've heard all the arguments, many times, thanks.
My point is that this is symptomatic. I'm not saying "YaST sucks."  I'm
saying that huge bunches of Linux stuff is not user friendly in a
variety of ways that anyone being *paid* to do the stuff would have
fixed long before releasing it. Since I work with both professional and
amateur operating systems, I find myself constantly stumbling over the
little things that annoy me.  "Abort" buttons are also high on the list,
along with incomprehensible or useless error messages, along with things
reacting to the user very poorly when the machine is under load, to the
point where the display is downright deceptive.
I'll grant you that of the major OSen, Linux is the OS most likely to
improve, mind. :-)
Err, not more so than, say, X. :-) There are many replacements for
Explorer. Not many people replace it on general-purpose desktop
machines, because there aren't that many flaws with it.
... and you're fine. So? You just don't do it by patching source code
and recompiling, any more than you install new device drivers by
patching the kernel source.
You just write a plug-in for explorer, like (say) TortiseSVN uses, etc.
Indeed, I just saw someone somewhere complain that copying several files
at once thrashes the drive, and why don't OSes queue up the copies?
Followed by someone the next day posting code that patches into explorer
to do exactly that.  It isn't difficult, if you're immersed in how the
system works. It's just that most programmers only have a very surface
understanding of how Windows works and what you can do with it.
VI? I'll have to see if the middle mouse button works there to paste.
The fact that some programs use one paste buffer and others use another
is also annoying.
I'll grant it's more an issue of training fingers than anything.
It always throws me also that some programs will do the copy as soon as
you highlight text. Or, if the text is still highlighted when you give
the program focus, it'll replace whatever's in the copy buffer with
whatever is highlighted.
Date: 2 Dec 2007 20:30:46
Message: <47535c46@news.povray.org>
  You can always demand a refund...
Date: 2 Dec 2007 21:46:32
Message: <47536e08@news.povray.org>
> an OS would provide the very basic file management functions and options
I'm guessing it's a ploy dreamed up by finance: "Hey, if we hide some of the
slightly advanced features that folks might need to do their job, we can
then charge a little bit more for training!"
Date: 2 Dec 2007 22:03:34
Message: <47537206$1@news.povray.org>
You're so cute sometimes.
Date: 2 Dec 2007 23:33:03
Message: <475386ff$1@news.povray.org>
Or fix it yourself. It's open source after all. :)
Date: 3 Dec 2007 00:20:22
Message: <47539216@news.povray.org>
  While this sounds far-fetched to most, it sometimes is actually very
true.
  For example, years ago, when mplayer was still in its infancy, I had
problems with video playback in a Sun Sparc machine: The red and blue
channels were swapped together. Something to do with a Sparc being
high-endian. Well, I took the source, searched for the place where the
pixels are written, and switched the red and blue channels. It worked.
Date: 3 Dec 2007 02:29:21
Message: <4753b051$1@news.povray.org>
Yep. And I do that, when it would actually take less time to track down
and fix the bug than it would to just put up with it. That doesn't mean
it isn't a bug. :-)
Date: 3 Dec 2007 12:42:18
Message: <47543ffa$1@news.povray.org>
>> On a bare terminal, write it down on paper and save yourself the
>> trouble.
>   copy-pasting
Personally, I use ctrl+shift+c and ctrl+shift+v in a GNOME terminal
window...
Jim
Date: 3 Dec 2007 12:45:44
Message: <475440c8$1@news.povray.org>
On Sun, 02 Dec 2007 16:43:52 -0800, Darren New wrote:
> I'm
I don't know that I'd agree with that.  First, is there a bug in
bugzilla.novell.com about this issue?
Lots of seemingly simple things get overlooked in test cases for QA - no
matter what software vendor it is.  If the test plan doesn't have pasted
text in it, but just entered text to see if it works, then I could see
that being non-working.
Jim
Date: 3 Dec 2007 14:55:54
Message: <47545f4a@news.povray.org>
> window...
  That's a terminal emulator and thus not the same thing as a bare terminal.
Date: 3 Dec 2007 15:27:30
Message: <475466b2$1@news.povray.org>
>> window...
>   terminal.
True....
Jim
Date: 3 Dec 2007 20:54:05
Message: <4754b33d$1@news.povray.org>
I've never seen the latter happen. Can you give an example?
As for the former, usually if you explicitly copy something (using ^C or
^Ins), highlighting something won't erase that from memory. I guess
there may be exceptions.
Do Not Attempt to Traverse a Chasm in Two Leaps...
                                   anl
Date: 3 Dec 2007 23:30:49
Message: <4754d7f9$1@news.povray.org>
I'll keep it in mind to remember the circumstances next time it happens.
It tends to be old apps (like interpreters that have been around since
before Linux) that I see it happen in, IIRC.
Depends how old the app is, and which copy/paste buffer it uses, I think.
Date: 3 Dec 2007 23:32:07
Message: <4754d847@news.povray.org>
Maybe it's just me, but if a URL can't have a space in it, I'd strip
spaces from what comes in from the user before trying to use it, without
even thinking about it. It just rather surprised me.
Date: 4 Dec 2007 05:34:30
Message: <47552d36@news.povray.org>
Just like if you have a folder name coming in, and you're using it to access
a file, you append a "/" or "\" to the end if it isn't there already.
Date: 4 Dec 2007 12:14:38
Message: <47558afe$1@news.povray.org>
>> without even thinking about it. It just rather surprised me.
> access a file, you append a "/" or "\" to the end if it isn't there
> already.
That is something the webserver does (redirect /dir to /dir/), not the
browser.
Date: 4 Dec 2007 17:33:54
Message: <4755d5d2$1@news.povray.org>
Well, if it were me, I'd code that way, too - but it could also be that
they replace the space internally with %20, which would be valid in a
URL.  Could be that's the case they picked instead.
Jim
