POV-Ray : Newsgroups : povray.off-topic : New puzzle/logic game Server Time
20 Oct 2026 05:58:57 EDT (-0400)
  New puzzle/logic game (Message 1 to 16 of 16)
Subject: New puzzle/logic game
Date: 2 Oct 2007 00:25:03
Message: <4701c81f$1@news.povray.org>
Hi everyone,
I've made a new game. It's called Light's Out!, and is based on an
electronic handheld game by the same name.
The objective is to clear all the lights on each board. It has twenty
levels and penalties if you make too many mistakes. POV was used to
create the buttons, pointer and cursor. A special homage to POV appears
on level 9 :)
Here's a screenshot:
http://www.caltel.com/~abenge/lights_out.jpg
And the zip file (314kb):
http://www.caltel.com/~abenge/lights_out.zip
You'll need DirectX 8.0 or higher and Windows for it to work. The
instructions are included in the zip.
Tell me what you think of it! I'd also like to know if it runs smoothly
on your system. I capped the frames at 100/second. On my 1.6ghz machine
it runs perfectly, with frames to spare.
Plus, if you have any bugs to report, please tell. I think I've buttoned
everything up, but you never know!
Sam
Subject: Re: New puzzle/logic game
Date: 10 Oct 2007 04:23:51
Message: <470c8c17$1@news.povray.org>
> Tell me what you think of it! I'd also like to know if it runs smoothly on
> your system. I capped the frames at 100/second. On my 1.6ghz machine it
Looks very nice and plays very smoothly.  I got stuck on level 7 so couldn't
get to see the POV homage :-(
On my laptop I assume it runs at 100 fps as the CPU usage is only around
15-20%.
One very small suggestion is that you should be able to make the game run
full-screen, or at least change the size of the window.  In the
"lights_out.log" file it says it could not find a full screen mode of
512x512 - I assume this is an error because not many monitors will have a
512x512 full-screen mode defined!
Date: 11 Oct 2007 17:26:12
Message: <470e94f4$1@news.povray.org>
> couldn't get to see the POV homage :-(
Wow, a reply :) Thanks for your input!
The levels are made by randomly switching areas of the board, and it's
you're job to 'undo' what was done to it. Each level *can* be beaten,
but if you get off on the wrong foot, so to speak, it can be very
difficult to fix it.
> 15-20%.
Well, I capped the fps at 100, so that's good.
> run full-screen, or at least change the size of the window.  In the
> a 512x512 full-screen mode defined!
I've never heard of a 512x512 screen resolution on *any* monitor/video card.
The game library I use lets you alt+enter for full screen as a default,
so that's why there is an error. It won't switch to a nonexistent screen
resolution. I've never had any luck switching back-and-forth between
(regular) modes, so that's why I made the screen an odd size. To prevent
the user from potentially crashing the game. It may just be an issue
with target layers; I haven't tried testing a game without them yet.
If I see that enough people like the game, I'll add support for a full
screen mode, and maybe even allow the high scores to be kept.
Sam
Date: 11 Oct 2007 17:47:46
Message: <470E9B05.9000006@hotmail.com>
OK here is another one. (I planned to reply earlier, but my video card
fan broke, and the temporary card I used could not display the game,
current temporary does.)
I did reach level 9 and saw the POV logo's
[snip]
It is an interesting new concept, but I have two problems with it:
- One is purely me, I hate bright light and you made the game with
simulated overexposure, even though white is just as white as always, it
still annoys me.
- from level 5 on they have all the same difficulty level. (unless very
high levels have more light) As soon as you don't see an obvious answer
you start trying thinks randomly (at least I did). I have learned by now
that there is a.o. a combination of switches that will switch only the
light at position <2,2> or equivalent. But I still have no clue what
that combination is. I keep finding it faster by now, but the number of
switches to turn is too big for me to remember. So I can solve the
levels but I don't feel I am learning to see the patterns. Put another
way: it is boring, sorry.
At last you need more variation in the boards. Plus a few introductory
levels to learn some combinations that only affect one or a few lights.
A bit like the combination of rotations that only swapped two cubes in
rubic's cube.
Date: 11 Oct 2007 19:04:31
Message: <470EAD02.5010203@hotmail.com>
your score will not be saved!
Date: 11 Oct 2007 19:11:31
Message: <470eada3@news.povray.org>
The idea didn't come from me; I just implemented it.
> still annoys me.
I got an e-mail about that very same thing. I didn't realize it would be
so annoying...
Hmm, I tested it, and I don't get the same problem.
Yeah, it is kinda boring. I programmed it just to learn a few things and
keep my programming skills up. What I really want to make is another
'Metroidvania' type game. I still need to learn some things before I
can, though.
How so? Boards with different shapes?
> rubic's cube.
The difficulty does rise rather steeply. As I said previously, if enough
people like it, I'll improve on it. For now, I'll let it sit and collect
dust.
Sam
Date: 12 Oct 2007 03:02:48
Message: <470f1c18$1@news.povray.org>
>> still annoys me.
> so annoying...
Leave it as an option though - I like it :-)
It took me a few goes to realise the board was randomly generated by
"switching" a few squares before showing the board.  I always got stuck with
a board with 2 lights on in the bottom row and cannot work out how to get
them off.  If I am unlucky I get this on level 3 or 4.  After about 100
random clicks it then looks solvable, but often I just restarted the
program.
Oh yeh, there should be a button to start again at level 1.
Yeh, or just label certain squares as "always off", which is essentially the
same thing.  Or allow the "toggle 4 neighbours" rule to change, I remember a
game once where clicking each square toggled a random (but constant)
selection of squares on the whole board.  Was pretty fun.
> dust.
Yep, that's what always happens to my projects too :-)  Right this moment I
am about 60% through writing a game, but now I have an idea for a better one
which I want to start on right away!  I have no incentive really to finish
off the first game.
Date: 12 Oct 2007 19:38:44
Message: <47100686.2070308@hotmail.com>
bug: the first level after you continue after completing all levels does
not have 2 switches but many more.
btw I seem to be learning a bit at last. I recognize now a few patterns
that I can solve. Now most of my levels are below 100 clicks. Total
score last time 23700.
Date: 13 Oct 2007 21:36:35
Message: <471172a3$1@news.povray.org>
andrel wrote:
It won't? <grin>
Ahh, I *try* to fix these things, but there is always that one variable
I didn't account for. I know why global variables are a bad idea now....
Not too bad!
~Sam
Date: 28 Oct 2007 22:40:10
Message: <4725561a@news.povray.org>
> moment I am about 60% through writing a game, but now I have an idea for
> a better one which I want to start on right away!  I have no incentive
> really to finish off the first game.
Wow, you reached a whole 60% of completion on a project before having
another idea... *jealous*
Date: 2 Nov 2007 04:40:56
Message: <472af0a8$1@news.povray.org>
>> I am about 60% through writing a game, but now I have an idea for a
Yeh it's pretty unusual for me - although it's been stuck at 60% for the
last few weeks now because I've been too busy.  I just need to implement AI
and a menu system and it should be pretty much finished...  AI could turn
out to be more than 40% though... :-)
Date: 2 Nov 2007 09:44:41
Message: <472b37d9@news.povray.org>
> AI and a menu system and it should be pretty much finished...  AI could
> turn out to be more than 40% though... :-)
Last few weeks? That's nothing. Quote of a program FAQ:
"A GTK+ interface to jigdo is being worked on. Unfortunately, it's been
80% done for over 1.5 years, so don't hold your breath for its release."
Date: 2 Nov 2007 09:51:40
Message: <472b397c@news.povray.org>
Hehe, I made the unusual (for me) step this time to record each day what I
had done.  Most of the work I did during August and the beginning of
September.  I had a break at the end of September for several reasons, and
then had another burst of progress during most of October.
Since then I have been much busier at work with several trips away and I've
been trying to organise moving to a new apartment at the end of November,
and I'm out of the country all next week for a training course!  I don't
really see myself getting much more done in 2007...
Oh and the source for my game is only about 250K, so I guess it's pretty
small compared to a GTK+ interface to jigdo, whatever that is :-)
Date: 2 Nov 2007 10:04:02
Message: <472b3c62$1@news.povray.org>
>>>> having another idea... *jealous*
>>> the last few weeks now because I've been too busy.  I just need to
>>> implement AI and a menu system and it should be pretty much
>>> finished...  AI could turn out to be more than 40% though... :-)
>> been 80% done for over 1.5 years, so don't hold your breath for its
>> release."
> I had done.  Most of the work I did during August and the beginning of
> and then had another burst of progress during most of October.
Hey, I was planning to make some program to record what I was doing
every *five minutes*. I usually look for some docs online or whatever
and end up reading lots of totally unrelated things[1]. The popup saying
WHAT ARE YOU DOING would remind me I was supposed to be doing something
else.
[1] http://xkcd.com/214/
BTW, that's not something *I* am doing. Just a funny example I
remembered of a "suspended" project.
Date: 2 Nov 2007 11:40:01
Message: <web.472b5288e818cbef2c10637b0@news.povray.org>
GTK+ interfaces these days are XML-generated code which is parsed and built in
run-time.  They tend to be pretty small in contrast to code them directly pure
C GTK+ API.  Still, even the most heavy hand-coded C interfaces in GTK+ are not
as large as the GTK+ libs themselves.  Your application interface code will
always be in the K marks.
How about comparing the GTK+ lib to the DirectX or Windows.Forms libs instead?
btw, of course I couldn't run the game.
Date: 2 Nov 2007 11:51:14
Message: <472b5582$1@news.povray.org>
If you'll do the comparison, add things like Java Swing to the mix (or
better: SWT).
