POV-Ray : Newsgroups : povray.off-topic : Small CSS question Server Time
3 Nov 2026 19:26:55 EST (-0500)
  Small CSS question (Message 1 to 38 of 38)
Subject: Small CSS question
Date: 6 Nov 2007 10:59:11
Message: <47308f4f$1@news.povray.org>
I have the following HTML:
   <span>A<span>B<span>C</span>D</span>E</span>
I've set up some CSS to put borders round span elements. It's supposed
to display as follows:
   |A|B|C|D|E|
However, no matter what I do, it actually renders like this:
   |A|B|C|D|E|F|
Any idea how I fix this?
Subject: Re: Small CSS question
Date: 6 Nov 2007 11:24:31
Message: <4730953e@news.povray.org>
  'padding' is probably the keyword you are looking for.
Date: 6 Nov 2007 11:37:26
Message: <47309846$1@news.povray.org>
Yeah, I was expecting some combination of padding and/or margin to do
it. But I can't seem to get that to work...
Date: 6 Nov 2007 11:40:24
Message: <473098f8@news.povray.org>
>   |A|B|C|D|E|
>   |A|B|C|D|E|F|
I tried giving it both padding and margin, but didn't get what you
wanted. However, display:block did the trick. It makes the span behave
just like a div (and a div with display:inline would be identical to a
span). You need to give it explicit width though; the default is 100% of
the container block (the whole page in my test).
Date: 6 Nov 2007 11:42:05
Message: <4730995d$1@news.povray.org>
Scratch that; it doesn't match what you want (but gets close enough). It
doesn't get the B and D on the *sides* of the C block.
*tweaks more*
Date: 6 Nov 2007 11:47:23
Message: <47309a9b$1@news.povray.org>
>> of the container block (the whole page in my test).
> *tweaks more*
Yeah, I already discovered that one myself. ;-)
There's a couple of other settings that do more or less the same thing
too. (display:table, etc.) But none does what I actually want. :-(
Date: 6 Nov 2007 11:49:40
Message: <47309b24$1@news.povray.org>
And even if they did what you want, you may like to know display:table,
table-cell, table-row, etc; aren't supported by Microshaft Internet
Exploder.
Date: 6 Nov 2007 11:53:15
Message: <47309bfb@news.povray.org>
> *tweaks more*
Doesn't seem easy. You would need like three columns on each span: the
letter, the inner span, and the other letter.
I got close enough with floats:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
   <head>
     <style type="text/css">
     div.block {
       border: red 1px solid;
       padding: 5px;
       margin: 5px;
     div {
       float: left;
     </style>
   </head>
   <body>
     <div class="block">
       <div>A</div>
       <div class="block">
         <div>B</div>
         <div class="block">
           <div>C</div>
         </div>
         <div>D</div>
       </div>
       <div>E</div>
     </div>
   </body>
</html>
But I couldn't manage to get the letters vertically centered.
Date: 6 Nov 2007 11:58:45
Message: <47309d45$1@news.povray.org>
> Exploder.
...and I care because? ;-) ;-)
Date: 6 Nov 2007 12:05:38
Message: <47309ee2$1@news.povray.org>
>>> thing too. (display:table, etc.) But none does what I actually want. :-(
>> display:table, table-cell, table-row, etc; aren't supported by
>> Microshaft Internet Exploder.
I dunno, some weird people care. And people who make pages that
unfortunately *should* work for everybody. For example, an e-commerce
page that doesn't work on IE means less people wasting money^W^W buying
there.
But even then, it's always fun to have at least a feature or two that
require a correctly-working browser :) "If you have IE, you can still
buy but the site will look ugly; blame Microsoft for that."
Date: 6 Nov 2007 12:10:30
Message: <op.t1drbcl8c3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 15:59:06 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>    |A|B|C|D|E|
>    |A|B|C|D|E|F|
What's wrong with this?
<html>
<style>
span.outer {border: red 1px solid; padding: 20px;}
span.inner {border: red 1px solid; padding: 10px;}
span.centre {border: red 1px solid; padding: 0px;}
</style>
<span class="outer">A<span class="inner">B<span
class="centre">C</span>D</span>E</span>
</html>
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 6 Nov 2007 12:24:43
Message: <op.t1dry0xyc3xi7v@news.povray.org>
spake, saying:
>    |A|B|C|D|E|
>    |A|B|C|D|E|F|
<html>
<style>
</style>
</html>
Phil Cook
Date: 6 Nov 2007 13:21:39
Message: <4730b0b3$1@news.povray.org>
> <html>
> <style>
> </style>
> </html>
Apart from there being an echo in here, that only allows a fixed amount
of nesting. I want to allow arbitrary nesting.
(This is basically for printing out expressions containing insane
numbers of brackets. I want to use borders to help untangle the mess in
some kind of visually-sane way...)
Date: 6 Nov 2007 22:26:52
Message: <4731307c@news.povray.org>
Try making it using the table tools in google docs. THEN look at the HTML
they come up with.
Date: 6 Nov 2007 22:56:34
Message: <47313772$1@news.povray.org>
> they come up with.
Tables would be overkill and *wrong* for this.
http://www.hotdesign.com/seybold/
Date: 7 Nov 2007 04:06:29
Message: <op.t1ezimvmc3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 18:21:42 -0000, Orchid XP v7 <voi### [at] devnull>
did spake, saying:
>> <html>
>> <style>
>>  </style>
>> </html>
I saw spans used that you said produced a fixed height block, I saw divs
used with and without floats; I didn't see this suggestion.
> that only allows a fixed amount of nesting. I want to allow arbitrary
> nesting.
Which you didn't mention.
n
count the number of brackets and times by two then set the padding that
way so
(A(B(C)D)E) is 6 then replace every ( with a padding=n-(i*2) i++
<html>
<style>
span {border: red 1px solid;}
</style>
<span style="padding:6px">A
<span style="padding:4px">B
<span style="padding:2px">C
</span>
D</span>
E</span>
</html>
I'm sure you can get one of the languages you use to do something like
that.
Phil Cook
Date: 7 Nov 2007 04:36:18
Message: <47318712$1@news.povray.org>
> did spake, saying:
>> nesting.
Oh alright then. ;-)
>> in some kind of visually-sane way...)
> way so
> <html>
> <style>
> </style>
> </span>
> D</span>
> E</span>
> </html>
> that.
Well, that'll work... but surely there's some W3C compliant way of doing
this transparently without such low-level hacks?
(I still don't understand why having a large box inside doesn't cause
the containing box to enlarge itself...)
Date: 7 Nov 2007 05:22:24
Message: <op.t1e200osc3xi7v@news.povray.org>
And lo on Wed, 07 Nov 2007 09:36:17 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
<snip>
>> that.
This is a W3C compliant way - HTML+CSS, what's not compliant about it? The
only thing you can moan about is the use of style in a strict.
It does if you use a block rather then an inline element.
Phil Cook
Date: 7 Nov 2007 07:34:51
Message: <4731b0eb$1@news.povray.org>
> spake, saying:
>> doing this transparently without such low-level hacks?
> The only thing you can moan about is the use of style in a strict.
It just seems a pitty to have to litter the code with style information
that should be in a seperate stylesheet, that's all.
What I *could* do is this:
   style {padding: 1em;}
   style style {padding: 2em;}
   style style style {padding: 3em;}
   etc.
But that still seems a crying shame...
But then it adds unwanted linebreaks.
Date: 7 Nov 2007 09:16:00
Message: <op.t1fds5gmc3xi7v@news.povray.org>
And lo on Wed, 07 Nov 2007 12:34:50 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
>    etc.
Wrong way round. You could have a fixed css file containing the following
html {margin:20px;}
span {padding:20px;}
span span {padding:18px;}
span span span {padding:16px;}
Assuming ten levels max and you would at least have a fixed height for the
equation you're displaying
Yep life's a bitch.
Phil Cook
Date: 7 Nov 2007 10:53:58
Message: <4731df96@news.povray.org>
> spake, saying:
>>    etc.
> Wrong way round.
Gah. o_O
Date: 9 Nov 2007 03:16:44
Message: <slrnfj85rc.j3c.bisqwit@bisqwit.iki.fi>
Try MathML. It helps greatly at least if your formula contains divisions.
 <math xmlns="http://www.w3.org/1998/Math/MathML">
  <mrow>
   <mn>log</mn>
   <mo>(</mo>
     <mfrac>
     <mrow>
       <mn>sqrt</mn>
       <mo>(</mo>
       <mn>5</mn>
       <mo>)</mo>
     </mrow>
     <mrow>10</mrow>
     </mfrac>
   <mo>)</mo>
  </mrow>
 </math>
MathML can be embedded in XHTML, but you need to pass
the right Content-type header (xhtml+xml).
Joel Yliluoma - http://bisqwit.iki.fi/
: comprehension = 1 / (2 ^ precision)
Date: 9 Nov 2007 04:54:58
Message: <47342e72$1@news.povray.org>
>   <mrow>
>    <mn>log</mn>
>    <mo>(</mo>
>      <mfrac>
>      <mrow>
>        <mn>sqrt</mn>
>        <mo>(</mo>
>        <mn>5</mn>
>        <mo>)</mo>
>      </mrow>
>      <mrow>10</mrow>
>      </mfrac>
>    <mo>)</mo>
>   </mrow>
>  </math>
OK, let's see the MathML for the following expression:
S(S(KS)K)(S(S(KS)K)I)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I)))(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I))))
Care to tell me where one subexpression ends and the next one begins? ;-)
Date: 9 Nov 2007 09:20:19
Message: <op.t1i3d1rsc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 09:54:59 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> divisions.
>>   <mrow>
>>    <mn>log</mn>    <mo>(</mo>
>>      <mfrac>
>>      <mrow>
>>        <mn>sqrt</mn>
>>        <mo>(</mo>
>>        <mn>5</mn>
>>        <mo>)</mo>      </mrow>
>>      <mrow>10</mrow>
>>      </mfrac>
>>    <mo>)</mo>
>>   </mrow>
>>  </math>
Just for fun with spans
<html>
<style>
html {margin:20px;}
div {height:40px;}
span {padding:20px; border: red 1px solid;}
span span {padding:18px; border: orange 1px solid;}
span span span {padding:16px; border: yellow 1px solid;}
span span span span {padding:14px; border: green 1px solid;}
span span span span span {padding:12px; border: blue 1px solid;}
span span span span span span {padding:10px; border: red 1px dotted;}
span span span span span span span {padding:8px; border: orange 1px
dotted;}
span span span span span span span span {padding:6px; border: yellow 1px
dotted;}
span span span span span span span span span {padding:4px; border: green
1px dotted;}
span span span span span span span span span span {padding:2px; border:
blue 1px dotted;}
span span span span span span span span span span span {padding:0px;
border: black 1px dotted;}
</style>
<div>S(S(KS)K)(S(S(KS)K)I)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I)))(S(S(KS)K)(S
(S(KS)K)(S(S(KS)K)(S(S(KS)K)I))))</div>
<div>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</span
>I</span><span>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</sp
an>K</span><span>S<span>S<span>KS</span>K</span>I</span></span></span><s
pan>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</span>
<span>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</spa
n>I</span></span></span></span></div>
</html>
that's using a simple find replace on () for <span></span>
Phil Cook
Date: 9 Nov 2007 09:40:17
Message: <47347151$1@news.povray.org>
> spake, saying:
Looks good! (Although possibly the spacing is a little *too* generous.)
Certainly a lot easier to find subexpressions than in the raw text
above. Just a pitty it takes so many miles of CSS...
Date: 9 Nov 2007 09:46:02
Message: <op.t1i4jqugc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 14:40:17 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
Well it's allowing for 11 levels with enough of a gap so that lines don't
blend, but it's adjustable.
Well the CSS is fixed so just dump it into a separate file and all you'll
have is the spans
Phil Cook
Date: 9 Nov 2007 10:03:57
Message: <473476dd$1@news.povray.org>
> spake, saying:
> you'll have is the spans
True.
I'm wondering if I could do something weird with inheritance and
percentage units...
Date: 9 Nov 2007 10:09:04
Message: <47347810$1@news.povray.org>
Invisible escribió:
>> did spake, saying:
> True.
> percentage units...
All you need is server-side scripting. Count the parentheses levels and
generate the CSS with that many levels. But a pure CSS method would be nice.
Still, you should really use MathML. That's what it's made for...
Date: 9 Nov 2007 10:20:43
Message: <47347acb@news.povray.org>
> nice.
Nah; just generate a file with 20 levels of nesting. If there's more
than that, you won't be able to disentangle it visually anyway. (And
it's not like the program will crash; it'll just show less clean output.)
What, drawing pretty lines around bits of text?
Date: 9 Nov 2007 10:59:18
Message: <op.t1i7untmc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 15:08:59 -0000, Nicolas Alvarez
<nic### [at] gmailisthebestcom> did spake, saying:
> Invisible escribió:
>>> did spake, saying:
>>  True.
>> percentage units...
Which was my first suggestion :-)
But little use unless you can serve it as application/xhtm+xml whereas
html is always served as text/html without the need for a dedicated server
component.
Phil Cook
Date: 11 Nov 2007 17:46:33
Message: <47378649$1@news.povray.org>
Wonderful span! Glorious span! (span span span!)
Shut up! Shut up!
Could I have S(S(KS)K)(S(S(KS)K)I) without so much span in it?
EWWWW!
Seriously, I didn't know you could do that with CSS. Cool.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 12 Nov 2007 04:09:20
Message: <op.t1n81f14c3xi7v@news.povray.org>
And lo on Sun, 11 Nov 2007 22:46:33 -0000, Darren New <dne### [at] sanrrcom>
did spake, saying:
> Shut up! Shut up!
> EWWWW!
well you could replace all the span with inline div :-)
Heh I think it should be called MySpace code
Phil Cook
Date: 12 Nov 2007 04:33:18
Message: <47381dde@news.povray.org>
That's not even funny. Seriously. Have you *seen* MySpace? >_<
Date: 12 Nov 2007 05:41:17
Message: <op.t1odapdec3xi7v@news.povray.org>
And lo on Mon, 12 Nov 2007 09:33:17 -0000, Invisible <voi### [at] devnull> did
spake, saying:
Oh yeah. I wasn't suggesting the term as a compliment.
Phil Cook
Date: 12 Nov 2007 08:05:37
Message: <47384fa1$1@news.povray.org>
The only thing worse than the HTML on MySpace is the crud the actual
users add to it themselves.
(I especially liked the red writing on a pink background with a hail of
red hearts constantly raining down in the foreground...)
Date: 12 Nov 2007 12:11:08
Message: <op.t1ovcgkec3xi7v@news.povray.org>
And lo on Mon, 12 Nov 2007 13:05:36 -0000, Invisible <voi### [at] devnull> did
spake, saying:
I like the way MySapce<sic> don't enforce picture sizes then auto-expand
column widths.
Phil Cook
Date: 13 Nov 2007 04:25:54
Message: <47396da2$1@news.povray.org>
Also... is there a reason why every MySpace profile randomly plays 6
different MP3 files at you simultaneously as soon as you visit it?
Date: 13 Nov 2007 05:10:18
Message: <op.t1p6inl0c3xi7v@news.povray.org>
And lo on Tue, 13 Nov 2007 09:25:53 -0000, Invisible <voi### [at] devnull> did
spake, saying:
Yes, but the reason is only revealed once you've been illuminated into the
9th degree.
Phil Cook
