OK, so unlike the Euler project, *this* question has some practical use. ;-)
Anybody have any idea how I can make a program generate random numbers
between 30 and 30,000, but so that "most" of the numbers generated are
actually in the range 100 - 400?
"Invisible" <voi### [at] dev null> a écrit dans le message de news:
474aa1aa$1@news.povray.org...
Did you look in POV-Ray rand.inc? :-)
Marc
That's cute. No, I didn't - I'm at work right now. :-P
Besides, I doubt that precise distribution is present. ;-)
#if( rand(s1) < 0.1 )
#local N = rand(s1) * 29970 + 30;
#else
#local N = rand(s1) * 300 + 100;
> #else
> #end
Mmm, yeah, I guess that would work. :-)
http://en.wikipedia.org/wiki/Poisson_distribution
Ooo... trippy:
http://en.wikipedia.org/wiki/Inverse_transform_sampling
Invisible nous apporta ses lumieres en ce 2007/11/26 05:36:
A possibility: Use the division of some random numbers. The divider must have a
range starting at 1.
Samples: rand(X)*29970/(rand(X)*Z+1)+30
(rand(X)+rand(X))*14985/(rand(X)*Z+1)+30
Adjusting Z will shift the peak. Low Z for high location, larger Z for lower
location.
Everybody should believe in something: I believe I'll have another drink.
Well, one step is to develop a random number generator that kicks out a
number from 1 to 1000, with the frequency peaking at 10. Then generate
30 such numbers and sum them.
Or,
Generate 29970 random numbers from 0 to 1. Multiply each one by 29970.
For each product that is less than 220, add one to your running tally.
When you're all done, add 30 to the tally.
The tally will be a number between 30 and 30000, with the results
clustering around 250.
John
I'd have used a Gaussian - any particular reason to choose a Poisson?
Isn't it counterproductive to have incandescent bulbs in a fridge?
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
100 and 400 are both nearer to 30 than to 30,000?
Depends on how efficient or accurate it needs to be.
A simple but inefficient way is to create a curve
function that represents the desired distribution,
generate two random numbers representing an
X,Y vector on the chart, then reject the points
above the curve, and use the X value of accepted
points as the random value.
An efficient but more complicated method is
to create a bar graph approximation of the
distribution curve, then "stack" the rectangles.
Then you can create an X,Y vector guaranteed
to be inside the stack of rectangles, then figure
the X offset of the rectangle based on Y and
use X + X offset @ Y as your random value.
>> #else
>> #end
I saw the question, came to the same answer, and anticipated the same
response, even it had been in haskell. Don't you have some flirting you
should be catching up with?
That requires a partner. :-P
>> you should be catching up with?
You could always flirt with yourself. Mind you don't go blind, though.
Oh that's cute. :-P
"Bill Pragnell" <bil### [at] hotmail com> a écrit dans le message de news:
474d8e1d$1@news.povray.org...
Let's not forget the kittens
http://en.wikipedia.org/wiki/Image:God-kills-kitten.jpg
Marc
http://lolcat.com/godkills.html
Ceiling cat is watching you kill kittens?
A new euphemism is born: "sorry I didn't hear the phone, I was upstairs
killing the kittens..."
You're only half right: every time a *guy* masturbates, God kills a
kitten. Every time a *girl* masturbates, an angel gets its wings.
Tim Cook
Version: 3.12
Woah... I seem to have stumbled into a very scary place here... o_O
Hai! Teh blessigs of teh Ceiling Cat b pwn u, lol!
http://www.lolcatbible.com/index.php?title=Genesis_1
I don't think you understand what flirting is. It's how you get a partner.
Oh.
My.
God.
It's true: *everything* exists on the Internet! 0_0
OK, I rephrase: I'd still need somebody to flirt at. :-P
(Leaving aside the small matter that I've never flirted with anybody in
my life and I wouldn't even begin to know how...)
Am Fri, 30 Nov 2007 09:07:45 +0000 schrieb Invisible:
For starters: Look at your target and smile... (I know it's hard, been
down that road too.)
Bah. I smile at people all the time! They *still* don't like me very much...
