POV-Ray : Newsgroups : povray.off-topic : Guess the algorithm Server Time
29 Jun 2026 07:37:57 EDT (-0400)
  Guess the algorithm (Message 1 to 10 of 15)
Subject: Guess the algorithm
Date: 18 Nov 2007 10:37:29
Message: <47405c39$1@news.povray.org>
Take a look at this:
http://www.nullsoft.com/free/monkey/
Anybody got any ideas what the cave-building algorithm is? (As in, I'd
like to copy it...)
Subject: Re: Guess the algorithm
Date: 18 Nov 2007 12:22:25
Message: <474074d1$1@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/18 10:37:
> like to copy it...)
It's looks like it's based on tubes. You travel a tube and it encounters other
tubes at various angles. Any triangle that is inside any tube is removed. All
edges are smoothed, a little like for a blob.
You could use splines to place blob components, you then place the camera inside
the blob. Use a low strenght, or a large treshold value.
   If it weren't for pickpockets, I'd have no sex life at all.
   	Rodney Dangerfield
Date: 18 Nov 2007 14:14:12
Message: <47408f04$1@news.povray.org>
> other tubes at various angles. Any triangle that is inside any tube is
> removed. All edges are smoothed, a little like for a blob.
Yeah, but it looks a little more complex than that. There are large
chambers that don't appear to be "tube-like", and there are passages
that aren't quite circular, and so on. (Maybe the tube diammeter varies
or something?)
Well anyway, it looks like it could be *awesom* with true
light-sourcing, global illumination, and maybe some volumetric light
scattering. ;-)
Date: 19 Nov 2007 04:27:43
Message: <4741570f@news.povray.org>
> chambers that don't appear to be "tube-like", and there are passages that
> aren't quite circular, and so on. (Maybe the tube diammeter varies or
> something?)
My immediate thought was that you take the nVidia "Cascades" demo and invert
it so you are inside the geometry, not outside it...
Take a look at the "rock generation" part of these slides, they have some
useful info for building geometry like this, and most of it is directly
portable to POV iso-surfaces:
http://developer.download.nvidia.com/presentations/2007/gdc/CascadesDemoSecrets.zip
Date: 19 Nov 2007 06:06:31
Message: <47416e37$1@news.povray.org>
> invert it so you are inside the geometry, not outside it...
Yeah, that demo sounds quite interesting. Pitty my graphics card is
insufficiently expensive to run it...
> some useful info for building geometry like this, and most of it is
> directly portable to POV iso-surfaces:
Mmm, OK.
Date: 19 Nov 2007 11:51:32
Message: <4741bf14$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47416e37$1@news.povray.org...
2007 Happily awaits your arrival ;)
Date: 19 Nov 2007 12:00:23
Message: <4741c127$1@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/18 14:14:
>> encounters other tubes at various angles. Any triangle that is inside
>> any tube is removed. All edges are smoothed, a little like for a blob.
> or something?)
> scattering. ;-)
Most large chambers are the intersection of several conduits. When over 5
twisting tubes intersect, you loose the apearance of tubes. On ocasions, I saw
some bits of "floating" objects in those large chambers.
Some passages are actualy made of 2 or more almost parallel tubes, and some of
those may be flattened.
You know you've been raytracing too long when you've tried rendering hair with
each strand as an object.
Quietly Watching
Date: 19 Nov 2007 13:14:02
Message: <4741d26a@news.povray.org>
And what's that meant to mean?
Date: 19 Nov 2007 13:16:58
Message: <4741d31a$1@news.povray.org>
> 5 twisting tubes intersect, you loose the apearance of tubes. On
> ocasions, I saw some bits of "floating" objects in those large chambers.
> some of those may be flattened.
Mmm, seems plausible. You'd have to have some fairly high-order
smoothing to blur out the details though. Also, are the tunnels entirely
random? Do they all run more or less parallel with perturbed paths? Are
the statistics random or carefully tuned?
Time to experiement, I think... ;-)
Date: 19 Nov 2007 22:16:22
Message: <47425186$1@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/19 13:17:
>> over 5 twisting tubes intersect, you loose the apearance of tubes. On
There are tunels that seems perpendicular to the one you travel, but most
intersect at a sharp angle.
Possibility: generate the main tunel.
Randomly generate a cluster of points around it's path, in a radius about twice
the radius.
For each point, select a random direction and curvature. Possibly add some
radius variance.
At times, you bet filled whireframe, and the mesh resolution is fairly low at
"high" quality. If you deselect "Disable hair effect", you get small sticks at
the triangles angles that seems to corespond to the normals.
You know you've been raytracing too long when you've gained twenty pounds
sitting at the computer, but can't tell because your beard covers your stomach.
Taps a.k.a. Tapio Vocadlo
