My 19" LCD packed up the other night, and I thought I'd replace it with a
widescreen (20" or 21") LCD
I've heard good things about the BenQ 20" and about the LG monitors.
Anyone with personal experience with widescreen LCDs? It's going to be used
for graphics, movie watching (a little) and gaming.
I checked Tom's hardware, but all the LCD reviews I could see were last year
I had a bad experience with an LG monitor, though it wasn't widescreen. I
can no longer remember its name, but the problems were these two details:
1) The monitor used that technology (I've forgotten the name) where the
brightness and colors are different depending on which angle you look at the
monitor from. Most laptop monitors are like this too, but it was very
uncomfortable for a stationary monitor, especially when working with
graphics.
2) The monitor was not true 24-bit. Again, I have forgotten what it actually
was, but it had fewer than 256 colors per channel, which were then
interpolated. You couldn't see it most of the time, but when working with
subtle gradient, like a blue sky, it was visible and annoying.
If you find an LG monitor that uses the angle-independent technology and is
true 24 bit, then these observations don't apply of course.
Rune
Wow that sucks. I'm finding 256 colors per channel being not enough!
(like on grayscale images :P)
That's... interesting. I'm fairly sure I read somewhere that for
*greyscale* the human visual system can only distinguish about 16
different levels. (Not sure whether that's *linear* though...)
Yeah, if I have 16 *consecutive* grayscale values (185, 186, 187, 188,
189...) on an image, I can definitely distinguish them!
> different levels.
That's unusually easy to prove wrong. How many bars can you count in
this image? http://warp.povusers.org/images/grayscales.png
The number you counted is the amount of grayscales you can distinguish
at least. (The true number is probably at least that times 10 or more.)
>> different levels.
While some cells in the eye may be able to distinguish that many colors,
that doesn't mean that the visual system in the brain can. A lot of
preprocessing is done in the eyes themselves before the visual data is sent
to the brain.
For example, the eyes have an edge detecting layer I think, or something
along those lines. This layer could find all the edges of the bars in your
image and send information about these edges on to the brain, so that the
brain can tell how many bars there are. The eyes also send the actual "raw"
brightness info on to the brain, but this may be in a "low resolution" where
no more than 16 different shades can be told apart. However, the brain can
still count all the bars, becuase of the edges detected in the eyes.
I'm not saying it's like that; just that your image doesn't prove anything
about the amount of gray scales the brain can tell apart. So it really comes
down to what you mean by "human visual system" - the eyes or the brain.
Rune
>> different levels.
First two and last two look quite similar from some angles (damned LCD
screen). Also, the black ones look all similar (damned gamma; the world
would be a better place if screens had had built-in gamma correction
since the beginning).
I'm quite certain that if it was an animation where each frame is
completely filled by a shade of gray and was played eg. at 1 FPS, you
could clearly see the change.
Warp nous apporta ses lumieres en ce 2007/11/17 12:19:
>> different levels.
I can count about 30 very distinct bands, monitor permiting.
A short cut is the longest distance between two points.
"Warp" <war### [at] tag povray org> wrote in message
news:473f3242@news.povray.org...
>> your
>> "raw"
>> where
>> can
That might be one test, but it still makes it easy for the brain by showing
transitions.
What if you had a test that didn't allow the eyes/brain to calibrate from
frame to frame?
What if your vision was blanked for a time (eg. half-second or second)
between each successive frame? How many grey shades could you distinguish
reliably?
> distinguish reliably?
That wouldn't be a fair test. It's hard for humans to find differences
between two images (even big differences) if the image blanks for a
second before showing the other. I saw an example that swapped two
images with a black screen in between, then did it again without the
black screen and *then% I could notice the differences.
Anyway, I don't care about an accurate test of eye sensitivity. I just
know that I can notice "color bands" on grayscale images, and more bits
per channel would avoid that.
Nicolas Alvarez escribió:
> I just know that I can notice "color bands" on grayscale images, and
> more bits per channel would avoid that.
Oh, and I remember a suggestion of converting a 48-bit image to 24-bit
using dithering. I wonder how good that would look...
Rune wrote:
> A lot of
> to the brain.
You'd be amazed. :-)
> along those lines.
First a change detector layer, then from that a bunch of edge detectors,
then object detectors, then motion detection, then ...
Before it leaves you're eyes, they already know there's something large
coming towards you from the left. That info is hooked directly from eyes
to neck muscles.
True.
Well, it's an analog pulse train. Actually, I'm not sure how far up the
pile before *you* decide it's no longer eyes and has become brain. I'm
also not sure if the cells that actually sense light are integrated into
anything at a higher level at all, or whether all their info is
processed before getting to the "brain" part.
I think if you're picking out a monitor, you're worried about your
brain's perception of it. :-)
Remember the good old days, when we
used to complain about cryptography
being export-restricted?
Nicolas Alvarez nous apporta ses lumieres en ce 2007/11/17 19:12:
It can look very good, if the resolution is fine enough. The best would be to
use something like "error diffusion" dithering. That's a random noise dithering
technique. That's the way I got the best printing for smooth shades.
One tequila, two tequila, three tequila, floor.
Darren New nous apporta ses lumieres en ce 2007/11/17 19:45:
> Rune wrote:
>> A lot of preprocessing is done in the eyes themselves before the
>> visual data is sent to the brain.
>> something along those lines.
> to neck muscles.
>> This layer could find all the edges of the bars in your image and send
>> information about these edges on to the brain, so that the brain can
> True.
>> The eyes also send the actual "raw" brightness info on to the brain,
>> but this may be in a "low resolution" where no more than 16 different
>> However, the brain can still count all the bars, becuase of the edges
>> anything about the amount of gray scales the brain can tell apart. So
>> it really comes down to what you mean by "human visual system" - the
>> eyes or the brain.
Processing steps for human vision:
- retina catch light
- Raw image processing by the retina itself
- More image processing between the retina and the optical nerve
- Still more processing by the optical nerve (maybe the only nerve that have
actual processing capability)
- Final gross processing by the brain
- Pattern recognition and image reconstruction
- Visual memory cross references image completion
I may have missed/myss ordered some steps...
There will always be beer cans rolling on the floor of your car when the boss
asks for a ride home from the office.
Wow... Having a color corrected screen does wonders. I can see all 32
levels. I can also see I need to run the calibration tool on my CRT
again (the lower 2 levels don't show, but they do on the LCD)
I've seen these grayscales used on photography sites occasionally to
make sure brightness and contrast are optimal.
My home monitor is a Samsung 22" widescreen (Can't remember the exact
model number off-hand) The only drawback is if you get far enough
off-axis the colors begin to distort, but it has good contrast ratio,
and very fast response time.
One of my primary complaints about the monitor I have at work is if you
scroll white text over a black background, it literally disappears.
Doesn't happen on my Samsung.
Ah, here it is, the 226BW:
http://tinyurl.com/24544j
And lo on Sun, 18 Nov 2007 00:10:30 -0000, Nicolas Alvarez
<nic### [at] gmail is the best com> did spake, saying:
Look up saccadic masking, our eyes blank out info when they're moving so
you could have two screens with no intermission if they just in different
places relative to a neutral background.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
You mean like the attached images? Which pair of squares are the same
colour and which pair are different? (I used colours from Warp's vertical
bar image)
Download 'grey test.png' (3 KB)
Download 'grey test 2.png' (3 KB)
Preview of image 'grey test.png'
Preview of image 'grey test 2.png'
My wife’s PC has a BenQ monitor. It is not a wide screen but the image quality
is quite good (acceptable to me) and it was quite cheap. But I found out later
that they use “slave labour”. Well under paid immigrant labout.
And lo on Mon, 19 Nov 2007 15:28:26 -0000, scott <sco### [at] laptop com> did
spake, saying:
>> different
> vertical
> bar image)
I was thinking more top-left, top-left plus bottom-right, bottom-right,
reverse; so your eye would move from one to the other but not be able to
have both colours up at the same time for any comparison. No transition
flicker, no edge detection, just were those two colours the same.
Phil Cook
>> world would be a better place if screens had had built-in gamma
>> correction since the beginning).
The problem is that if your screen is perfectly color-corrected,
everything looks weird, because the people who design websites, etc.
work with non-color-corrected screens!
I have a Hewlett Packard "HP w20"
For graphics/rendering/3D-Modeling, videos/animations, DVD's the monitor is OK
For Office and development a wide-monitor is IMO generally better than
a 4:3-monitor.
"Gaming" - I can't say very much to this, because I'm using LINUX.
The monitor does have two horrible (and IMO absolutly useless)
integrated speakers. But this is not a specific problem of *this* monitor
the most integrated monitor-speakers sounds terrible.
So I don't use them.
My conclusion:
I love this wide-monitor and never want back to a 4:3-monitor
I still keep Gamma at 2.2, since Windows apps are usually designed to
that, and most websites created on the PC are designed to that. The D65
whitepoint takes some getting used to, for a while everything looks too
yellow, but colors look richer.
In an ideal world, people would use an image editor that has color
management (Photoshop) and web browsers would have proper color
management, which would eliminate the gamma and color issues. But using
a proper color-managed workflow is tricky, especially when working with
multiple outputs.
"Meothuru" <nomail@nomail> wrote in message
news:web.47427b6b1d7416445a73e3b40@news.povray.org...
> My conclusion:
I fell in love with the widescreen when I bought a 17" laptop. It's heavy,
but so nice to work on.
"Mike Raiford" <mra### [at] hotmail com> wrote in message
news:47418ced$1@news.povray.org...
a
Not sure if there's space on the desk for a 22". The 20 is going to take
some squeezing. Will look at it.
Measure first. :) I originally had a 19" CRT that seemed to take up a
lot of space on the desk, the 22" took up a little more space, but still
fit. if 20 or 21 is a squeeze, I'd definitely check dimensions before
I purchased the screen.
I recently bought an LG monitor, a 24" widescreen L246W and I'm pretty
happy with it. The type of panel is important if you're doing art with POV-Ray,
or anything that requires accurate colors. I compromised a bit with the L246W,
a lot less expensive than the more accurate panel types.
Lots of good info on monitors, including specific model recommendations, here:
http://hardforum.com/forumdisplay.php?f=78
The sticky thread on "TFT Technology Breakdown and Model/Panel Index" is
especially useful.
Mark
"Renderdog" <slo### [at] hiwaay net> wrote in message
news:web.4743e4ee1d741644fb72c6fc0@news.povray.org...
> especially useful.
Thanks. I'll check that out.
