POV-Ray : Newsgroups : povray.off-topic : Today's random thought Server Time
26 Mar 2026 10:58:19 EDT (-0400)
  Today's random thought (Message 1 to 10 of 29)
Subject: Today's random thought
Date: 12 Nov 2007 11:30:44
Message: <47387fb4$1@news.povray.org>
Suppose that every atom in the known universe had a unique serial
number. Suppose I picked a serial number at random, and then asked you
to go find out where that particular atom is. (Let us assume that there
is no particular correspondence between serial numbers and position in
space.)
Well your first problem is going to be that if I pick a random serial
number, that atom is probably many billions of light years away from
Earth, and so even if you knew where to go, you couldn't possibly go
there. But suppose you somehow have access to an electronic database of
all the atoms, their serial numbers, positions, and other interesting data.
(We casually ignore for the moment the minor detail that a database
describing the known universe would obviously be very much larger than
the actual universe itself, and hence could not possibly exist inside it...)
Given such a database, there are two ways you could try to find this atom.
One is to simply go through the database table, one row at a time. This
is equivilent to examining every atom in the universe, one by one, until
you find the one you want.
Assuming that you could somehow examine several million million million
records per second (highly implausible), to find the atom you're looking
for would take... several tens of billions of times the current age of
the universe. As in, after all the energy in the universe had been spent
and the entire cosmos had died an icy death of silent stillness at zero
entropy, your hypothetical computer would still have not made 1%
progress yet.
Just stop and think about that for a moment. There literally isn't
enough time in the universe to perform this search. Woah.
(But hey, you're searching all the atoms in existence! It's hardly
surprising...)
Alternatively, you could perform an index lookup. Assuming you have an
index on the main table that consists of a tree with 10 entries in each
node, you could find the atom in question after examining... 100 nodes.
(If we assume the tree is well-balanced.) Even if we type in the index
node requests by hand, it will take well less than 10 minutes to find
out atom.
So, one way has O(n) complexity, and would take so long that there
simply isn't enough time or energy in the universe to complete the
computation. The other way is O(log n), and would take less than 10
minutes even if done partially by hand.
Wow. Just... wow.
Subject: Re: Today's random thought
Date: 12 Nov 2007 12:16:40
Message: <47388a78@news.povray.org>
  It's enough for the values to be sorted. Then you can simply perform
a binary search. Assuming fast random access the search should take
much less than a second.
Date: 12 Nov 2007 12:35:00
Message: <web.47388e6c48c69ad773c9a3e0@news.povray.org>
Asimov solved this long ago!
http://www.multivax.com/last_question.html
> the universe.
BTW, what if when you finally reach the area the atom was at originally it
already moved on to an area you had already inspected?  concurrency problems?
Date: 12 Nov 2007 12:40:00
Message: <web.47388f0748c69ade8ba46670@news.povray.org>
Today, the number of atoms of the observable universe is estimated at about
10^80. (See http://en.wikipedia.org/wiki/Observable_universe).
Whish it were my bank account! But presently only the absolute value is correct
Message: <web.47388f4648c69ade8ba46670@news.povray.org>
Date: 12 Nov 2007 13:04:29
Message: <473896B8.40600@hotmail.com>
> space.)
I don't want to spoil your gedanken experiment, but in modern physics
you can not distinguish one (e.g.) hydrogen atom from another. It is not
that they are two different objects that are not marked so you can not
distinguish them, but much more fundamental. If you exchange two protons
nothing happens. There is no way to figure that out, because there is
absolutely no difference. You probably better say that this one proton
is at all these places at the same time.
Perhaps you know the interpretation that a positron is just an electron
flying backwards in time. It has been suggested that if the universe
ends in a big crunch (probably not) then you only need one electron
weaving forwards and backward in time. i.e. if an electron and a
positron annihilate, what actually happens is that the electron changes
direction again. So probably not true, but a funny image anyway.
Date: 12 Nov 2007 13:21:18
Message: <4738999e@news.povray.org>
You say this, but it's not actually true.  You cannot distinguish two
hydrogen atoms as long as you ignore the stuff that lets you distinguish
them.  Like, say, their positions.
Certainly the hydrogen atoms in my coffee are distinguishable from the
hydrogen atoms emitting light eight minutes ago in the sun.
Basically, science has a list of "things it's safe to ignore when
replicating an experiment."  Given that list, hydrogen atoms are
indistinguishable. But there's still a list.
It's like saying "pennies are indistinguishable, from a spending point
of view. I can replace one penny with any other penny."  Yet I'll still
get arrested for putting all your pennies in my bank account.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 12 Nov 2007 13:23:39
Message: <47389a2b$1@news.povray.org>
Indeed. A binary index lookup and a binary search are equally efficient.
However, inserting a record for a new atom becomes somewhat
compute-intensive if we have to keep all the data in sorted order. (If
it's a typical array-like structure, O(n) complexity again. For an
index, it's just O(log n) - assuming any rebalancing you choose to do
doesn't blow it up.)
Of course, whether you have an unordered table and seperate index or
whether the index *is* the table doesn't matter too much. (Depending on
just how much data you store per atom...)
Date: 12 Nov 2007 13:39:06
Message: <47389dca$1@news.povray.org>
Actually, the real problem would be that electronic representation of the
atomic data would require atoms for storage purposes....So you'd have to
have the database operating outside the space/time continuum to begin
with. :-)
Jim
Date: 12 Nov 2007 13:43:00
Message: <47389eb4$1@news.povray.org>
>> there is no particular correspondence between serial numbers and
>> position in space.)
Sure. You're probably right. And anyway, how the heck would you write
serial numbers on them, even if you could? More to the point, how would
you catelogue them all in a giant database? And what if they move
around? What if an atom is created or destroyed? etc.
My point is really just the staggering difference between complexity
classes, rather than physical correctness. The same argument would apply
to *anything* that there's 10^100 of - atoms in the universe is about
the only [remotely] comprehensible way to describe just what a big
number that is. ;-)
