POV-Ray : Newsgroups : povray.off-topic : It's Word again Server Time
20 Jan 2026 17:30:18 EST (-0500)
  It's Word again (Message 1 to 10 of 25)
Subject: It's Word again
Date: 21 Nov 2007 10:02:32
Message: <47444888$1@news.povray.org>
This probably isn't news to you, but... numbered lists seem to be
spectacularly broken in Word 2003.
I mean, sure, they were always a little quirky in Word 97. But now I've
upgraded to Word 2003, it seems just downright *broken*. I've got a
couple of pages, each one with a numbered list on it. And I point-blank
*cannot* make each such list start counting from 1.
I can make *some* of them count from 1, but then that makes the others
reset to start counting from where it left off. Or, sometimes, makes
them start counting from some seemingly arbitrary number like 138.
What in the name of God...?
Seriously, is this behaviour "normal" for Word now?
Subject: Re: It's Word again
Date: 21 Nov 2007 10:40:34
Message: <op.t15eztpmc3xi7v@news.povray.org>
And lo on Wed, 21 Nov 2007 15:02:32 -0000, Invisible <voi### [at] devnull> did
spake, saying:
Right click on the item you want to be 1 (and is showing as 5 or whatever)
select Bullets and Numbering then Restart Numbering, if you've got a list
starting from 1 you don't want to then do the same thing but choose
Continue previous list.
However remember if you have two numbered lists and move items from one to
the other it retains the original list's identity, they're linked so:
1. First point first list
2. Second point first list
3. Third point first list
1. First Point second list
2. Second point second list
if you move Second point second list to the 2nd position in the 1st list
you get
1. Second point second list
2. First Point second list
IOW Second point second list becomes the 1st point in the 2nd list and
what was the 1st point renumbers itself. So trying to Restart a list
becomes more difficult, if you select Second point second list and
Continue previous list First point second list renumbers to 5. and they
all become 1st list.
Does that make any sense?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 21 Nov 2007 10:45:06
Message: <47445282@news.povray.org>
I am teaching Word to my ninth-grade computer literacy class, and
several students have noticed this.
I haven't yet figured out a consistent way to get Word to start the
numbering exactly where you want it.  Our problems have popped up in
tables; for some odd reason, at certain times the second row of a table
picks up the numbering from the second row of the table in the previous
page.  WTF?
There is an option to restart numbering if you select Format->Bullets
and Lists from the menu; it will be applied to the selected text (unless
Word is even buggier than previously known).
The other thing to do is to work from the end of the document upwards,
selecting sections to be numbered and going up from there.
You also might want to switch to Outline view; in there, put the
numbered sections at a given outline level, and make sure that each
section is preceded by an empty line at a higher outline level.
Hope this helps,
John
Date: 21 Nov 2007 10:51:59
Message: <4744541f$1@news.povray.org>
> whatever) select Bullets and Numbering then Restart Numbering.
Approximately 50% of the time, that particular box is disabled.
It's also on the context menu; sometimes it does nothing, sometimes it
resets the *next* item to 1 (*not* the item I clicked), and sometimes it
actually does exactly what I want.
> to the other it retains the original list's identity, they're linked so:
Not really, no.
However, since every page is virtually identical and I created them all
with a large cut and paste operation, presumably it is now impossible to
unlink them and restore deterministic behaviour?
Anyway, I just finished downloading MiKTeX. I'm going to write the
****ing test plan with LaTeX. At least that knows how to number things
consistently. (Not to mention I don't have to spend 20 minutes tweaking
the spacing to get a reasonably printout.)
Date: 21 Nov 2007 11:25:32
Message: <op.t15g1an6c3xi7v@news.povray.org>
And lo on Wed, 21 Nov 2007 15:52:00 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> Not really, no.
It's possible to mix two or more lists together each possessing their own
numbering scheme. So you could have
1
  1
  2
2
  3
  4
with 1 & 2 being part of one list and 1,2,3 & 4 being a second list. I can
move any items from 1234 around without changing 12's numbering. So if you
get something like this with all the numbers at the same level it's
difficult to see what item belongs to what list and Outline won't help you
there.
Reset to Normal Ctrl+A Ctrl+Shift+N or skip the Ctrl+A and just Normal the
lists.
Oo doesn't the QA specifically state what package you have to use to write
it up in? ;-)
Phil Cook
Date: 21 Nov 2007 11:55:47
Message: <47446313$1@news.povray.org>
> spake, saying:
>> Not really, no.
> own numbering scheme. So you could have
> 1
>  1
>  2
> 2
>  3
>  4
> can move any items from 1234 around without changing 12's numbering. So
> if you get something like this with all the numbers at the same level
> it's difficult to see what item belongs to what list and Outline won't
> help you there.
Oh good.
And this is a design *feature*?
>> all with a large cut and paste operation, presumably it is now
>> impossible to unlink them and restore deterministic behaviour?
> the lists.
I'll give it a go...
>> tweaking the spacing to get a reasonably printout.)
> write it up in? ;-)
Actually... no.
They will, however, almost assuredly complain about it being the wrong
typeface.
...all of which is rather moot, since I am insufficiently talented to
convince TeX to generate a box that fills all available space on the
page! >_<
Let's face it, trying to do nontrivial layout with LaTeX isn't much fun
either, is it? *sigh* I'm surrounded...
Date: 21 Nov 2007 14:08:51
Message: <47448243$1@news.povray.org>
It is perfectly expected - there's rational behind how it all works.
It's easy once you figure it out.
Good luck in doing that ;-)
Tom
Date: 22 Nov 2007 07:10:01
Message: <op.t16z2nlwc3xi7v@news.povray.org>
And lo on Wed, 21 Nov 2007 16:55:45 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
>>> Not really, no.
>>  1
>>  1
>>  2
>> 2
>>  3
>>  4
>> help you there.
> Oh good.
I can see why they'd need to link each item in a list together, but that
it fails to break once moved out of the list - hmmm.
>> the lists.
Should get rid of lists and links so you can re-number from scratch, just
don't go moving items between lists.
>> write it up in? ;-)
> Actually... no.
> typeface.
Comic Sans?
Phil Cook
Date: 22 Nov 2007 07:17:55
Message: <47457373$1@news.povray.org>
> spake, saying:
>> Oh good.
Hmm indeed.
>>> Normal the lists.
> just don't go moving items between lists.
I didn't in the first place - just copy & pasting lists to duplicate pages.
>> typeface.
> Comic Sans?
Arial. Possibly the world's ugliest typeface...
Date: 22 Nov 2007 07:18:56
Message: <op.t160g4r8c3xi7v@news.povray.org>
And lo on Wed, 21 Nov 2007 19:08:51 -0000, Tom Austin <taustin> did spake,
saying:
>> I've upgraded to Word 2003, it seems just downright *broken*. I've got
>> a couple of pages, each one with a numbered list on it. And I
>> point-blank *cannot* make each such list start counting from 1.
Talking to an older guy who despairs of every 'getting' computers and
bemoaning his own stupidity I point out he's not stupid it's just that
computers tend to use their own rules of logic that he's not familiar
with. "In Windows to stop the computer press Start" makes sense if you
consider each action has to be initiated and the Start button is(can be)
the beginning of all such actions.
Of course it doesn't help when they break their own rules; consider how
windows open in Excel2k compared to Word2k, or in Andy's case they create
invisible rules you can't see.
Phil Cook
