POV-Ray : Newsgroups : povray.off-topic : Crysis is a devious Vista advertisement stunt? Server Time
20 Oct 2026 05:16:43 EDT (-0400)
  Crysis is a devious Vista advertisement stunt? (Message 1 to 15 of 15)
Subject: Crysis is a devious Vista advertisement stunt?
Date: 29 Oct 2007 09:14:33
Message: <4725eac9@news.povray.org>
Crysis is a game which is also a demo of the latest 3D hardware features.
It has several quality settings which define which features are turned on
or off.
  The program will not let you choose the highest quality setting
("very high") unless you are running the program in Vista with a DX10
compatible graphics card. It only lets you choose the second-highest
quality setting ("high"). Clearly it's trying to tell that the highest
quality setting turns on DX10-only (and thus Vista-only) features, so
they are not available in XP and DX9.
  It seems that this is a hoax. Just a marketing campaign. Yes, the
"very high" quality setting does indeed turn on several additional
rendering features, but the hoax is that these rendering features *do*
work in XP with a DX9 graphics card, and they do so at perfectly acceptable
speeds. Not allowing to choose this highest quality option unless you are
running Vista and a DX10 graphics card has nothing to do with lacking
hardware/OS support, but it's just an artificial limitation.
  The thing is, at least in the demo version of the program, you can
tweak its settings file manually and make all the "high quality" settings
to be turned on in the "high" settings, which the game allows you to choose,
and the features will work even if you are just running XP with DX9.
  So much for "Vista-only" features...
http://www.crysis-online.com/forum/index.php?topic=11837.0
Subject: Re: Crysis is a devious Vista advertisement stunt?
Date: 29 Oct 2007 10:13:12
Message: <4725f888@news.povray.org>
> or off.
Some people on that forum were saying that if you don't have DX10, those
features would run on the CPU instead of the GPU. Sounds like BS as
well: If it was done by the CPU, the framerates would be a lot lower.
People who edited the config were getting framerates *even better than
on Vista*.
Also, it would use the CPU if your GPU doesn't support the features and
you force them enabled anyway; but if you don't have the interface to do
such effects (DX10), there would be no way for the game to get those
effects.
So it's definitely as you say and as most people said on the forum: DX9
can do all those effects.
Date: 29 Oct 2007 10:45:57
Message: <op.t0yt2qmuc3xi7v@news.povray.org>
And lo on Mon, 29 Oct 2007 15:13:11 -0000, Nicolas Alvarez
<nic### [at] gmailisthebestcom> did spake, saying:
>> acceptable
>> are
> on Vista*.
> effects.
Wasn't this one of the original points of DX? 'The program says do this DX
action. The card drivers says it can handle it - give it to the card; The
card drivers says it can't handle it - can I emulate it?
Sometimes it was yes, sometimes no; depended on what was being asked for.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 29 Oct 2007 10:51:47
Message: <47260193$1@news.povray.org>
Maybe. Maybe they didn't test those features on DX9. There are a good many
applications that won't install in W2K, for instance, even though if you
trick them into doing that, they will run fine. The developer just didn't
want to be bothered by testing and supporting an older platform. Not
necessarily a MS conspiracy.
Date: 29 Oct 2007 11:11:43
Message: <4726063f$1@news.povray.org>
>>> acceptable
>>> are
>> those features would run on the CPU instead of the GPU. Sounds like BS
>> as well: If it was done by the CPU, the framerates would be a lot
>> lower. People who edited the config were getting framerates *even
>> better than on Vista*.
>> and you force them enabled anyway; but if you don't have the interface
>> to do such effects (DX10), there would be no way for the game to get
>> those effects.
>> DX9 can do all those effects.
> DX action. The card drivers says it can handle it - give it to the card;
> The card drivers says it can't handle it - can I emulate it?
Exactly. The program can't say "do this DX action" if that action is
defined in DX10 and the computer has DX9, so it wouldn't run neither
emulated nor native on card.
Date: 29 Oct 2007 11:37:37
Message: <op.t0ywguuyc3xi7v@news.povray.org>
And lo on Mon, 29 Oct 2007 16:11:42 -0000, Nicolas Alvarez
>>> those effects.
>> this DX action. The card drivers says it can handle it - give it to the
>> card; The card drivers says it can't handle it - can I emulate it?
>> for.
Yes. If you try to run a DX10 program on DX9 software plus hardware, then
it won't know what to do. However what if you run a DX10 program on DX10
software with DX9 hardware, which may be what the forum people are talking
about or simply that this game doesn't actualy use any new actions that
can't be emulated in DX9, but they don't want to take the performance hit
so they're disabled.
Phil Cook
Date: 29 Oct 2007 13:18:08
Message: <472623e0@news.povray.org>
  XP doesn't have DX10 support at all in software. Only DX9.
Date: 29 Oct 2007 13:24:01
Message: <47262541@news.povray.org>
Quote from the link:
"Yeah amazing getting the sunshafts and other stuff in XP it just shows
that vista is useless xp is just as good when it comes to graphics in
games."
If xp is 'just as good' than vista isn't useless, it's merely 'not
better than xp'.  Unless xp is useless, too.  :3
Tim Cook
Version: 3.12
Date: 29 Oct 2007 13:30:13
Message: <472626b4@news.povray.org>
> games."
  I suppose "it's useless" means "there's no advantage"... :P
Date: 29 Oct 2007 16:28:57
Message: <47265099$1@news.povray.org>
So I downloaded all the updates NVidia thought I needed (didn't need two
of 'em), downloaded the demo (over a GB?  for a demo?), installed it,
ran it...kinda.  Couldn't select the 'very high' settings (and I have
Vista and a quad-core system with 3 GB RAM here), got really choppy when
I tried actually going into the game...so I ran the GPU benchmark it
had.  Max fps of 4.41.  :P
I thinks my video card sucks.  XD
*uninstalls*
Tim Cook
Version: 3.12
Date: 2 Nov 2007 07:40:32
Message: <472b1ac0$1@news.povray.org>
> acceptable
The development team would have had to put in a huge amount of effort to
ensure those special effects worked on a DX9 card.  Why would they go to all
that effort and then not allow you to use them in the game?  If they really
wanted to get people to upgrade to Vista, they simply wouldn't have written
DX9 code for the effects and saved themselves a lot of time.
Another explanation is that they simply haven't got round to fully testing
the DX9 code yet for all the special effects, and didn't want to let people
try it "officially" in the demo.  If it is buggy after you've modified some
.cfg file yourself, you are less likely to get annoyed than if it is an
official option in the game.
Date: 2 Nov 2007 08:49:54
Message: <472b2b02$1@news.povray.org>
> testing the DX9 code yet for all the special effects, and didn't want to
> let people try it "officially" in the demo.  If it is buggy after you've
> modified some .cfg file yourself, you are less likely to get annoyed
> than if it is an official option in the game.
Then why does the game allow people to try it "officially" in the demo
under Vista?
Date: 2 Nov 2007 09:34:18
Message: <472b356a$1@news.povray.org>
>> modified some .cfg file yourself, you are less likely to get annoyed than
> under Vista?
Vista uses DX10 (even with a DX9 card), which makes a lot of stuff far
simpler to code.  I imagine that they concentrated on making the DX10
code-base first (which will run on both DX9 and DX10 hardware in Vista),
then ported the new features to be compatible with pre-DX10 systems (ie XP).
If they didn't want the new features to run on pre-DX10 systems, why would
they even bother coding for DX9?  They must realise that a large proportion
of people still are on XP, which is why I assume they are doing DX9 code, I
guess they just didn't want to include it officially in the demo for some
reason.
Also, if they really didn't want people to try it out in the demo, why leave
it as a simple plain-text hack to get it working?  If they really were
trying to fool people then just hard-code it into the binary somewhere, or
better yet, just don't write any DX9 code at all for the fancy effects...
Date: 2 Nov 2007 18:57:17
Message: <472bb95d@news.povray.org>
> would they even bother coding for DX9?
I'm guessing they originally wrote it towards DX10, and when they got
close, found that MS had screwed all their deadlines and release plans.
So they all jumped in and pounded away to add DX9 support at the last
minute.  And I'm guessing the lack of configuration is either an
oversight or it's because it's on a different part of the game by a
different group or something who didn't have time to fix it, maybe.
Maybe, in other words, they're waiting until the actual release of the
game to decide whether to let DX9 do the highest rez stuff, depending on
how fast MS gets their act together with Vista.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 4 Nov 2007 12:04:05
Message: <472dfb85$1@news.povray.org>
> close, found that MS had screwed all their deadlines and release plans. So
> they all jumped in and pounded away to add DX9 support at the last minute.
> And I'm guessing the lack of configuration is either an oversight or it's
> because it's on a different part of the game by a different group or
Yeh, that was pretty much my thoughts.  I mean why spend a huge amount of
resource debugging and testing the DX9 code (which will be far more complex
than the DX10 version), if by the time the game is released only a small %
of potential owners are not capable of running DX10.
