POV-Ray : Newsgroups : povray.off-topic : The nebulous question of probability Server Time
3 Nov 2026 18:27:45 EST (-0500)
  The nebulous question of probability (Message 1 to 30 of 30)
Subject: The nebulous question of probability
Date: 15 Nov 2007 06:30:58
Message: <473c2df2@news.povray.org>
Quoting RFC #1321, Section 1:
"It is conjectured that it is computationally infeasible to produce
two messages having the same message digest, or to produce any
message having a given prespecified target message digest."
This conjecture has now been determined to be false. In fact, a single
laptop can perform both these tasks in a few minutes using a suitable
algorithm.
However, one might also conjecture that the probability of any two
arbitrary messages having the same [MD5] hash code would be 2^(-128).
Does the existence of a collision-generation algorithm for MD5
contradict this second conjecture?
(In othe words, it is possible to *maliciously* alter a message without
affecting the MD5 hash, but what is the probability of an *accidental*
modification going undetected? Is it 2^(-128)? Or is it some higher
probability?)
Subject: Re: The nebulous question of probability
Date: 15 Nov 2007 09:06:13
Message: <473c5255$1@news.povray.org>
Actually, according to the Birthday Paradox, the probability in this
case is much lower.
All I *really* want to know is the probability of a random alteration to
a file going undetected by an MD5 hash comparison. But this depends on
just how "random" MD5 really is. Apparently it's not something anybody
has looked at much. The existence of a collision algorithm seems to
suggest that it's not all that random, but I don't know...
Date: 15 Nov 2007 10:41:09
Message: <473c6895@news.povray.org>
  I think it's quite unlikely.
  I wonder how much more unlikely it would be if you calculated two MD5
codes: The first one is calculated in the regular way, and the second one
is calculated starting from the second byte in the file forwards, and taking
the first byte as if it was the last (iow. effectively as if you had removed
the first byte of the file and appended it to the end of the file).
  A random change which would keep one of the MD5 sums the same would
quite unlikely keep the other one the same too. I have no idea about the
probabilities, though.
Date: 15 Nov 2007 11:30:09
Message: <473c7411$1@news.povray.org>
I think it's astronomically unlikely. I'd just like to be able to put a
hard number on that though. ;-)
Alternatively, take the MD5 *and* the SHA-1 hash as well. Or better yet,
take the MD4, MD5, SHA-1, SHA-256, WIRLPOOL and RIPEMD hashes.
But let's face it, "md5sums" is a psuedo-standard file format that is
quite widely recognised.
The real reason we're interested in this is for checking that CDs are
readable. Currently, we "check" the CD by looking at the directory
listing and confirming that every file is present and has the correct
size in bytes.
In other words, we check that the Table Of Contents on the CD has been
burned correctly. :-P
In a sense, the important point about MD5 is that checking a CD this way
ensures that every single bit of data is physically read from the
surface of the disk. If you can do that, the data is probably correct
anyway...
(Let us not forget that the CD itself puts the data through two seperate
layers of Reed-Solomon codes anyway, not to mention filesystem metadata
probably has CRC32 checksums in there.)
If a CD is defective, you're far more likely to get read/write errors
from the operating system than actual garbage data, so perhaps the
actual hash value is irrelevant.
By the way, do you know how MD5 works? It's kind of interesting. I'm
currently trying to implement it in Haskell - but I'm being thwarted
because it uses that brain-deadness known as "little-endian integers".
(These really shouldn't exist...)
Basically, you take your file and split it into 512-bit blocks, padding
the final block to make it exactly 512 bits. (Actually it's slightly
more complicated than that.) Then, starting from the hash value
   0123456789ABCDEFFEDCBA9876543210
you process each block using the MD5 "compression function", which
updates the hash value. Add the new hash value to the previous hash
value to get a final output, and then repeat for the next block. When
all blocks have been processed, whatever the final hash value is, *that*
is the MD5 hash value.
In particular, if you change one particular message block in such a way
that the compression function maps it to the same value, then the MD5
hash of the whole file will be unchanged. So you really want to
scrutinise that compression function...
The compression function itself consists of a loop repeated 16 times,
each time with different parameters. At each loop, you rotate the hash
round, and mutate one of the 32-bit words within it. You do this by
adding a mash value to it; this mash value is derived from
- A table of constants (derived from the sin(x) function)
- A bit-wise combination of the other 32-bit words in the hash. (The
exact combination varies throughout the loop.)
- A 32-bit word from the input block. (The exact one is determined by
the loop counter, but with a nontrivial relationship.)
The mash value is also bit-rotated by a loop-specific amount first.
And that, my friends, is basically the MD5 algorithm... It certainly
*looks* like it should give your data a good mashing, but on the other
hand, there are loads of places where you can say "hmm, if somehow the
same numbers got here, the results would be identical".
Date: 15 Nov 2007 11:33:10
Message: <473c74c6$1@news.povray.org>
Gah! 64 times... >_<
Maybe I should just stop typing now? :-S
Date: 15 Nov 2007 11:40:26
Message: <473c767a$1@news.povray.org>
I would assume Warp knows... :)
Date: 15 Nov 2007 16:39:29
Message: <473cbc91$1@news.povray.org>
> algorithm.
Do you have a cite for this? I'd heard of the first problem being
broken, but not the second one.
Only if you do it on purpose. Obviously, to *arbitrary* messages will
have low probablility of a hit.
> probability?)
It's still a low probability. You have to alter the message in a way
that takes specifically into account how MD5 works. That's why the same
technique doesn't work on other hashes.
> Actually, according to the Birthday Paradox, the probability in this case is much
lower.
Not with only two messages.
> But this depends on just how "random" MD5 really is. Apparently it's not something
anybody has looked at much.
People looked for any collision for a decade or more before the folks
who professionally analyze cryptographic systems figured out how to
cause a collision. It's sufficiently unlikely a random change in a file
will cause you any grief that you need to worry about it.
The reason people worry about it is they fear an active, intelligent
adversary changing that which has been signed.
> In a sense, the important point about MD5 is that checking a CD this way ensures
that every single bit of data is physically read from the surface of the disk. If you
can do that, the data is probably correct anyway...
Since the TOC is at the start of the CD, I find this much more likely to
be broken. Checksum the TOC, the first file, and the last file, and
*then* you don't have to read the whole CD. I'd say 1/3rd of my CDs that
coaster have a good TOC and no actual file data on them.
> there are loads of places where you can say "hmm, if somehow the same numbers got
And that's exactly how they went about cracking it. :-)
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 15 Nov 2007 16:57:25
Message: <473cc0c5$1@news.povray.org>
>> algorithm.
Wikipedia. (So... utterly trustworthy then. Mind you, I believe there's
a reference at the bottom.)
You know how it is - somebody posts a near-break, somebody else extends
it, somebody else makes it go faster, etc.
> Only if you do it on purpose. Obviously, two *arbitrary* messages will
Well... the fact that collisions can be constructed prove that they
exist, which might suggest the function is "less random" than it should
be...
>> without affecting the MD5 hash, but what is the probability of an
>> *accidental* modification going undetected? Is it 2^(-128)? Or is it
>> some higher probability?)
True. I'd just like to put a number to it, that's all. ;-)
>> case is much lower.
Probability is defined as "if you did this X times, Y times the event
would occur". So even with 2 messages, it matters.
>> not something anybody has looked at much.
Well, if people searched for decades without finding any collisions,
they must be reasonably rare then. (At least, for the kinds of messages
people tried hashing.) That suggests that at least the function doesn't
collide *massively* more often than it should...
Ah yeah, sure, MD5 isn't cryptographically secure. I get that. I'm just
wondering how useful it is for detecting random alterations.
>> way ensures that every single bit of data is physically read from the
>> anyway...
...which is why just checking that you can "see" the filenames is no
good at all. Clearly the person who wrote the official procedure is a
legal expert not a computer expert...
The worrying thing being, how likely is it that such a thing might just
happen by accident? :-}
Date: 15 Nov 2007 17:12:35
Message: <473cc453$1@news.povray.org>
> be...
The fact that the digest is smaller than the input data proves that
collisions exist. If the digest is 1 byte smaller than the input data,
there are 256 collisions possible.
The question is how easily you can "construct" a collision (if the only
  way is testing *all* combinations of bits, the hash function would be
"ideal").
Date: 15 Nov 2007 20:22:07
Message: <473cf0bf$1@news.povray.org>
Someone at Oxford has done it, but I think it uses the FFI.
http://web.comlab.ox.ac.uk/oucl/work/ian.lynagh/md5/haskell-md5-0.1.0/
Date: 16 Nov 2007 04:16:58
Message: <473d600a@news.povray.org>
Nicolas Alvarez wrote:
> The question is how easily you can "construct" a collision.
Actually, I think the question is how evenly scattered the collisions
are... ;-)
Date: 16 Nov 2007 13:20:51
Message: <473ddf83$1@news.povray.org>
In fact, *several* people have done it - ranging from FFI bindings to
existing MD5 libraries to pure Haskell implementations in different forms.
I'm mainly trying to implement it in Haskell for fun; it'll probably go
too slow to be useful. (But we'll see about that...)
Date: 16 Nov 2007 13:48:09
Message: <473de5e9$1@news.povray.org>
Orchid XP v7 wrote:
> Wikipedia.
Of course. Duh. Still getting used to these intratubes, ya know.
> be...
First, yes, of course they exists. As soon as you have meesages >128
bits, you by necessity have collisions. Second, the function isn't
supposed to be random, it's supposed to be non-invertible.
Two arbitrary files? Probably very close to 2^(-128)
>>> case is much lower.
The birthday paradox says "how many people can you put in a room before
there's a probability that two have the same birthday."  If there's only
two, it's still 1/365.
So if you're just looking at one hash and saying "how many files will
make this hash", there's no birthday paradox probability involved. If
you look at a big pile of files, and you ask "how likely is it that two
have the same hash", the birthday paradox comes into it.
But if you're talking 2^(-128) to start with, you can go an awful long
time before you have to worry about it.
Correct. It was best-of-breed for a long time, and then still used under
warnings for a long time later.
Nobody can give you a perfect assurance. I would guess, however, that
you're much more likely to have the disk get scratched and unreadable as
you pick it up out of the tray than to have an existing change cause a
collision in the MD5 hash.
Hell, you're much more likely to get struck by lightning as you head
home from work than have an accidental collision in an MD5 hash.
Very slim, or it would have happened much earlier.
Date: 16 Nov 2007 14:04:26
Message: <473de9ba$1@news.povray.org>
>> should be...
Indeed. But I'm using it for its randomness...
Depends where you live. Apparently in the USA the chance of being killed
by lightning is only 1 in 700,000. That's actually quite a *high*
probability. o_O
Apparently the changes of winning the National Lottery (absurdly
improbable) is x * 10^(-8), for some "small" x. (I don't remember what
it is.) 2^(-128) works out as x * 10^(-39) - the theoretical probability
of winning the Lottery several times back to back. I guess even if we
assume MD5 is moderately screwed, you'd still have to estimate the
collision probability at 10^(-24) or something. That's still fairly
improbable...
>> just happen by accident? :-}
Yeah, I'm fairly sure it's quite a low probability too. I'd just like to
be able to put an objective figure to it. ;-)
Date: 16 Nov 2007 14:49:23
Message: <473df443$1@news.povray.org>
> probability. o_O
Exactly. Far far larger than 2^-128.
Funny enough, I saw where someone had looked up the death statistics,
and figured out you had a 2000x better chance of being killed between
the time you bought your lottery ticket and the time the big winner was
announced than the chance of you actually being the big winner.
If you could give a reliable objective number, you'd know enough of how
it works to calculate it without going thru the actual math.
Date: 16 Nov 2007 16:13:24
Message: <473e07f4$1@news.povray.org>
Oh my *God*, I've just spent my entire evening trying to make this damn
thing work! I was thwarted by the following:
- I mis-typed certain magic numbers, causing the output to be a few
digits wrong. >_<
- I forget the final state-add step. I spent literally *ages* trying to
figure out why all the output was correct up until the very last stage.
- The hash is little-endian. Damn thing! I actually had the right
output, it just looked wrong because you have to turn it half-backwards
according to the dumb RFC. *sigh*
So yays! My program now correctly hashes the 0-byte string to yield an
MD5 hash of D41D8CD98F00B204E9800998ECF8427E.
Now all I need to do is implement the very fiddly bit-padding algorithm
and I'm golden...
It's TF2 time!
Date: 16 Nov 2007 16:35:31
Message: <473e0d23@news.povray.org>
  I could do that much faster than you. Probably in something like
10 seconds. ;)
Date: 16 Nov 2007 16:54:33
Message: <473e1199@news.povray.org>
> 10 seconds. ;)
if (data.length == 0) {
	return "D41D8CD98F00B204E9800998ECF8427E";
} else {
	error("Not implemented yet");
Date: 16 Nov 2007 17:08:14
Message: <473e14ce@news.povray.org>
  error("I'll implement this when I have the time.")
Date: 17 Nov 2007 06:49:50
Message: <473ed55e$1@news.povray.org>
> 10 seconds. ;)
Well, I now have the full algorithm working. :-P
Or at least, it seems to work for messages shorter than 52 bytes anyway.
It seems there's still a glitch in the padding algorithm that makes it
go wrong for messages longer than 1 block...
I'm just amazed that I managed to implement an algorithm as complex and
fiddly as MD5 in only 2 days. Heh.
Date: 17 Nov 2007 07:28:59
Message: <473ede8a@news.povray.org>
  Then it's not a full working algorithm, is it?-)
  Testing that the algorithm works for all possible inputs would be a rather
laborious job. Just testing that it can produce any MD5 value would be a
rather impossible job, taking into account how many there are.
  I wonder how they make sure that an implementation is correct...
Date: 17 Nov 2007 09:12:02
Message: <473ef6b2$1@news.povray.org>
Well, it's damn near. :-P
Test all code paths, I assume.
For example, I am pretty damn confident that the compression function in
my implementation is correct. I've tested it with dozens of different
input blocks, and it's always produced the right output. There's no
particular reason why it shouldn't for other input blocks. It processes
them all the same way...
Now, the padding algorithm, *that* changes for every message size. For
some sizes it seems to work, but not for all of them. I need to test it
with a large array of sizes to check it's working. (Or rather, to figure
out why currently it isn't.)
Date: 17 Nov 2007 12:43:32
Message: <473f2844$1@news.povray.org>
Ah-HAH! One more bug, annihilated. >:-)
In the midst of a complex padding algorithm, I forgot to add on the
running count of the number of bytes processed. The "size" figure
appended onto the end of the bitstream was always the size of the last
block, not the whole message. (IOW, message size mod 512.) Oops!
The program now appears to give correct results for every case I've
tried. (I.e., not very many. However, I threw a 2 MB file at it, and it
gave me the right answer. This indicates that it's not *completely*
broken...)
And yes, it's just a tad slower than C. ( = exaggeration.)
Date: 17 Nov 2007 18:47:33
Message: <473f7d95$1@news.povray.org>
Generally, code coverage and intermediate results, along with a set of
test vectors designed to cover all paths through and often showing the
intermediate results.
It's somewhat easier when your specification is "here's the C code to do
it" rather than an ambiguous description of what you're supposed to do.
Especially since there isn't any "real world" right or wrong answer,
other than "match what the C code outputs."
Plus, of course, it's designed to go wildly arwy with the slightest
peturbation of the process, so even tiny bugs tend to produce completely
different results. Which is its own debugging problem.
Date: 18 Nov 2007 04:38:56
Message: <47400830@news.povray.org>
I got 2 bits wrong in one of the magic numbers. Totally messed up the
output... until I found and fixed the bug.
Date: 20 Nov 2007 06:44:24
Message: <4742c898$1@news.povray.org>
Random fact:
2^(-128) ~= 2.93 * 10^(-39)
Winning the National Lottery (assuming you only bought 1 ticket) has a
probability of roughly 7.15 * 10^(-8).
If my arithmetic is right, that means that winning the National Lottery
jackpot 5 times back-to-back is still more than 637 times *more* likely
than something with a probability of 2^(-128) happening.
Assuming the probability of a random file mutation leaving the MD5 hash
unchanged really *is* 2^(-128), it's a pretty unlikely event. You should
probably worry more about the building being burned to the ground...
Date: 20 Nov 2007 07:07:47
Message: <4742ce13$1@news.povray.org>
> Random fact:
If you are only worried about one file per week and you don't backup off
site, then sure...
Date: 20 Nov 2007 13:34:54
Message: <474328ce$1@news.povray.org>
>> Random fact:
>> Lottery jackpot 5 times back-to-back is still more than 637 times
>> *more* likely than something with a probability of 2^(-128) happening.
>> hash unchanged really *is* 2^(-128), it's a pretty unlikely event. You
>> should probably worry more about the building being burned to the
>> ground...
> site, then sure...
1. We backup off-site, but - absurdly enough, when you think about it -
we don't *archive* anything off-site. So when a project is finished, it
gets put into a pair of CDs, deleted from the servers, and stored in our
own building. So actually, our "current" projects are protected better
than the finished ones... Hmm, actually, we should probably fix that! ._.
2. Let's look at the rules of probability:
Pr(A and B) = Pr(A) * Pr(A)
Pr(A or  B) = Pr(A) + Pr(B)
[Subject to various assumptions.] In particular, we have
   Pr(A and B) < Pr(A)
   Pr(A or  B) > Pr(A)
So ANDs decrease the probability, and ORs increase it. Thus, the
probability of winning the Lottery today AND next week AND the week
after AND... becomes quite small. However, the probability of file A
being corrupt OR file B being corrupt OR... increases as we add more
files. BUT NOT AS FAST!
If the probability of a single file being corrupted but not detected by
MD5 is 2.93 * 10^(-39) then the probability of any single file out of
1,000 files being so-corrupted is... 2.93 * 10^(-36). Which is still
pretty tiny. (It's about 2x more likely than 5 wins on the Lottery -
which is astronomically unlikely in the first place.)
With 1 million files per month, we get 2.96 * 10^(-33) as the
probability of one of them getting corrupted but us not noticing. That's
nearer to 4 consecutive Lottery wins... I don't think I'll worry too
much. ;-)
Date: 22 Nov 2007 06:09:19
Message: <slrnfkaoqv.88l.bisqwit@bisqwit.iki.fi>
error("This feature is only available in the registered version.");
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 22 Nov 2007 06:51:07
Message: <47456d2b@news.povray.org>
Joel wins.
