POV-Ray : Newsgroups : povray.off-topic : All that Windoze stuff Server Time
3 Nov 2026 19:30:21 EST (-0500)
  All that Windoze stuff (Message 1 to 25 of 25)
Subject: All that Windoze stuff
Date: 29 Oct 2007 13:48:25
Message: <47262af9$1@news.povray.org>
I spent an afternoon reading about DDE, COM, COM+, DCOM, OLE, DCE/RPC,
MSRPC and many other things that I can't even remember the name of now.
All of which make virtually no sense at all.
Can somebody explain to me what all this stuff is meant to be for?
Subject: Re: All that Windoze stuff
Date: 29 Oct 2007 14:53:43
Message: <47263a47$1@news.povray.org>
IPC.  HTH.  HAND. :-)
Jim
Date: 29 Oct 2007 15:01:13
Message: <47263c09$1@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:47263a47$1@news.povray.org...
>> DCE/RPC,
>> of now.
>> for?
> IPC.  HTH.  HAND. :-)
> Jim
P.s.  mutex trafficking
Date: 29 Oct 2007 15:15:17
Message: <47263f55$1@news.povray.org>
Cross-process object-oriented calling.  Basically, remote procedure
calls and everything you need to do it "right" instead of half-assed.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 29 Oct 2007 16:10:52
Message: <47264c5c$1@news.povray.org>
OK. So... if I actually knew how to do all this stuff, what useful
things could I do with it?
Date: 29 Oct 2007 16:43:34
Message: <47265406@news.povray.org>
It's the fundamental technology that Windows parts use to talk to other
Windows parts. You could write a program that starts up Word and Excel,
loads a spreadsheet, clips a range out and pastes it into your Word
document. You can take a blob of code that someone wrote to manage
calendars, and a blob of code that someone wrote to manage email, and
paste them together to make an email-sending reminder applciation. You
can write components for (for example) decompressing your compressed
movie stream, and plug them into Windows Media Player without having to
recompile either one. It's used for everything from plug-ins,
specialized widgets, active agents running in the background,
distributed processing, and embedded programming languages for
applications.
It's basically library++, "active" libraries that can run by themselves
as independent components.
It's "component" stuff, which I don't think Linux ever really got around
to implementing, or at least not using in any sort of consistent way.
You use it to do all the sorts of things you use IPC for (pipes,
sockets, etc) in Linux land.
Date: 29 Oct 2007 18:09:34
Message: <4726682e$1@news.povray.org>
> applications.
Let me add some: things like showing custom thumbnails for a file format
(like Windows does by default for pictures) is done by implementing a
COM interface. explorer.exe will tell your COM object to generate the
thumbnails.
Same for adding items to the context menu, and to the drag context menu
(like WinZIP and other file archivers do, right-drag a zip and it will
have an "extract here" along with the default "move here" and "copy here").
Adding toolbars to explorer and/or Internet Explorer uses COM too, so
there's a technology advertisers know well[1].
Embedding and linking objects in Office documents uses OLE, which is
based in COM. I think WordPad is a program Microsoft used to test OLE
mechanisms, then they decided to release it.
Guess what ActiveX is based on.
[1] http://img.photobucket.com/albums/v391/brownpau/friends_ie.jpg
Date: 30 Oct 2007 07:12:30
Message: <47271fae$1@news.povray.org>
Holy toolbars, Batman!
Date: 30 Oct 2007 15:01:47
Message: <47278dab$1@news.povray.org>
Problem is, it is possible to get the same effect in Firefox.
Incautious/computer-unsavvy people don't care what browser they're
using, they'll still wreak havoc on their machine.  :P
Tim Cook
Version: 3.12
Date: 30 Oct 2007 15:49:57
Message: <472798f5$1@news.povray.org>
> applications.
So... would it for example be possible to write some gizmo that enables
you to insert a mathematical formula into a Word document without Word
crashing? (Or an organisation chart, for that matter?)
Could you write a plugin for Excel that draws some new kind of chart? Or
maybe be able to write macros in Haskell instead of VisualBasic? (You
know how normally you can write a macro in VB and then use it as a
normal function in cells of the spreadsheet? Well, what if you wanted to
use Haskell instead? Is that possible, technically?)
When I develop things that have to talk to each other, I generally just
use TCP. (Because almost all programming languages know how to do it. As
a somewhat nice side effect, it also makes it possible to run components
on seperate machines.) I have no idea what the overhead is though.
(Before now I've written some code in one programming language, then had
it use TCP to talk to a Tcl script to provide a front-end. Damn, if only
there was 1 programming language that had *all* the features I need...)
Date: 30 Oct 2007 16:24:46
Message: <4727a11e$1@news.povray.org>
Possible, yes. That's exactly one of the sorts of things it's good for.
Yep.
I would expect so. It depends what Excel exposes.0
There's certainly the serialization overhead.
Yah. That's what I'm doing right now, to wrap up some buggy C++ code
that doesn't bother to deallocate resources when something fails. :)
Date: 30 Oct 2007 16:42:56
Message: <4727a55f@news.povray.org>
  OTOH most spyware is designed to stick onto IE so at least they will
have a bit less of harmful effect if you use firefox.
Date: 30 Oct 2007 17:05:52
Message: <4727aac0$1@news.povray.org>
Darren New wrote:
>> enables you to insert a mathematical formula into a Word document
>> without Word crashing? (Or an organisation chart, for that matter?)
So... when you double-click a "drawing" object in Word, and Word locks
up for 40 seconds while it pages huge amounts of data back into RAM...
that's Word loading the external plugin that handles drawing objects?
>> to use Haskell instead? Is that possible, technically?)
Heh. Where do you find this kind of information?
(I guess it's kind of moot anyway. I don't have access to any
programming language that supports COM. No, I classify VB as "joke"
rather than "programming language"...)
>> just use TCP. I have no idea what the overhead is though.
Depends on what you're sending. (If it's text anyway, that's not too
bad. Or if you're just sending button presses...)
I know you probably don't care, but for a project I once make a small
gizmo that allows you to talk a Smalltalk application and move it's GUI
to another machine on the network. (But unlike, say, X11 or VNC, you're
working at the model level rather than the bitmap level.)
Date: 30 Oct 2007 17:10:34
Message: <4727abda$1@news.povray.org>
Javascript running under Windows Scripting Host (and under IE with very
low security settings) can use COM. PHP has a COM extension too,
although I have never tried it.
Date: 30 Oct 2007 21:03:22
Message: <4727e26a$1@news.povray.org>
I don't know if that's built in, or a separate COM object, or what.
Google "Excel vba interface" or "Excel com interface".
An example of code with COM calls in it:
http://www.smartquant.com/help/excel/
Or go to msdn.microsoft.com and search, except that they tend to take
down the documentation on any older versions of products, the bastards.
Actually, most stuff that runs on Windows supports COM. Including Tcl
(google for TCOM). And including WSH.  And including anything written
with .NET.  I'd be really surprised if Perl and all them didn't, too.
Yeah. If you're sending events, it's easier. COM exposes some pretty
complex APIs, tho.
That's pretty cool.
Date: 30 Oct 2007 21:44:40
Message: <4727ec18$1@news.povray.org>
Or, come to think of it, fire up Excel and go into the help box and
search for "vba".
Date: 30 Oct 2007 23:24:13
Message: <4728036d@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:4727aac0$1@news.povray.org...
C#?
You might also try F#. I haven't personally used it, but I think is a
language you might like, and it's built on the .NET framework.
Date: 31 Oct 2007 06:40:15
Message: <48qgi351j3ct4qs3i25m5sr6kqo5trj77r@4ax.com>
>search for "vba".
Or, while in Excel, [ALT}+[F11] to open the Visual Basic Editor, then [F2] to open the
Object Browser window, at least in Excel 2000.
Date: 31 Oct 2007 16:00:20
Message: <4728ece4$1@news.povray.org>
So... can anybody provide a high-level overview of the general structure
and terminology of this stuff?
(All the documentation I found so far just shows examples in C - which
means nothing to me.)
Date: 1 Nov 2007 01:05:13
Message: <MPG.2191c7f6ff09542f98a05e@news.povray.org>
In article <4727abda$1@news.povray.org>,
nic### [at] gmailisthebestcom says...
It should be noted that support for COM in those does **not** include
event management. That is only supported if you are running it IE, since
it has all the fancy bits in it that allow you to call Invoke. This is
apparently intentional, though I never quite got how knowing that you
fracking clicked on a button is more dangerous than a COM object that
tries to format your hard drive... I just don't get how disallowing
events did anything but make it a pain to do anything (though it does
work in IE, since IE supports an object event handler system, which lets
you link your own script function to the event. Its why, if you look in
the help for it, you will find that there are commands to both "link" an
event (don't remember the name of that) and a "GetRef" command used to
get the internal entry point to your script function, so that when the
event happens that function will be called. But without IE's event
manager, the linking command just generates a, "This command not
available", type error. :p
Its basically a serious pain in the rear. You can get past it by
introducing what is known as a ATL Bridge. Basically, ATL give more
direct support to the functions that are "needed" to tell Event A to
call your own code/script function. The problem is, the event cycle is a
bit wacky. Basically, you click the button, for example, it generates a
system level event, which is sent to your application, which is **then**
supposed to be sent to the event handler that is keeping track of who to
call when the event is received. Things like VB, MFC and Windows
Scripting Host, all pretty much leave you hosed, since they either don't
provide a way to *create* the needed link, or to even inform the object
that it should generate the event. But in some like MFC, the "event" is
not identified as one that belongs to your program, so is tossed back to
the OS, to die in obscurity, instead of being passed on to any handler
you "may" have. VB is a bit nicer, since you can trap arbitrary events
(harder to do in MFC, and impossible in WSH), but since you can't talk
to the core layer of the object to tell it that you "want" the event in
the first place, it won't tell you that it happened, let alone allow
your application to do anything about it.
Bloody mess...
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 4 Nov 2007 03:10:43
Message: <472d7e83$1@news.povray.org>
news:4728ece4$1@news.povray.org...
> structure and terminology of this stuff?
> which means nothing to me.)
http://en.wikipedia.org/wiki/Component_object_model
Also - powershell from MS is free and does COM
Date: 5 Nov 2007 04:36:01
Message: <472ee401@news.povray.org>
Already read it. It's one of Wikipedia's less helpful articles. (Ditto
for all that .NET stuff.)
Um... OK. Maybe they have some documentation I can use...
Date: 6 Nov 2007 00:04:05
Message: <472ff5c5$1@news.povray.org>
I think it's more like, now that you know what it is (namely, an API for
communication between independent objects via an API-like interface),
what's your actual question? :-)
Date: 6 Nov 2007 04:22:34
Message: <4730325a$1@news.povray.org>
 From Wikipedia's article, it seems that COM's idea of what the terms
"object", "class" and "method" mean is somewhat different from the usual
OO terminology. (Or Wikipedia is outright incorrect, which is of course
not impossible.) Can anybody clarify?
Date: 6 Nov 2007 10:29:12
Message: <47308848$1@news.povray.org>
Invisible escribió:
>> for communication between independent objects via an API-like
>> interface), what's your actual question? :-)
It is a bit different from normal OO terms. Just wait until you get to
the "containment/delegation and aggregation" part (replaces uses of
inheritance), that's really screwed up.
