POV-Ray : Newsgroups : povray.off-topic : Today's random thought Server Time
3 Nov 2026 18:32:20 EST (-0500)
  Today's random thought (Message 1 to 29 of 29)
Subject: Today's random thought
Date: 12 Nov 2007 11:30:44
Message: <47387fb4$1@news.povray.org>
Suppose that every atom in the known universe had a unique serial
number. Suppose I picked a serial number at random, and then asked you
to go find out where that particular atom is. (Let us assume that there
is no particular correspondence between serial numbers and position in
space.)
Well your first problem is going to be that if I pick a random serial
number, that atom is probably many billions of light years away from
Earth, and so even if you knew where to go, you couldn't possibly go
there. But suppose you somehow have access to an electronic database of
all the atoms, their serial numbers, positions, and other interesting data.
(We casually ignore for the moment the minor detail that a database
describing the known universe would obviously be very much larger than
the actual universe itself, and hence could not possibly exist inside it...)
Given such a database, there are two ways you could try to find this atom.
One is to simply go through the database table, one row at a time. This
is equivilent to examining every atom in the universe, one by one, until
you find the one you want.
Assuming that you could somehow examine several million million million
records per second (highly implausible), to find the atom you're looking
for would take... several tens of billions of times the current age of
the universe. As in, after all the energy in the universe had been spent
and the entire cosmos had died an icy death of silent stillness at zero
entropy, your hypothetical computer would still have not made 1%
progress yet.
Just stop and think about that for a moment. There literally isn't
enough time in the universe to perform this search. Woah.
(But hey, you're searching all the atoms in existence! It's hardly
surprising...)
Alternatively, you could perform an index lookup. Assuming you have an
index on the main table that consists of a tree with 10 entries in each
node, you could find the atom in question after examining... 100 nodes.
(If we assume the tree is well-balanced.) Even if we type in the index
node requests by hand, it will take well less than 10 minutes to find
out atom.
So, one way has O(n) complexity, and would take so long that there
simply isn't enough time or energy in the universe to complete the
computation. The other way is O(log n), and would take less than 10
minutes even if done partially by hand.
Wow. Just... wow.
Subject: Re: Today's random thought
Date: 12 Nov 2007 12:16:40
Message: <47388a78@news.povray.org>
  It's enough for the values to be sorted. Then you can simply perform
a binary search. Assuming fast random access the search should take
much less than a second.
Date: 12 Nov 2007 12:35:00
Message: <web.47388e6c48c69ad773c9a3e0@news.povray.org>
Asimov solved this long ago!
http://www.multivax.com/last_question.html
> the universe.
BTW, what if when you finally reach the area the atom was at originally it
already moved on to an area you had already inspected?  concurrency problems?
Date: 12 Nov 2007 12:40:00
Message: <web.47388f0748c69ade8ba46670@news.povray.org>
Today, the number of atoms of the observable universe is estimated at about
10^80. (See http://en.wikipedia.org/wiki/Observable_universe).
Whish it were my bank account! But presently only the absolute value is correct
Message: <web.47388f4648c69ade8ba46670@news.povray.org>
Date: 12 Nov 2007 13:04:29
Message: <473896B8.40600@hotmail.com>
> space.)
I don't want to spoil your gedanken experiment, but in modern physics
you can not distinguish one (e.g.) hydrogen atom from another. It is not
that they are two different objects that are not marked so you can not
distinguish them, but much more fundamental. If you exchange two protons
nothing happens. There is no way to figure that out, because there is
absolutely no difference. You probably better say that this one proton
is at all these places at the same time.
Perhaps you know the interpretation that a positron is just an electron
flying backwards in time. It has been suggested that if the universe
ends in a big crunch (probably not) then you only need one electron
weaving forwards and backward in time. i.e. if an electron and a
positron annihilate, what actually happens is that the electron changes
direction again. So probably not true, but a funny image anyway.
Date: 12 Nov 2007 13:21:18
Message: <4738999e@news.povray.org>
You say this, but it's not actually true.  You cannot distinguish two
hydrogen atoms as long as you ignore the stuff that lets you distinguish
them.  Like, say, their positions.
Certainly the hydrogen atoms in my coffee are distinguishable from the
hydrogen atoms emitting light eight minutes ago in the sun.
Basically, science has a list of "things it's safe to ignore when
replicating an experiment."  Given that list, hydrogen atoms are
indistinguishable. But there's still a list.
It's like saying "pennies are indistinguishable, from a spending point
of view. I can replace one penny with any other penny."  Yet I'll still
get arrested for putting all your pennies in my bank account.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 12 Nov 2007 13:23:39
Message: <47389a2b$1@news.povray.org>
Indeed. A binary index lookup and a binary search are equally efficient.
However, inserting a record for a new atom becomes somewhat
compute-intensive if we have to keep all the data in sorted order. (If
it's a typical array-like structure, O(n) complexity again. For an
index, it's just O(log n) - assuming any rebalancing you choose to do
doesn't blow it up.)
Of course, whether you have an unordered table and seperate index or
whether the index *is* the table doesn't matter too much. (Depending on
just how much data you store per atom...)
Date: 12 Nov 2007 13:39:06
Message: <47389dca$1@news.povray.org>
Actually, the real problem would be that electronic representation of the
atomic data would require atoms for storage purposes....So you'd have to
have the database operating outside the space/time continuum to begin
with. :-)
Jim
Date: 12 Nov 2007 13:43:00
Message: <47389eb4$1@news.povray.org>
>> there is no particular correspondence between serial numbers and
>> position in space.)
Sure. You're probably right. And anyway, how the heck would you write
serial numbers on them, even if you could? More to the point, how would
you catelogue them all in a giant database? And what if they move
around? What if an atom is created or destroyed? etc.
My point is really just the staggering difference between complexity
classes, rather than physical correctness. The same argument would apply
to *anything* that there's 10^100 of - atoms in the universe is about
the only [remotely] comprehensible way to describe just what a big
number that is. ;-)
Date: 12 Nov 2007 13:56:15
Message: <4738a1cf$1@news.povray.org>
Oh yeah.
I think your "database" would have to be at a specific point in time -
which leads us nicely to the fact that time is not universal...
Date: 12 Nov 2007 14:05:33
Message: <4738a3fd$1@news.povray.org>
> with. :-)
Yes, I believe I meantioned that one. ;-)
Other obvious problems include the clear impossibility of obtaining this
data in the first place (uncertainty, anyone?), the subjective nature of
both time and space, and the sheer craziness of the idea in the first
place...
Date: 12 Nov 2007 14:46:01
Message: <4738AE84.404@hotmail.com>
no.
nope
Sorry, no. It may sound counterintuitive but there isn't. A proton does
not have a position, but a peaked distribution in one place with a small
but finite change that it is somewhere else entirely. If you have two
protons, you have a distribution with two peaks with an amplitude large
enough for two protons. Nothing more and individuality is a meaningless
concept here. I am trying to find a macroscopic equivalent, but I can't,
yet.
There is a difference between the (sub)atomic and the macroscopic range.
In the latter common sense is just that, in the former not.
> Yet I'll still
No as long as we assume that you exchanged all your pennies with mine
simultaneously, I don't see why anyone would bother. ;)
Don't try this at home though, the number of pennies in this house will
probably not exceed 2, mainly because we use a different currency.
Date: 12 Nov 2007 15:34:56
Message: <4738b8f0$1@news.povray.org>
>> the atomic data would require atoms for storage purposes....So you'd
>> have to have the database operating outside the space/time continuum to
>> begin with. :-)
Ah, yes, so you did. ;-)
> place...
Heisenberg would be proud. :-)
Jim
Date: 12 Nov 2007 22:15:35
Message: <473916d7@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/12 13:23:
If you have a sorted list of serial numbers, the next item will have it's number
set as n+1, or 1 after the current last element.
In the case of a balanced tree structure, concidering a tree with about 10^80
elements, randomly adding a few billions elements is prety much insignifient.
At the feast of ego everyone leaves hungry.
	Bentley's House of Coffee and Tea, Tucson, AZ
Date: 12 Nov 2007 22:20:05
Message: <473917e5$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2007/11/12 12:33:
>> the universe.
The data will, of course, include the precise speed and direction of every
atoms, along with it's mass, magnetic momentum and spin, and how it can interact
with other atoms and any photons. With that information, you can predict where
it will be at any time of your choosing within a Km radius.
Lutheran: If shit happens, don't talk about it.
Date: 12 Nov 2007 22:45:53
Message: <47391df1$1@news.povray.org>
	Have to agree with andrel here.
	Nope. Just that the wavefunction will be such that most likely that if
we ignore that there is another H atom near the sun, the physics near
your coffee will barely change.
Give a man a fish and you feed him for one day. Teach him to use the Net
and he won't bother you for weeks.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 12 Nov 2007 23:52:50
Message: <47392da2$1@news.povray.org>
> every atoms, along with it's mass, magnetic momentum and spin, and how
> it can interact with other atoms and any photons. With that information,
> you can predict where it will be at any time of your choosing within a
> Km radius.
You're joking, right? :-)
Date: 12 Nov 2007 23:54:14
Message: <47392df6$1@news.povray.org>
>> distinguish them.  Like, say, their positions.
Hmmmmm.... OK.  I can see that.  How does space-like separation affect
that, tho?
Date: 13 Nov 2007 05:25:01
Message: <web.47397aa648c69adc4e49fa40@news.povray.org>
> > with. :-)
> place...
I don’t think the idea is crazy but the people that are answering you are. :)
Date: 13 Nov 2007 17:18:35
Message: <473A23C6.8020602@hotmail.com>
> that, tho?
space- like is from relativistic physics, the point we are discussing is
  quantum mechanics. As you know the two are incompatible. So, being a
formally trained physicist with a 20 year old education, I don't know. ;)
Date: 13 Nov 2007 18:03:50
Message: <473a2d56$1@news.povray.org>
> Km radius.
Which leads to the question: Is our universe the real one, or the one
modeled by this giant database existing outside of our perceived space-time?
Date: 13 Nov 2007 18:03:51
Message: <473a2d57$1@news.povray.org>
>> information, you can predict where it will be at any time of your
Why joke? We are already considering a giant computer outside of
space-time. Why not assume it has enough processing power to model all
of the physical forces that the universe requires?
Date: 13 Nov 2007 19:59:09
Message: <473a485d$1@news.povray.org>
Darren New nous apporta ses lumieres en ce 2007/11/12 23:52:
Not at all! If you could realy have all of that information for every atoms in
the univers, you could conceivably be able to predict when a star will apears,
how long it will live, how it will finish, if it will have planets and how many,
the exact description of every single one, if it will host any life, and if
inteligent life will apears. All that for a future star for whitch most of it's
constituant matter is still contained in several other stars. Star that will
only start to form in a billion years.
The joke is that: You can't have all of that information, and even if you could
have it, there is no way that you could possibly process it.
'I had to hit him -- he was starting to make sense.'
Date: 13 Nov 2007 20:00:06
Message: <473a4896$1@news.povray.org>
Sabrina Kilian nous apporta ses lumieres en ce 2007/11/13 18:03:
>> Km radius.
Very good question.
"If you see me running, try to keep up."
       ...Back of bomb technician's shirt
Date: 13 Nov 2007 21:35:29
Message: <473a5ef1$1@news.povray.org>
Permutation City, by Greg Egan.
Buy it, read it, love it. :-)
Date: 13 Nov 2007 21:36:03
Message: <473a5f13$1@news.povray.org>
andrel wrote:
> Darren New wrote:
>> Mueen Nawaz wrote:
>>>> two hydrogen atoms as long as you ignore the stuff that lets you
>> that, tho?
Heh. OK, fair enough.
And thank you. I think I've had that misconception for a while. Thanks
for clearing it up.
Date: 14 Nov 2007 03:01:07
Message: <473aab43@news.povray.org>
> atoms in the univers, you could conceivably be able to predict when a star
> will apears, how long it will live, how it will finish, if it will have
> planets and how many, the exact description of every single one, if it
> will host any life, and if inteligent life will apears. All that for a
> future star for whitch most of it's constituant matter is still contained
> in several other stars. Star that will only start to form in a billion
> years.
Could the machine also tell you exactly what happened in the past?
The key question is if it is possible to predict the exact behaviour of
every particle based on its current state.  Are there not some things that
exhibit truly random behaviour?
Date: 14 Nov 2007 12:25:04
Message: <473b2f70$1@news.povray.org>
scott nous apporta ses lumieres en ce 2007/11/14 03:01:
>> star will apears, how long it will live, how it will finish, if it
>> will have planets and how many, the exact description of every single
>> one, if it will host any life, and if inteligent life will apears. All
>> that for a future star for whitch most of it's constituant matter is
>> still contained in several other stars. Star that will only start to
Absolutely!
> that exhibit truly random behaviour?
Quantum fluctuations, with it's probability coud, is purely random. But, the
random range is prety tight, even if it extend almost to infinity.
Take any given electron at rest. You can know it's location within an amstrong
radius, and you have more than a 99.999999% chance to effectively find it within
that radius, BUT, there is a non-zero chance to find it at over 1 light-year away.
'Power corrupts. Absolute power is kind of neat, though.'
