POV-Ray : Newsgroups : povray.off-topic : My laptop is a binge drinker Server Time
3 Nov 2026 21:21:02 EST (-0500)
  My laptop is a binge drinker (Message 1 to 26 of 26)
Subject: My laptop is a binge drinker
Date: 10 Sep 2007 06:28:30
Message: <46e51c4e$1@news.povray.org>
So, last night I knocked over a full can of beer onto my MacBook. Which
was open, turned on and rendering (as usual). Most of the spillage went
directly onto the keyboard. As you can imagine, I let out a set of
strangled expletives and fairly levitated from my chair to deal with the
catastrophe.
I turned it off, tipped the excess beer off the keyboard and took out
the battery. Then I spent the best part of an hour trying to find a set
of screwdrivers small enough to permit a careful disassembly; having
found some, I then sat down and, well, carefully disassembled it. A bit
of respect to Apple here - I was expecting to have to break something at
this point, but the entire keyboard lifted off in its entirety with a
minimum of fuss (although there were about 15 screws in the battery bay
alone that I didn't immediately notice). I took out the RAM too.
Next, I liberally hosed down the keyboard and laptop interior with lab
grade ethanol, soaked up the excess with paper towels, played a cold
hairdryer over the whole thing for a few minutes and left it to dry. As
I type, there it still sits.
I will reassemble it this evening and fire it up to see what's what. In
the meantime, does anyone have any additional advice?
Subject: Re: My laptop is a binge drinker
Date: 10 Sep 2007 06:58:47
Message: <46e52367@news.povray.org>
> A bit of respect to Apple here - I was expecting to have to break
> something at this point, but the entire keyboard lifted off in its
> entirety with a minimum of fuss (although there were about 15 screws in
> the battery bay alone that I didn't immediately notice). I took out the
> RAM too.
Yeh, most laptops have very easily removed keyboards, I guess so suppliers
can replace with region-specific keyboards without having to take the whole
thing apart.  My Dell has 4 or 5 screws on the back that are even labelled
"K" :-)
Nope, sounds like it should be fine.  The only problem will be if some of
the keys are "sticky", that can sometimes be really hard to fix totally -
but if you rinsed it off before the beer started to dry it shouldn't be a
problem.
Good luck!
Date: 10 Sep 2007 09:05:46
Message: <46e5412a$1@news.povray.org>
> catastrophe.
just make sure it gets enough exercise so it doesn't get a beer belly......
Date: 10 Sep 2007 12:06:17
Message: <op.tyf4c50ac3xi7v@news.povray.org>
And lo on Mon, 10 Sep 2007 14:05:46 +0100, Tom Austin <taustin> did spake,
saying:
>> was open, turned on and rendering (as usual). I will reassemble it this
>> evening and fire it up to see what's what. In the meantime, does anyone
> belly......
and note that you'll now only be able to do that render when you pour some
more beer onto it, otherwise it'll be 'file not found' ;-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 10 Sep 2007 13:13:41
Message: <46e57b45$1@news.povray.org>
1. Where the hell did you get lab-grade ethanol from?
2. Isn't that likely to disolve important plastic components?
http://blog.orphi.me.uk/
Date: 10 Sep 2007 17:08:36
Message: <46e5b254$1@news.povray.org>
I heard that you can stick a cell-phone, or an Ipod
that has gotten wet into a bag of dry uncooked rice
overnight to get the last of the water out.  The rice
absorbs the water I guess. You might try some
variation on that.
Date: 10 Sep 2007 17:24:28
Message: <46e5b60c@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> a écrit dans le message de news:
46e5b254$1@news.povray.org...
> variation on that.
One of these variations can be Silica gel dryer (the stuff you find in
little bags in electronic devices package)
Marc
Date: 10 Sep 2007 20:34:57
Message: <46e5e2b1$1@news.povray.org>
If you persist in drinking around your laptop, get an external keyboard
so that you can keep the CPU farther away from the beer.
John
Date: 11 Sep 2007 05:03:09
Message: <46e659cd$1@news.povray.org>
> spake, saying:
>>> Which was open, turned on and rendering (as usual). I will reassemble
>>> it this evening and fire it up to see what's what. In the meantime,
>> belly......
> some more beer onto it, otherwise it'll be 'file not found' ;-)
When I eventually check the output file I'll probably find unexpected
focal blur. Or maybe the preview will look much better than the actual
image or something. :)
Date: 11 Sep 2007 05:17:12
Message: <46e65d18$1@news.povray.org>
The lab at work. You've probably got access to some too by the sounds of
it, although I wouldn't go 'borrowing' any unless you know for certain
that you won't get fired for it.
I don't think so, maybe some of the cheaper adhesives. Now acetone -
that would probably dissolve the circuit boards! Ethanol is particularly
suitable for cleaning electronics because it's hydrophilic,
non-conductive and evaporates very swiftly at room temperature.
Date: 11 Sep 2007 05:20:13
Message: <46e65dcd$1@news.povray.org>
>> variation on that.
Good ideas both - we've got silica in the desiccators in the lab, I'll
borrow some of that and give it a go. Apparently it can take weeks to
properly dry laptops after spillages...
Date: 11 Sep 2007 05:20:46
Message: <46e65dee$1@news.povray.org>
>> In the meantime, does anyone have any additional advice?
Yes, or one of those silicone overlays. Isn't 20-20 hindsight a
wonderful thing! :)
Date: 11 Sep 2007 05:26:05
Message: <46e65f2d$1@news.povray.org>
Well, I put it back together and booted it up last night. I think it
needs some more drying time :(
I think the HD and motherboard and everything actually within the case
is fine. However, the screen has been badly affected - it has big glare
artifacts across more than a quarter of its area, although all the
pixels seem to be firing OK so maybe the moisture is in a different
layer or something. The keyboard has 7-8 non-functional keys and I have
a suspicion it's sending the wrong characters, because I can no longer
log in - it complains about the password, even though all those keys
appear to work.
Anyway, it's back in bits in the airing cupboard now. I think it'll take
some time to be sure of long-term damage...
(kicks self)
Date: 11 Sep 2007 06:16:04
Message: <46e66ae4$1@news.povray.org>
> However, the screen has been badly affected - it has big glare artifacts
> across more than a quarter of its area, although all the pixels seem to be
> firing OK so maybe the moisture is in a different layer or something.
Yes, it's pretty unlikely that any moisture got inside the actual LC, or
even under the polarisers, they are all laminated together with
moisture-proof seals around the outside.
What probably happened is the beer got between the rear polariser and the
backlight, there is usually a 100-500 micron air-gap that could easily fill
with liquid.  Any contamination in this area will show up very obviously on
the screen.
Cleaning it out will be hard, if you're lucky you could remove the actual
display panel from the backlight without too much effort (sometimes they are
stuck down with almost super-glue like adhesives!).  But then the backlight
will consist of several very thin optical films, which the liquid could have
got between too.  In theory you could take the backlight apart and clean
each film thoroughly, but I don't rate your chances of being able to get
back to a perfect looking screen (this sort of assembly is normally done in
clean rooms).
Date: 11 Sep 2007 06:47:38
Message: <46e6724a$1@news.povray.org>
>> layer or something.
That's a relief.
> the backlight, there is usually a 100-500 micron air-gap that could
> easily fill with liquid.  Any contamination in this area will show up
> very obviously on the screen.
Well, I'm hoping that my overkill sloshing of ethanol is the main
culprit here, and that most of it will evaporate eventually. I've taken
the trim off the screen which will help, I guess - there are some small
vents around the edge of the actual screen panel. I'm reluctant to take
it apart further without good reason because I have zero experience with
LCDs!
> actual display panel from the backlight without too much effort
> (sometimes they are stuck down with almost super-glue like adhesives!).
It doesn't look human-dismantle-able, I couldn't see any more screws
than those that hold it to the plastic case.
> But then the backlight will consist of several very thin optical films,
> which the liquid could have got between too.  In theory you could take
> the backlight apart and clean each film thoroughly, but I don't rate
> your chances of being able to get back to a perfect looking screen (this
> sort of assembly is normally done in clean rooms).
Are they very delicate? I don't have access to a clean room but we have
any amount of rubber gloves, sterile dooberys and anti-static wossnames
in our lab at work.
The real problem is if the films are held together by decent adhesive I
might break something just taking it apart. This will be a worst-case
last-ditch option I think!
Thanks for the info
Date: 11 Sep 2007 07:09:29
Message: <46e67769$1@news.povray.org>
>> fill with liquid.  Any contamination in this area will show up very
> Well, I'm hoping that my overkill sloshing of ethanol is the main culprit
It may be a residue of ethanol on the rear polariser, you could try and put
a few drops on the front of the screen and see if you can see anything once
it has dried off.  Polarisers are funny things and react weirdly sometimes
to certain chemicals.
Turn on the screen anyway, it will generate a load of heat which will help
dry out any left-over moisture.
> It doesn't look human-dismantle-able, I couldn't see any more screws than
Yeh, they are not really designed to be taken apart once assembled.  A lot
of the components are stuck down and "snapped in" rather than screwed.  If
you don't know the details about the exact model you could easily end up
breaking something.
The panel will be made from two sheets of glass stuck together around the
edge, each sheet of glass is probably between 0.3 and 0.7 mm.  The only real
weak point is around the edge where there is no polariser attached to
strengthen the glass - it is really easy to chip or snap off a corner or
edge of the glass here, especially as this is usually where it is stuck down
to the backlight.  Once you do that it's the end, because there are
electrical connections and circuits all around the edge of the glass.
The films aren't usually held together by anything, they just sit in there
and are constrained from moving by all the other components.  Once you get
the panel itself off, the films should just lift out one by one (maybe they
have a small dab of adhesive in one corner to help keep them in position).
The hardest bit is the glue around the outside of the panel that holds it to
the backlight.  Maybe you have some chemical that can dissolve this
adhesive, or just go around the outside carefully with a knife (if
accessible).  Don't put any force on the edge of the glass though, it's the
weakest point and will chip easily.
Date: 11 Sep 2007 07:38:36
Message: <46e67e3c$1@news.povray.org>
> put a few drops on the front of the screen and see if you can see
> anything once it has dried off.  Polarisers are funny things and react
> weirdly sometimes to certain chemicals.
> help dry out any left-over moisture.
My laptop's screen died after I was caught under heavy rain, carrying it
in a not-so-waterproof bag...
I never knew exactly what happened, but apparently some water got caught
in the screen, causing the sort of effect Bill is seeing, I think. At
first it was working OK but large drops of liquid could be seen, I
believe they were behind the pixels and just in front of the backlight.
I thought turning it on would help it dry, and apparently it was an
error... One day after that the screen would not show anything. Perhaps
some metallic connector got corroded by the water, I don't know.
The screen can still be turned on (it was a year ago), but now shows
only squarish clusters of weakly colored pixels. Something hard to
describe... Anyhow my laptop has became a desktop :-( And traces of the
water can still be seen.
The interesting thing is that it had one broken pixel that permanently
appeared red. This is now the only pixel with a definite color ;-)
I don't know exactly how you can solve the problem, but in my experience
turning it on to make it dry did not help...
Vincent
Date: 11 Sep 2007 08:03:51
Message: <46e68427$1@news.povray.org>
> error...
You need to make sure all water (or anything water-based, eg beer) is gone
before turning it on.  As soon as you get water in anything electronic rip
the battery out immediately, otherwise the tracks on the circuit boards (and
the glass if you have an LCD) will start to corrode very quickly.
Only after you have got rid of all the water should you attempt to put the
battery back in and turn it on.  Using ethanol (as Bill did) is a good way
to get rid of all the water, my suggestion was to turn it on to encourage
any remaining ethanol to evaporate.
Sorry if that wasn't clear... I take no responsibility for anyone damaging
anything :-)
Date: 11 Sep 2007 08:49:32
Message: <46e68edc$1@news.povray.org>
>> error...
> gone before turning it on.  As soon as you get water in anything
> electronic rip the battery out immediately, otherwise the tracks on the
> circuit boards (and the glass if you have an LCD) will start to corrode
> very quickly.
> the battery back in and turn it on.  Using ethanol (as Bill did) is a
> good way to get rid of all the water, my suggestion was to turn it on to
> encourage any remaining ethanol to evaporate.
> damaging anything :-)
Well in my case the damage is done and I will only blame myself :-) In
fact I'm surprised that the screen is the only thing that died in that
laptop...
I guess what confused me in your previous post was the term "moisture"
which I associate with water.
That raises another question: how can one be sure that no water is left,
before turning the screen on? And if liquid can be seen still, how can
you tell it's ethanol?
Vincent
Date: 11 Sep 2007 09:55:47
Message: <46e69e63$1@news.povray.org>
> before turning the screen on? And if liquid can be seen still, how can you
> tell it's ethanol?
Good point, I assume that Bill has it covered though:
"Well, I'm hoping that my overkill sloshing of ethanol is the main
culprit here,"
I had a look through a few documents here and my suspicion is that the
ethanol might have done some permanent damage to the polarisers.  Here we
have to test the polarisers for lots of different things (petrol, diesel,
sweat, face-cream, cleaning fluids, coffee etc), and one of the tests for
cleaner fluid (some mixture with ethanol in it) often fails and leaves
permanent marks on the polariser...
FWIW we use IPA (isopropyl alcohol) for cleaning the polarisers... might be
worth a shot if you can get to the inside.
Date: 11 Sep 2007 10:50:34
Message: <op.tyhvixb8c3xi7v@news.povray.org>
And lo on Tue, 11 Sep 2007 10:28:22 +0100, Bill Pragnell
<bil### [at] hotmailcom> did spake, saying:
> appear to work.
That'd be the hangover, try not to type so heavily.
Phil Cook
Date: 11 Sep 2007 10:51:29
Message: <46e6ab71$1@news.povray.org>
Yeek, now I hope it was the beer after all. Do you make LCDs for Apple
or can I also hope that their materials are sufficiently different that
I might be in the clear? :-\
> be worth a shot if you can get to the inside.
I'll look into it, cheers
Date: 11 Sep 2007 11:07:37
Message: <46e6af39$1@news.povray.org>
> Yeek, now I hope it was the beer after all. Do you make LCDs for Apple or
> can I also hope that their materials are sufficiently different that I
I know we supply the LCDs for the full-size iPods and the iPhone, not sure
about any other Apple products though, it's not out of the realms of
possibility that we do.  The other groups tend to keep themselves very much
to themselves, I only really know about LCDs in phones and cars in Europe.
But even within my small area of knowledge we use several different
polariser suppliers and each of them has several different versions of
polarisers, each with different good and bad points.  It's always a matter
of compromises when you select which one to use.
It's worth noting though that the front polariser usually has some
anti-glare and anti-reflection coatings (unless you have one of those "CRT"
effect LCDs...) and possibly even some layer to protect it from impact with
the keyboard, so the front is usually much better protected than the back...
Date: 13 Sep 2007 09:21:40
Message: <46e93964@news.povray.org>
It lives!
24h in an airing cupboard, 24h sealed in a bin liner with a tray of
silica crystals. The keyboard works perfectly, although the touchpad
button sticks a little. It boots to the desktop properly, no problems.
The screen is still a bit munged, but I think the effect has shrunk
slightly, so I'm going to keep drying it when not in use. The pixels all
fire ok, it's just a smudge of brightness variation... looks really weird!
I've invested in an external drive to back up my system properly just in
case the HD throws in the towel at a later date (which I was meaning to
do anyway, so not really an unexpected cost).
Thanks for the sounding board, everybode :)
Date: 4 Oct 2007 17:57:12
Message: <470561b8$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:46e93964@news.povray.org...
> It lives!
Very Impressive. I just bought a MacBook Pro this afternoon and I hope to
never have to go through this. I am reassured however that it is possible in
some cases.
-r
Date: 5 Oct 2007 05:36:01
Message: <47060581$1@news.povray.org>
>> It lives!
> some cases.
Get one of those silicone keyboard covers if your home is a high-risk
beverage environment. I plan to. Any day now. Promise.
