Take a look at this:
http://www.nullsoft.com/free/monkey/
Anybody got any ideas what the cave-building algorithm is? (As in, I'd
like to copy it...)
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/18 10:37:
> like to copy it...)
It's looks like it's based on tubes. You travel a tube and it encounters other
tubes at various angles. Any triangle that is inside any tube is removed. All
edges are smoothed, a little like for a blob.
You could use splines to place blob components, you then place the camera inside
the blob. Use a low strenght, or a large treshold value.
If it weren't for pickpockets, I'd have no sex life at all.
Rodney Dangerfield
> other tubes at various angles. Any triangle that is inside any tube is
> removed. All edges are smoothed, a little like for a blob.
Yeah, but it looks a little more complex than that. There are large
chambers that don't appear to be "tube-like", and there are passages
that aren't quite circular, and so on. (Maybe the tube diammeter varies
or something?)
Well anyway, it looks like it could be *awesom* with true
light-sourcing, global illumination, and maybe some volumetric light
scattering. ;-)
> chambers that don't appear to be "tube-like", and there are passages that
> aren't quite circular, and so on. (Maybe the tube diammeter varies or
> something?)
My immediate thought was that you take the nVidia "Cascades" demo and invert
it so you are inside the geometry, not outside it...
Take a look at the "rock generation" part of these slides, they have some
useful info for building geometry like this, and most of it is directly
portable to POV iso-surfaces:
http://developer.download.nvidia.com/presentations/2007/gdc/CascadesDemoSecrets.zip
> invert it so you are inside the geometry, not outside it...
Yeah, that demo sounds quite interesting. Pitty my graphics card is
insufficiently expensive to run it...
> some useful info for building geometry like this, and most of it is
> directly portable to POV iso-surfaces:
Mmm, OK.
"Invisible" <voi### [at] dev null> wrote in message
news:47416e37$1@news.povray.org...
2007 Happily awaits your arrival ;)
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/18 14:14:
>> encounters other tubes at various angles. Any triangle that is inside
>> any tube is removed. All edges are smoothed, a little like for a blob.
> or something?)
> scattering. ;-)
Most large chambers are the intersection of several conduits. When over 5
twisting tubes intersect, you loose the apearance of tubes. On ocasions, I saw
some bits of "floating" objects in those large chambers.
Some passages are actualy made of 2 or more almost parallel tubes, and some of
those may be flattened.
You know you've been raytracing too long when you've tried rendering hair with
each strand as an object.
Quietly Watching
And what's that meant to mean?
> 5 twisting tubes intersect, you loose the apearance of tubes. On
> ocasions, I saw some bits of "floating" objects in those large chambers.
> some of those may be flattened.
Mmm, seems plausible. You'd have to have some fairly high-order
smoothing to blur out the details though. Also, are the tunnels entirely
random? Do they all run more or less parallel with perturbed paths? Are
the statistics random or carefully tuned?
Time to experiement, I think... ;-)
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/19 13:17:
>> over 5 twisting tubes intersect, you loose the apearance of tubes. On
There are tunels that seems perpendicular to the one you travel, but most
intersect at a sharp angle.
Possibility: generate the main tunel.
Randomly generate a cluster of points around it's path, in a radius about twice
the radius.
For each point, select a random direction and curvature. Possibly add some
radius variance.
At times, you bet filled whireframe, and the mesh resolution is fairly low at
"high" quality. If you deselect "Disable hair effect", you get small sticks at
the triangles angles that seems to corespond to the normals.
You know you've been raytracing too long when you've gained twenty pounds
sitting at the computer, but can't tell because your beard covers your stomach.
Taps a.k.a. Tapio Vocadlo
> like to copy it...)
How about this?
Thought I'd have a play about at lunch and this is the best I came up with
(the black hole is a weird error due to a too low max_gradient).
I got some of the ideas form that nVidia presentation I posted, plus some
random noise. The core geometry is three "cylinders" that rotate around the
z-axis in a circle at different rates.
Here's the functions to get the xy coords of the rotating tubes:
#declare fn_P1x = function(z) { 6*cos(z/19) }
#declare fn_P1y = function(z) { 6*sin(z/19) }
#declare fn_P2x = function(z) { 6*sin(z/11.2 + 2.6) }
#declare fn_P2y = function(z) { 6*cos(z/11.2 + 2.6) }
#declare fn_P3x = function(z) { 6*sin(z/17.12 - 8) }
#declare fn_P3y = function(z) { 6*cos(z/17.12 - 8) }
And here's the main isosurface function (it's all a bit messy):
#declare fn_X = function(x,y,z)
6 / sqrt( pow((x)-fn_P1x(z),2) + pow((y+6)-fn_P1y(z),2) ) - 1
+4 / sqrt( pow(x-fn_P2x(z),2) + pow(y-fn_P2y(z),2) ) - 1
+7 / sqrt( pow(x-fn_P3x(z),2) + pow(y-fn_P3y(z),2) ) - 1
-1 *(noise(x/4,y/4,z/4)-.5)
Use a contained_by { box { <-20,-20,0>, <20,20,500> } } and view it from -z
down the z axis.
Download 'rock_tunnel 2.jpg' (77 KB)
Preview of image 'rock_tunnel 2.jpg'
>> like to copy it...)
> How about this?
> with (the black hole is a weird error due to a too low max_gradient).
There are other tiny black holes at the back.
Can you easily get a path through the tunnels, for example to move the
camera through it? :) How long did the render take?
scott wrote:
> How about this?
Mmmmm. Bronchia. Not shiny enough, tho.
Is this still off-topic, when you're posting POV code? :-)
It's not feature creep if you put it
at the end and adjust the release date.
Wow! I just looked at this again at home, and I can see the whole
tunnel! What I viewed it at work, there was a large black hole, with a
narrow pink bit around the edges of the picture.
Jesus my monitor has an absurd gamma factor...
>> How about this?
Yeh, they're all max_gradient errors. I was using 1 during testing, but
even upping it to (IIRC) 5 in the final render they were still there.
Yep, I would just choose one of tunnels and move the camera along the centre
line, should work assuming no huge noise part overlaps the centre of the
tunnel. A better way would be to find the maximum value of the isosurface
at each xy slice and put the camera there.
About 20 mins, but a smaller one with less AA and lower max_gradient should
be way quicker.
