And so Kimi Räikkönen won the F1-Championship, leaving both Alonso an
d
Hamilton only one point behind!
-- Arttu "Blizzara" Voutilainen
-- http://www.zbxt.net/~blizzara/
-- antilzah.deviantart.com
No, Gail won.
> And so Kimi Räikkönen won the F1-Championship, leaving both Alonso and
Yep, closest season for a long time. Silly mistakes by both Alonso and
Hamilton over the last few races which cost them both the championship.
Still, if they had won there would always be doubt after they were caught
spying on Ferrari...
Do you think that Massa's small mistake before the 2nd pit-stop was
intentional to allow Kimi to pass in the pits?
And lo on Mon, 22 Oct 2007 08:43:24 +0100, scott <sco### [at] laptop com> did
spake, saying:
> caught spying on Ferrari...
Is this the one with the row about fuel temperatures? I don't know first
the Rugby and now this.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Hehe yeh, apparently two other teams pumped in their fuel at less than 10
degrees below ambient, which is not allowed. But the FIA decided not to
disqualify the drivers as the advantage gained would have been less than 1
second over the race and likely not changed the outcome. Disqualifying the
teams would have meant a different world champion though...
And lo on Mon, 22 Oct 2007 11:10:41 +0100, scott <sco### [at] laptop com> did
spake, saying:
>> first the Rugby and now this.
> 10 degrees below ambient, which is not allowed. But the FIA decided not
> to disqualify the drivers as the advantage gained would have been less
> than 1 second over the race and likely not changed the outcome.
> Disqualifying the teams would have meant a different world champion
> though...
IOW they broke the rules, and got caught, but the advantage they gained
was deemed inconsequential to their win; so that's okay then. Wag that
finger and tell them not to do it again - pfft.
Phil Cook
>> though...
Well the official report was that they were not punished because the fuel
temperature could not be proved.
But the funny bit is that McLaren are presumably asking for the teams
concerned to be punished and have their drivers points taken away. This is
the McLaren who had all their team points taken away and narrowly avoided
having all their driver points taken away too... they should be careful.
And lo on Mon, 22 Oct 2007 11:57:49 +0100, scott <sco### [at] laptop com> did
spake, saying:
>>> not to disqualify the drivers as the advantage gained would have been
>>> less than 1 second over the race and likely not changed the outcome.
>>> though...
> fuel temperature could not be proved.
Wasn't it at a lower temperature they could get more fuel into the tank?
Don't they keep a record of how much fuel is put in and then compare it to
the tank capacity? I mean if at X degrees the tank will hold Y and at X-10
it'll hold Z, bit of a smoking gun if they stuck Z in there.
> is the McLaren who had all their team points taken away and narrowly
> avoided having all their driver points taken away too... they should be
> careful.
Sounds like a 'why did we get hit and not them?'
Phil Cook
No.
This assumes the tank is filled to the brim - which it hardly ever is. Most
drivers made 2 or 3 stops during the race, IIRC most cars can do about
60-70% race distance when filled right to the brim with fuel.
The main reasons for doing it are to speed up the refilling process and the
engine also develops slightly more power on lower temperature fuel - but
this effect is only for a lap or two before the fuel heats up to ambient
temperature.
I don't know where the quoted temperature measurements come from, but
presumably they were not reliable or accurate enough to actually make a
disqualification.
>> careful.
But McLaren only got team points, not driver points, taken away for a much
more serious offence. They are campaigning to get driver points taken away
from yesterdays race (so they can win the drivers championship), seems silly
when they narrowly missed having drivers points taken away from their own
team...
