At the weekend, I downloaded and tried out every demo nVidia have ever
made. (Well, except for the first one, which wouldn't download. And the
last few, which require a GeForce 8 series.)
The first one was literally a crystal ball. In other words, they were
showing off using environment mapping to simulate reflection. Hmm. Oh
well, it does say "Requires GeForce 2 or better"...
Anyway, actually most of the demos were pretty unimpressive. I mean, I'm
sure they're technically quite advanced. But not much fun to look at.
It wasn't until I reached "Dawn" that I was impressed. That's one pretty
impressive fairy. (Um... and the reason she's wearing almost nothing
is...? Hmm, I wonder who their target demographic is? *wink*) Her sister
"Dusk" is impressive too.
And then we have "Nalu", the mermaid. Fairly technically-impressive, if
a little uninteresting. (She doesn't really "do" much.) Being
underwater, the skin tones don't seem quite so "wow!", if you see what I
mean.
Well anyway, the thing that really blew me away was "Luna and the
Occular Oracle". I mean... woah. 0_0 Watch it and you'll see what I
mean. Graphically it's fairly impressive stuff. But scenematically...
Seriously, WHAT THE HELL where these guys smoking when they came up with
this stuff?? It's like a far-out acid trip or something... wow. Just
wow. Oh, yeah, and the graphics are fairly impressive. But that's not
what I was most looking at... heh.
Oh, and now half the demos won't uninstall cleanly. But then, a few of
them wouldn't run properly in the first place. In general, all the demos
seemed pretty buggy. Hmm... great advert!
Oh yeah, and "Smoke". Simple little demo, but I have *no clue* how it
manages to do that in realtime...
Do these demos work in ATI cards, or do they have special code which
checks the type of card you have and refuses to run if you don't have
an nvidia one?-)
> this stuff?? It's like a far-out acid trip or something... wow. Just wow.
> Oh, yeah, and the graphics are fairly impressive. But that's not what I
Nice, but you need to have a look at demos not made by companies.
For a real far-out acid trip (and the best demo I've ever seen) have a look
at the Assembly 2007 winner "Lifeforce":
http://www.pouet.net/prod.php?which=31571
Rune
Warp nous apporta ses lumieres en ce 2007/10/29 16:10:
> an nvidia one?-)
They will probably install and run, but also, probably, with deliberately
cripled performances.
A dirty trick by those making the demos (independent from where they come from):
Let install on the concurent maker's card, but disable some features and replace
others with some DEoptimised versions that deliberately run slower.
To get the real results, you need to use demos and benchmarks by independant
devlopers, and hope that your drivers don't have special codes that lowers the
settings like resolution, polygon count and colour depth, to artificialy make
the benchmark run faster. nVidia DID use that dirty trick, and there is no proof
that ATI used it or not at this time.
WARNING: The consumption of alcohol may cause pregnancy.
You mean that nvidia deliberately put some code in their display driver
that detected that you are running, for example, 3DMark, and if so it has
a special code which converts the triangle meshes given by 3DMark to the
driver to ones with less polygons so that the graphics card will appear
to run faster than it really would?
I suppose there's no way for a program to detect such trickery...
Yep! And you wonder why video drivers under Windows crash the system so
often.
They also tend to do stuff like notice they're being tested by microsoft
for approval and stop skipping steps they don't think they "really"
need, but which they normally skip in order to get better performance at
the expense of correct results.
I've seen it done with other programs, too, like C compilers noticing
they're compiling SPECmark suites and such.
Remember the good old days, when we
used to complain about cryptography
being export-restricted?
> often.
And this isn't illegal? Doesn't it fall into something like
http://en.wikipedia.org/wiki/False_advertising
I suppose the law will always be behind technology.
Depends what you advertise, I suppose. "Passed the WHDL tests" is
correct, after all. :-)
But yah, I guess if you really wanted to sue someone, you'd have a case.
You might not win, but you'd have a case.
It's a complicated matter. Systems tailoring their behaviour to running
applications can have a perfectly valid reason. Sometimes, OS's and drivers
will do that to enable older applications that used, let's say,
unconventional or undocumented behaviour, to keep functioning. MS goes to
great lengths to accomodate badly written applications to maintain backwards
compatibility. Graphics card drivers work closely with major games and CAD
application vendors to maximize their performance, which benefits both
parties. So, a driver reconfiguring itself to maximize performance of CATIA
is not much different than a driver doing the same for 3DMark. Why should a
graphics driver optimized for many such applications let itself be
underspec'd through a synthetic benchmark, if it can help it?
Performing application-specific optimizations which result in the exact
same images being produced faster is completely different from producing
images of lower quality faster.
You'd agree that if the driver detects that 3DMark is being run and
then just presents a black screen and gives a score of 10000 frames per
second, that's not an acceptable result. The speed is staggering, but
obviously unacceptable because the visual result is not acceptable.
Why would the driver artificially reducing the number of polygons (thus
resulting in a poorer-quality image) just to get a higher benchmark score
be any more acceptable than the black-screen extreme example?
Or think about it like this: Imagine that a benchmark tests how fast
the graphics card can render using 4x antialiasing. The driver detects
this and artificially turns on 2x antialiasing instead, in order to score
better. This is obviously unacceptable.
Warp nous apporta ses lumieres en ce 2007/10/29 19:16:
What it does is reset the benchmark parameters to some lower ones when the
actual benchmark starts, then set them back to the selected values on exit.
Result: you get a display that say that you used parameter set X, but the test
was performed with parameters X/2.
Things that where done:
- changing the colour depth from 32 to 16 bits.
- changing the detail level from "High" to "Medium" or even "Low".
- turning fog off.
- reducing the Z-buffer depth.
- reducing the particles count.
- turning antialiasing off.
- reducing textures quality from "High" to "Medium", "Normal" or "Low".
- turning 3linear interpolation off.
- reduce the lights number.
...and some others...
You mention 3DMark, and it's exactly the first they targetted. They got caught.
They got sued, and LOST. 3DMark coutered by using name randomization of the
programm and all of it's components, folders and registry entries. Then every
other benchmarks makers followed. Net result: nVidia's results droped, sometimes
by an order of magnitude, around 10 to 30 times slower in some cases!
Think about boasting a 240+ FPS in a mark, then seeing that drop to around 12~17
FPS after your hack got negated!
WARNING: The consumption of alcohol may make you think you are whispering when
you are not.
> come from):
> replace
Yeah, that wouldn't surprise me.
> independant
> lowers the
> make
> no proof
Um... lower the polygon count? That sounds like a *highly* nontrivial
task. Arguably more work than actually rendering all the polygons. :-P
Not if the driver has code specifically designed for the specific
triangle mesh the benchmark program send it. It can simply have some
kind of lookup table or something which substitutes some of the triangles
with other (fewer) triangles.
...hmm, so *that* is why the nVidia video driver is over 200 MB...
(Seriously, are you NUTS?! Most drivers are about 20 KB.)
> often.
Uh... do they?
You can fit quite a lot of things into 20 kB. Just take a look at
some good 4 kB demos.
Orchid XP v7 wrote:
>> so often.
> Uh... do they?
Well, relatively often, yes, compared to most other stuff.
Darren New wrote:
> Orchid XP v7 wrote:
>>> so often.
>> Uh... do they?
Not a phenominon I've ever experienced, but anyway...
I'll bet you can. Games programmers used to do it back when computers
only had that much RAM...
Although I'd think lower resolution polygon meshes for 27 different
games and benchmarks does not belong to "the set of all things that can
fit into 20 KB". ;-)
It doesn't need to store the lower resolution meshes. It just needs to
store the logic to do reverse-subdivision of the meshes.
On Wed, 31 Oct 2007 20:58:11 +0000, Orchid XP v7 wrote:
> Darren New wrote:
>> Orchid XP v7 wrote:
>>>> so often.
>>> Uh... do they?
In one set of equipment we used to deliver courses on, we had Dell C610
laptops and Dell C640 laptops. Video cards were identical in the
systems, according to the specs (same chipset, same amount of memory,
same everything). For non-Windows OSes, they worked just great - you
could use an image developed on a 610 on a 640 and vice version.
For Windows, you had to install a *different* video driver, even though
the card was identical - even at the BIOS and firmware level (I checked
everything I could to find out what was different).
Yet consistently, if you used the 610's driver on the 640 (or vice-
versa), the video came up 16-colour 640x480 VGA, refused to change, and
left alone long enough, the driver would apparently eat itself and blow
the machine up - to the point a reimage was often needed.
One of the more bizzare problems I ever saw. A Dell IT technician in one
of my classes couldn't even tell me why the driver was different or why
it didn't do what it was supposed to do (ie, work).
Jim
Orchid XP v7 nous apporta ses lumieres en ce 2007/10/30 16:41:
>> come from):
>> and replace
>> independant
>> lowers the
>> artificialy make
>> is no proof
Not at all! The benchmark programm already have several quality levels,
including various mesh resolutions.
What you do, is to dynamicaly reset the relevant parameter of the benchmark to a
lower setting after the user have set it and hit the StartBenchmark button, but
before the benchmark have realy begun. Then, after the benchmark have finished,
you set it back to the user selected value.
The net result: artificialy inflated FPS count!
You know you've been raytracing too long when you have ever brought your
computer to its knees by mistakenly launching 64 simultaneous frames to be
traced, while trying to maximizing the benefits of parallelizing them.
Carsten Whimster
Orchid XP v7 nous apporta ses lumieres en ce 2007/10/30 17:58:
ONLY 20Kb??? I only once had video drivers under 500Kb! This was under Win 3.1
for an old PCI Trident VGA adaptor, the only and last drivers I ever got that
fit on a single floppy. The Win 95 drivers for that same card needed 2 floppys.
My current ATI drivers installation package is about 14.5 Mb.
Just take a look on both nVidia and ATI web sites, drivers downloads section.
As the shepherd said: If in doubt get the flock out!
Orchid XP v7 nous apporta ses lumieres en ce 2007/10/31 16:59:
WHO said that you need to store the alternate meshes? You don't need to do that
when the benchmark already contain the lower resolution meshes.
Benchmarks, and several games, often offer several mesh quality. You only need
to intercept or change the reference that is used to point to the lower
resolution mesh that is already provided.
One of the ways that the cheats where discovered was by running the benchmarks
at the two lowest settings available and realise that they return exactly the
SAME results: The second lowest get degraded to the lowest setting, but the
lowest settings CAN'T be lowered to anything lower! But, almost nobody ever try
those low settings.
You know you've been raytracing too long when someone shows you a photograph of
their new rough-slate kitchen floor and you say "nice normals".
-- Tom Melly
That would be Warp. ;-)
> You don't need to
> do that when the benchmark already contain the lower resolution meshes.
> only need to intercept or change the reference that is used to point to
> the lower resolution mesh that is already provided.
Mmm. Devious...
> benchmarks at the two lowest settings available and realise that they
> return exactly the SAME results: The second lowest get degraded to the
> lowest setting, but the lowest settings CAN'T be lowered to anything
> lower! But, almost nobody ever try those low settings.
...or it could simply indicate that the bottleneck isn't the GPU?
(I've seen a huge number of SLI benchmarks where the SLI mode is
*slower* than a single GPU, except at absurd resolution settings.)
...and as *I* said originally, "wouldn't that be drastically more work
than just rendering the high resolution mesh?"
Mesh subdivision being an extremely hard problem, and all that...
No, I only mentioned lookup tables as being a solution to reducing the
size of known meshes fast.
Ah, OK. I misunderstood then...
Using the GPU... the GPU is good for doing that sort of thing.
Even car manufacturers get on this too. The ECU detects when the car is
being subject to the standard emissions and economy tests (to provide the
official figures for fuel consumption and CO2 emmissions) and then
deliberately runs in some special state to get better results.
You only need to do it once though, not every frame.
Not hard at all (just creating new vertices with weighted proportions of
neighbours), nor is un-subdividing (just checking pairs of triangles that
are almost planar to be combined).
I'm still mystified (get it?) as to how it manages to render with
absolutely no visible grain of any kind to it. Even POV-Ray struggles to
do that given many *days* of rendering time...
Clearly some kind of trick must be involved.
Not really, just utilising the GPU's ability to handle 3D textures and
smooth blending really efficiently. Don't forget the GPU version is not
scattering light like POV does...
This links shows some details about a DX10 smoke simulation, I expect a DX9
version uses a similar method (probably just not as efficient).
http://developer.download.nvidia.com/presentations/2007/gdc/RealTimeFluids.pdf
>> to do that given many *days* of rendering time...
...GPUs can do 3D texturing now?
Orchid XP v7 nous apporta ses lumieres en ce 2007/11/04 12:49:
>> not scattering light like POV does...
Yes, and it's not even a new possibility! My old, totaly obsolete, and presently
unused, PCI Matrox Mystic was able to do some elementary 3D texturing, just not
to the same extent as todays cards and at a much lower resolution. It could'nt
do smooth blending or shading.
A modest man is usually admired; if people ever hear of him.
> presently unused, PCI Matrox Mystic was able to do some elementary 3D
> texturing, just not to the same extent as todays cards and at a much
> lower resolution. It could'nt do smooth blending or shading.
Oh, well... In that case, it's "merely" a matter of computing the gas
physics [to sufficiently believable precision]. That's a much easier task...
They're just a set of 2D textures, fairly simple to implement even if you
card doesn't specifically support 3D textures.
The hard-ish bit is how to render them, but again you can just write some
ray-casting code into a pixel-shader that runs in real-time (as I think that
link I posted explains).
