POV-Ray : Newsgroups : povray.off-topic : instantiation in various 3d formats Server Time
20 Oct 2026 05:16:41 EDT (-0400)
  instantiation in various 3d formats (Message 1 to 12 of 12)
Subject: instantiation in various 3d formats
Date: 27 Oct 2007 04:51:21
Message: <4722fc09@news.povray.org>
Just curious.... I want to know what 3d formats besides POV-Ray SDL
support object instantiation.  So far as I'm seeing, .obj does not and
yet seems like such a basic thing....  Am I wrong?  Know of a good place
to compare formats?
Thanks in advance,
Charles
Subject: Re: instantiation in various 3d formats
Date: 27 Oct 2007 05:44:11
Message: <4723086b$1@news.povray.org>
> to compare formats?
I have no idea about instanciation specifically, but this page is a good
start for plenty of data format:
http://local.wasp.uwa.edu.au/~pbourke/dataformats/
Hope this helps
Vincent
Date: 27 Oct 2007 07:21:22
Message: <47231f32$1@news.povray.org>
"Charles C" <"nospam a nospam.com"> a écrit dans le message de news:
4722fc09@news.povray.org...
> support object instantiation.  So far as I'm seeing, .obj does not and yet
> seems like such a basic thing....  Am I wrong?  Know of a good place to
> compare formats?
AFAIK, instantiation is not a property of the file format, but a feature of
the renderer.
G.
Date: 27 Oct 2007 07:38:20
Message: <4723232c$1@news.povray.org>
> the renderer.
True. Although it helps if the file format has some way to express that
the renderer should do this. (E.g., rather than just duplicating the
data twice.)
Date: 27 Oct 2007 10:19:10
Message: <472348de@news.povray.org>
> the renderer.
  If you tell the renderer "copy this mesh 1000 times over the scene" (but
the mesh data is kept only once in memory), thus getting a nice scene, and
then you want to save this scene into a file, how do you do that if the
file format doesn't support saying "copy this mesh here" commands?
Date: 27 Oct 2007 13:25:33
Message: <4723748d$1@news.povray.org>
>> the renderer.
Keeping it only once in memory is a feature of the renderer, which
requires such a command on the file format. Having the triangle list
only once in the input file is a feature of the file format. A (quite)
stupid parser could duplicate data in memory even if it's not duplicated
on the file!
Date: 27 Oct 2007 13:33:24
Message: <47237663@news.povray.org>
  That's what I thought.
Date: 28 Oct 2007 02:00:07
Message: <47243377@news.povray.org>
>>> feature of the renderer.
>> (but
>> and
> on the file!
Basically I like the idea of having the flexibility of being able to
export to a fairly universal format like .obj.   But if .obj doesn't
support instantiation, and if my model is (or will be) a collection of
tens if not (perhaps) hundreds of thousands of non-unique meshes (save
the for transformation of each), then man oh man will that be a big
file.  I can't imagine most file formats would leave out such a basic
thing.
Anyway unless somebody can answer somewhat definitively about a good
format, it looks like I've got some studying to do.  Paul Bourke's page
that Vincent linked to looks useful especially with that handy search
button.
Charles
Date: 28 Oct 2007 02:00:11
Message: <4724337b@news.povray.org>
>> place to compare formats?
> Hope this helps
Thanks!  This is definitely a good resource to know about.
Charles
Date: 28 Oct 2007 10:45:00
Message: <web.4724ad79c654e3737d55e4a40@news.povray.org>
> thing.
A lot of older formats would have been dealing with very simple scenes (for an
example of a format that time has really left behind, look at .3DS). I guess
the use case for a lot of those formats was to hold a single model rather than
a scene. You want a modern interchange format; Collada springs to mind.
Tom
Date: 29 Oct 2007 00:44:34
Message: <47257342@news.povray.org>
Thanks.  So far I've been too busy to have a chance to do anything more
than light browsing - I haven't really gone and done my homework fully
yet.
That said, are it seems like back then there'd be even more concerned
about efficiency.  E.g. table legs.  I guess I should look into scene
formats too. :-) I didn't know there was a difference, but I also notice
.wrl versus .vrml.
Charles
Date: 29 Oct 2007 01:47:27
Message: <472581ff@news.povray.org>
Woohoo! you're right. It's there.
http://www.collada.org/mediawiki/index.php/COLLADA_FAQ
First I saw:
"Transform hierarchy (rotation, translation, shear, scale, matrix)"
which was a good clue that instantiation really be there, and then I saw:
"Instancing"
But why haven't I heard of this Collada before?  Is it because it's XML
and the fact that (around here anyway) there seems to be a common
aversion to XML?
Charles
