I'm just sitting here looking over the plans for our new building at
work. It looks roughly like a tangled maze of lines, encrusted with text.
Some of the text is in fact almost unreadable because it's so tiny. Even
when printed out, I can bearly read it. I had a look at the PDF file,
and it says the document dimensions are "23.39 x 33.11 inches". A quick
trip to Google tells me that's 594.106 x 840.994 mm. (Wow, that sounds
pretty big!) A quick check on Wikipedia tells me that's exactly A1. (!!)
So, where the plan says "1:50 scale", it's really "1:400" when printed
on A4 instead of A1.
The drawing contains a number of items of interesting text. For example,
this is "DWG NO 2222.173". It is described as "GROUND FLOOR PLAN, OFFICE
B SETTING OUT".
Also, next to the stairs, I found this:
OVERALL RISE OF STAIR 3825mm
EACH RISE: 165mm (x23)
EACH GOING: 250mm.
BALUSTRADE TO BE TOP FIXED.
DESIGN TO COMPLY WITH B.REGS
PART K & M.
I just love the way they quote the size of a flight of stairs in
millimeters! I mean, it rises 12 feet up, and we care about 25mm?
I have no idea what "BALUSTRADE" is. (Assuming I've even read it right
from the tiny writing on the printout.)
Similarly, ever head of "BRISE SOLEIL"? Because apparently this building
will have *lots* of those.
But most of all, it's just numbers. *Millions* of numbers. Almost every
line has a second line next to it with some numbers. Many of the corners
also have angles written on them. (The ones that aren't 90° anyway.) And
there are dashed lines *everywhere*.
(I just reliased... Every single doorway in the place has a unique ID
written on it. Wow.)
There are also all sorts of symbols that look like they probably mean
something to a building engineer. Means nothing to me though! Heh.
It's certainly interesting anyway...
Don't you mean "barely"?
I have noticed that you make a whole lots of spelling mistakes for being
a native speaker...
OTOH I have heard the rumor that Australians always write "than" when
they mean "then".
> a native speaker...
Yeah, well, I didn't learn to write until I was 11...
(And let's face it, English is a pretty illogical language to start with.)
I'm quite sure that if its heigh is wrong by 25mm there will be plenty
of people tripping. Now you don't want work accidents, do you ;-) ?
It's all French words :-) That said, Wikipedia can help:
http://en.wikipedia.org/wiki/Brise_soleil
http://en.wikipedia.org/wiki/Baluster (read the first paragraph and not
just the title)
Vincent
That's because people who build the stairs works with that order
of tolerance (mm).
Yep. That's easier to build something :-)
Maybe you should ask for simplified plans with only big dimension lines
(just L and W of each room). We often provide that kind of stuff.
That's pretty normal. The drawing is probably linked to some spreadsheet
saying how much doors of what type are needed.
Apart from broad room dimensions, ceiling heights and under-slab heights,
you probably shouldn't care for anything else.
Fabien (architect).
Sure, your building design company would last a long time if every flight of
stairs had a tolerance of +/- 25 mm... :-)
Yeh, just like a 2D drawing of a mechanical part, the plans are to enable
the builders to actually make the building. They need dimensions of every
part, material types, finishes etc. They don't want to have to keep phoning
up the designer and asking "errm, how thick do you want this wall?" and
stuff like that.
> enable the builders to actually make the building. They need dimensions
> of every part, material types, finishes etc. They don't want to have to
> keep phoning up the designer and asking "errm, how thick do you want
> this wall?" and stuff like that.
You wouldn't imagine how often they ask for informations that
are already on the plans...
Fabien.
> of tolerance (mm).
In my house I built my own set of stairs - you care about every mm (or
inch) because you have to divide it very accurately to get the right
step height that makes everything even - especially if you have an
inspector reviewing it.
If you have never built stairs, it is not as easy as one would think....
but then after building a set, it is. Kinda like computers ;-)
Tom
Hahahaha!
The interesting part is, every set of plans I see has a different
contractor's name on it. There are so many different contractors working
on this thing it's unreal!
> of tolerance (mm).
So... what the hell do you do if you build some stairs, and the sement
sinks by 0.4 mm while drying? (A perfectly likely outcome.) Then each
step might be 0.4 mm out...! No noes! o_O
>> every line has a second line next to it with some numbers.
Yeah, well, there are millions and millions of paper plans, but for some
reason it's very hard to get electronic ones. I've been asking for some
for months. The plans I've got cut off part of the building, but it'll
do. ;-)
Reminds me of the building meeting I heard about. Apparently the
interior designers were fussing over what kind of light switches to
have, and the building engineers couldn't give a fig and just want the
building to not burn down due to an electrical fire or something...
Apparently it was a very amusing meeting for spectators!
(Did you know - actually, YOU probably did - they have entire catelogues
of hundreds of different kinds of light switches. Brass ones. Steel
ones. Rubberised ones. Plastic ones with every possible surface finish.
Big ones, small ones, ones for visually-impared people. One switch per
panel. Two switches per panel. Rows of 8 or more... Jesus, we just want
lights! LOL.)
Interesting that the archive is shown has having falls 8x thicker than
everywhere else. And on the door it says [in tiny letters]
BD10
2no.
FD120SC
TO GIVE
4 HOURS
And next to one wall, it says [in slightly bigger letters]
CEILING CAVITY BARRIER
Presumably this is all related to fire prevention or something...
Also, next to my server room there's [yet another] dashed line labelled
CEILING CAVITY
[Hmm, is there a reason all writing must be upper case?]
Of course, the most fun thing about our building is that it isn't
rectangular - it features angles like 174° and so on. ;-)
I wonder if that's what "FD30SC" means? (Every door seems to have this
written next to it, in addition to a unique number of the form "DB7".)
> just the title)
Ah... So that useless bit that sticks out of the front of the building
is meant to be a sun shade?
[Interesting how all the buildings constructed so far have an identical
projection, despite facing different directions. I mean, surely the sun
can only rise from one direction... And sides, it's far too tiny to
shade anything except the top of the roof.]
FD = Framed Door ? (such conventions are hardly universal)
30 = maybe 30 minutes fireproof ? on the leaf is 30 inches wide ?
SC = Single C???... ?
Sometimes there's an explanation on the edge (along with the meaning of hatches).
Fabien.
for example, we name our doors like :
PSF-93-10
09F 2.20
(both symbols grouped in an hexagon)
which means :
Porte Simple Feu (Single door, fire resistant)
93 cm leaf in a 10 cm wall
the lower symbol is the room to which the door gives access
09 (underground, 00 is ground, 01 1st level...)
F : zone F (fire detection zone)
2.20 : hierarchic geographical numbering within a zone
> hatches).
Not this time there isn't.
It's probably a catelogue number, and if you had their catelogue you
could look it up.
(I recall apparently there was a long debate about whether the doors
would be stained wood, or whether they would be painted black. The
designers were concerned that wood would clash with the white walls and
black skirting boards. [I kid you not!] IIRC, they eventually decided on
stained wood doors with black door frames...)
> EACH GOING: 250mm.
> PART K & M.
Hey, I just noticed. The individual stairs are numbered. As in, from 1
to 23. Wow!
There's also a small barely-readable table that says
C ARCHIVE STORE / INST. ROOMS RESETOUT 01.10.07 SH DS
B DOOR REFS ADDED. DIMS UPDATED 28.08.07 SH DS
A ISSUED FOR COMMENT 15.08.07 SH DS
REV DESCRIPTION DATE DWN CKD
I notice that in the middle of the building there's a line of what look
like H-section girders. Each one has a dashed line going through it,
ending in a unique letter on the outside of the building.
(To give you some idea, the lines C, D, E and F are all parallel and
equidistant. However, F and G are *not* parallel. The exterior walls on
either side of the G line meet at an angle of 174° rather than 180°. In
particular, this means that the corridore to my office and my server
room has non-parallel walls. Let's hope I don't need to wheel anything
large through there!)
There's also lots of little enigmatic annotations such as
BELOW GROUND
DRANAGE CONNECTION
FOR WHB
and
STUB STACK
and
sinks/washers
see fittings
and
RWP
INTO
BG.
Ooo, I just found a small space that looks like this:
| 87° 94°|
| RISER |
| 90° |
Hahahah! Some poor **** is going to have great fun building THAT...
There's also lots of circles with numbers in them. Or bisected circles
with pairs of numbers in them.
I'm sure all this means something to the guys drawing the plans. ;-)
> | 87° 94°|
> | RISER |
> | 90° |
What the...
You should ask for 3D plans in .pov format. Or make them?
OMFG... POV-Ray FTW!! :-D
>> | 87° 94°|
>> | RISER |
>> | 90° |
> What the...
Should probably be more like:
+--..__
|87 ''--.._
| 94|
|90 |
...still not too fun to build.
Tim Cook
Version: 3.12
And lo on Tue, 06 Nov 2007 11:40:26 -0000, Invisible <voi### [at] dev null> did
spake, saying:
Taking into account that the software may have 'fixed' it to print within
your printer margins.
> B SETTING OUT".
> EACH GOING: 250mm.
> PART K & M.
Yes if you want it to be 12 feet up when it races the top.
It's that bit that stops you from falling off the side of the stairs.
Sun-shade.
Yup
Yup again
Looking at building plans is always fun.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
> spake, saying:
>> Even when printed out, I can bearly read it. I had a look at the PDF
>> file, and it says the document dimensions are "23.39 x 33.11 inches".
>> A quick trip to Google tells me that's 594.106 x 840.994 mm. (Wow,
>> that sounds pretty big!) A quick check on Wikipedia tells me that's
>> exactly A1. (!!)
> within your printer margins.
True...
Perhaps that's why part of the building is missing? Or maybe it's just
that this particular drawing only includes that part, I'm not sure.
I'm glad someone else thinks so.
I have no idea what half the stuff means, but I'm nosey anyway! ;-)
>>> | 87° 94°|
>>> | RISER |
>>> | 90° |
>> What the...
> +--..__
> |87 ''--.._
> | 94|
> |90 |
That's a tilt of a tad more than 4°, but essentially yes. ;-)
(On the paper it sure looks like a perfect square. But there we are.)
>> of tolerance (mm).
Who secures stairs in place by resting them on unset concrete? :-S
>>> of tolerance (mm).
I was thinking more that the *stairs* are made of concrete...
>>>> of tolerance (mm).
Oh you mean like one big pre-fab set of stairs? If they all shrunk 0.4mm
after they were taken out of the mold then the usual idea is to make the
mold 0.4mm bigger than needed...
Anyway, who's going to notice if the last step is 0.4mm less that the
others?
> others?
...which was why I was amused at the stairs having dimensions to the
nearest mm. ;-)
Seriously, if I take a tape measure to the finished building, do you
really think all the measurements will be exactly whole numbers of
millimeters? I somewhat doubt it. ;-)
"Orchid XP v7" <voi### [at] dev null> wrote in message
> nearest mm. ;-)
If you give builders plans to the nearest meters, you can none of the
dimensions will be accurate to the nearest meter either. Does it all make
sense now?
>> others?
> nearest mm. ;-)
No, but it's a typical value with some tolerance. On our drawings we always
have stuff that is labelled like 16.68 +/- 0.20 mm, if they made all the
parts with an average of 16.66 mm then some of them wouldn't fit together
properly.
>>> others?
>> nearest mm. ;-)
> always have stuff that is labelled like 16.68 +/- 0.20 mm, if they made
> all the parts with an average of 16.66 mm then some of them wouldn't fit
> together properly.
As I understand it, the stuff you make is somewhat smaller than a
building. ;-)
>> together properly.
> building. ;-)
Exactly the same principles though.
Imagine you have a rise of 3050mm that you want to meet with 10 steps, and
you can make each step with a tolerance of +/- 50 mm.
You might specify each step as 305 +/ 50 mm, which will give you a total
height of 3050 +/- 50 mm. Using your argument though, you would say the 305
is pointless and you may as well just say 300. That would make every
staircase 5cm out on average!
In buildings I would imagine that lots of distances add up, and if you don't
at least aim to make each one correct, then at some point something is not
going to fit.
Orchid XP v7 a écrit :
>>>> of tolerance (mm).
>>> sement sinks by 0.4 mm while drying? (A perfectly likely outcome.)
>>> Then each step might be 0.4 mm out...! No noes! o_O
Concrete stairs are usually build in a workshop, poured into
a plywood form, upside-down (so the walking surface is at
the bottom of the form, giving a mostly perfect look and
dimensioning to the visible parts).
Fabien.
Really? I assumed they made them on-site. (And that that was the
principle advantage of making stairs out of such an otherwise
unattractive material when numerious better alternatives exist.)
Oh well, you learn something every day. ;-)
(Did you know, Boron is what makes silly putty so weird?)
Did you mean 305 +/- 5mm?
Remember the good old days, when we
used to complain about cryptography
being export-restricted?
Oops yes, actually no, thinking a little more about it the correct one would
be 305 +/- 15.8. (tolerances like this are normal distributions, not
uniform...)
