POV-Ray : Newsgroups : povray.off-topic : Plans Server Time
10 Apr 2026 06:02:46 EDT (-0400)
  Plans (Message 1 to 10 of 35)
Subject: Plans
Date: 6 Nov 2007 06:40:27
Message: <473052ab$1@news.povray.org>
I'm just sitting here looking over the plans for our new building at
work. It looks roughly like a tangled maze of lines, encrusted with text.
Some of the text is in fact almost unreadable because it's so tiny. Even
when printed out, I can bearly read it. I had a look at the PDF file,
and it says the document dimensions are "23.39 x 33.11 inches". A quick
trip to Google tells me that's 594.106 x 840.994 mm. (Wow, that sounds
pretty big!) A quick check on Wikipedia tells me that's exactly A1. (!!)
So, where the plan says "1:50 scale", it's really "1:400" when printed
on A4 instead of A1.
The drawing contains a number of items of interesting text. For example,
this is "DWG NO 2222.173". It is described as "GROUND FLOOR PLAN, OFFICE
B SETTING OUT".
Also, next to the stairs, I found this:
   OVERALL RISE OF STAIR 3825mm
   EACH RISE: 165mm (x23)
   EACH GOING: 250mm.
   BALUSTRADE TO BE TOP FIXED.
   DESIGN TO COMPLY WITH B.REGS
   PART K & M.
I just love the way they quote the size of a flight of stairs in
millimeters! I mean, it rises 12 feet up, and we care about 25mm?
I have no idea what "BALUSTRADE" is. (Assuming I've even read it right
from the tiny writing on the printout.)
Similarly, ever head of "BRISE SOLEIL"? Because apparently this building
will have *lots* of those.
But most of all, it's just numbers. *Millions* of numbers. Almost every
line has a second line next to it with some numbers. Many of the corners
there are dashed lines *everywhere*.
(I just reliased... Every single doorway in the place has a unique ID
written on it. Wow.)
There are also all sorts of symbols that look like they probably mean
something to a building engineer. Means nothing to me though! Heh.
It's certainly interesting anyway...
Subject: Re: Plans
Date: 6 Nov 2007 07:12:32
Message: <47305a2f@news.povray.org>
  Don't you mean "barely"?
  I have noticed that you make a whole lots of spelling mistakes for being
a native speaker...
  OTOH I have heard the rumor that Australians always write "than" when
they mean "then".
Subject: Re: Plans
Date: 6 Nov 2007 07:15:58
Message: <47305afe$1@news.povray.org>
> a native speaker...
Yeah, well, I didn't learn to write until I was 11...
(And let's face it, English is a pretty illogical language to start with.)
Subject: Re: Plans
Date: 6 Nov 2007 07:28:51
Message: <47305e03@news.povray.org>
I'm quite sure that if its heigh is wrong by 25mm there will be plenty
of people tripping. Now you don't want work accidents, do you ;-) ?
It's all French words :-) That said, Wikipedia can help:
http://en.wikipedia.org/wiki/Brise_soleil
http://en.wikipedia.org/wiki/Baluster (read the first paragraph and not
just the title)
Vincent
Subject: Re: Plans
Date: 6 Nov 2007 08:10:45
Message: <473067d5$1@news.povray.org>
That's because people who build the stairs works with that order
of tolerance (mm).
Yep. That's easier to build something :-)
Maybe you should ask for simplified plans with only big dimension lines
(just L and W of each room). We often provide that kind of stuff.
That's pretty normal. The drawing is probably linked to some spreadsheet
saying how much doors of what type are needed.
Apart from broad room dimensions, ceiling heights and under-slab heights,
you probably shouldn't care for anything else.
Fabien (architect).
Subject: Re: Plans
Date: 6 Nov 2007 08:21:25
Message: <47306a55$1@news.povray.org>
Sure, your building design company would last a long time if every flight of
stairs had a tolerance of +/- 25 mm... :-)
Yeh, just like a 2D drawing of a mechanical part, the plans are to enable
the builders to actually make the building.  They need dimensions of every
part, material types, finishes etc.  They don't want to have to keep phoning
up the designer and asking "errm, how thick do you want this wall?" and
stuff like that.
Subject: Re: Plans
Date: 6 Nov 2007 08:32:10
Message: <47306cda$1@news.povray.org>
> enable the builders to actually make the building.  They need dimensions
> of every part, material types, finishes etc.  They don't want to have to
> keep phoning up the designer and asking "errm, how thick do you want
> this wall?" and stuff like that.
You wouldn't imagine how often they ask for informations that
are already on the plans...
Fabien.
Subject: Re: Plans
Date: 6 Nov 2007 08:34:19
Message: <47306d5b$1@news.povray.org>
> of tolerance (mm).
In my house I built my own set of stairs - you care about every mm (or
inch) because you have to divide it very accurately to get the right
step height that makes everything even - especially if you have an
inspector reviewing it.
If you have never built stairs, it is not as easy as one would think....
  but then after building a set, it is.  Kinda like computers ;-)
Tom
Subject: Re: Plans
Date: 6 Nov 2007 09:20:48
Message: <47307840$1@news.povray.org>
Hahahaha!
The interesting part is, every set of plans I see has a different
contractor's name on it. There are so many different contractors working
on this thing it's unreal!
Subject: Re: Plans
Date: 6 Nov 2007 09:30:23
Message: <47307a7f$1@news.povray.org>
> of tolerance (mm).
So... what the hell do you do if you build some stairs, and the sement
sinks by 0.4 mm while drying? (A perfectly likely outcome.) Then each
step might be 0.4 mm out...! No noes! o_O
>> every line has a second line next to it with some numbers.
Yeah, well, there are millions and millions of paper plans, but for some
reason it's very hard to get electronic ones. I've been asking for some
for months. The plans I've got cut off part of the building, but it'll
do. ;-)
Reminds me of the building meeting I heard about. Apparently the
interior designers were fussing over what kind of light switches to
have, and the building engineers couldn't give a fig and just want the
building to not burn down due to an electrical fire or something...
Apparently it was a very amusing meeting for spectators!
(Did you know - actually, YOU probably did - they have entire catelogues
of hundreds of different kinds of light switches. Brass ones. Steel
ones. Rubberised ones. Plastic ones with every possible surface finish.
Big ones, small ones, ones for visually-impared people. One switch per
panel. Two switches per panel. Rows of 8 or more... Jesus, we just want
lights! LOL.)
Interesting that the archive is shown has having falls 8x thicker than
everywhere else. And on the door it says [in tiny letters]
   BD10
   2no.
   FD120SC
   TO GIVE
   4 HOURS
And next to one wall, it says [in slightly bigger letters]
   CEILING CAVITY BARRIER
Presumably this is all related to fire prevention or something...
Also, next to my server room there's [yet another] dashed line labelled
   CEILING CAVITY
[Hmm, is there a reason all writing must be upper case?]
Of course, the most fun thing about our building is that it isn't
