POV-Ray : Newsgroups : povray.off-topic : Power Server Time
3 Nov 2026 21:24:48 EST (-0500)
  Power (Message 1 to 50 of 133)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Power
Date: 1 Sep 2007 14:10:45
Message: <46d9ab25@news.povray.org>
Well, I've been testing out all sorts of electric and electronic gear to
find out what actually uses the most power. The results are very
surprising...
The most thirsty device I've found so far is... the kettle. It uses in
excess of 3,000 W for the entire duration that you try to boil water
with it. On the other hand, something like the washing machine uses a
tiny fraction of that, even when it's on its highest spin cycle. (Uses
only 600 W. Actually uses 700 W while it spins up, but then drops to 600.)
I haven't tested out the TV yet, but of all the stuff I have tested, it
seems that any device that performs any kind of *heating* instantly uses
many times more power than anything else. I emphasize: MANY TIMES more
power. Not 20% more, not 50% more, but nearer to 1000% more! Heck, even
the vacuum cleaner (surely a high power device) in fact uses a fraction
of the power that the toaster does!
Can anybody suggest why this might be? I mean, huge powerful electric
motors use a fair bit of power, but it's almost insignificant compared
to heating devices. Why does heating things require so much power?
Also, I notice that my PC uses about 10x as much power as my laptop.
There are two possible explanations for this:
1. My PC is (or recently was) leading edge, whereas my laptop was pretty
much old hat even when it was purchased.
2. It's a laptop. It's designed to use less power.
PS. We have *another* Intel Core 2 Duo laptop at work. And just like the
first one, it seems to be utterly impossible to make it heat up, no
matter how much number chrunching I throw at it. How do they manage that?
http://blog.orphi.me.uk/
Subject: Re: Power
Date: 1 Sep 2007 15:14:31
Message: <46d9ba17@news.povray.org>
No answer (sorry), but two questions :
- What device do you use to mesure power ? Is it expensive ?
- Have you tried to mesure the power used by electronic devices (TV,
HiFi, etc.) when they are on standby ? I find it difficult to get a
estimation for this, and it seems to vary greatly even among similar
devices ?
Thibaut
> surprising...
Subject: Re: Power
Date: 1 Sep 2007 15:30:46
Message: <46d9bde6$1@news.povray.org>
It's amazing how much potential there is in even a small amount of heat,
isn't it?
By the way, while heating so far beats all other estimates, IIRC cooling
requires even *more* juice for the same amount of temperature change.
Of course, I don't know if your air conditioner will suck in as much
heat as your kettle puts out, but AC is probably the greatest drain on
the power grid pretty much anywhere in the world.
Both.
Several ways, one of which being that it slows itself down if it gets
too hot :)
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Power
Date: 1 Sep 2007 15:52:22
Message: <46d9c2f6$1@news.povray.org>
Heat is generated through increased electrical resistance; in order to
heat a heating element up, you need to push more electricity through it.
http://en.wikipedia.org/wiki/Heating_element is a good starting point.
Jim
Subject: Re: Power
Date: 1 Sep 2007 21:19:27
Message: <46da0f9f$1@news.povray.org>
I think they are starting to use microwaves in
indirect heating in some high end ovens.  The
microwaves heat some sort of target element,
then pump air thru it, the oven door can be
opened without fear of microwave leakage.
It reduces cooking time, but I bet it's better
in terms of power usage too.
Subject: Re: Power
Date: 1 Sep 2007 21:32:56
Message: <46da12c8$1@news.povray.org>
There are also induction cookers which are significantly more efficient
than traditional conduction cooktops.
http://en.wikipedia.org/wiki/Induction_cooktop
Lance.
thezone - thezone.firewave.com.au
Subject: Re: Power
Date: 1 Sep 2007 21:50:13
Message: <46da16d5@news.povray.org>
It's because heat represents a huge amount of energy.
For instance, the humble calorie, the amount of energy required to raise
a single gram of water by one degree celsius, is the same amount of
energy required to lift that same gram of water about 387 meters in
Earth's gravity, or accelerate it from zero to 87 meters per second.
John
Subject: Re: Power
Date: 1 Sep 2007 21:52:44
Message: <46da176c$1@news.povray.org>
I have a 2Gig Celeron laptop (from 2003) that gets very hot when it has
to crunch, like during a POV-Ray render.
John
Subject: Re: Power
Date: 2 Sep 2007 00:24:50
Message: <46da3b12$1@news.povray.org>
On Sat, 01 Sep 2007 18:19:25 -0700, Tim Attwood wrote:
> I think they are starting to use microwaves in indirect heating in some
> high end ovens.  The microwaves heat some sort of target element, then
> pump air thru it, the oven door can be opened without fear of microwave
> leakage. It reduces cooking time, but I bet it's better in terms of
> power usage too.
Probably, but I'm always reminded of the phrase "there ain't no such
thing as a free lunch" - when it comes to generating heat, physics still
applies.  Doesn't mean things can't be more efficient than they currently
are, though.
Jim
Subject: Re: Power
Date: 2 Sep 2007 07:32:28
Message: <46da9f4c$1@news.povray.org>
I said it in my blog, and I'll say it again here:
http://www.maplin.co.uk/search.aspx?menuno=80119&MenuName=Power%20and%20Energy%20Monitors&FromMenu=y&worldid=-6&doy=28m8
Roughly £30.
> devices ?
Some devices actually use 0 W when off. (A few use 0 W even when on. For
example, the clothes iron, once it's hot.) Most things seem to use less
than 5 W while on standby.
And yes, the TV is one thing I still haven't got round to measuring!
Subject: Re: Power
Date: 2 Sep 2007 07:44:06
Message: <46daa206@news.povray.org>
Damn... pitty we can't use heat to do *useful* stuff!
Subject: Re: Power
Date: 2 Sep 2007 08:11:57
Message: <46daa88d$1@news.povray.org>
"Orchid XP v3" <voi### [at] devnull> a écrit dans le message de news:
46daa206@news.povray.org...
Watt?
Marc
Subject: Re: Power
Date: 2 Sep 2007 08:23:37
Message: <46daab49@news.povray.org>
> are, though.
Problem with conventional cookers is they tend to heat up your kitchen
too...
Subject: Re: Power
Date: 2 Sep 2007 08:25:26
Message: <46daabb6@news.povray.org>
You mean like to boil water to turn a big turbine that generates enough
electricity to run a city?
Subject: Re: Power
Date: 2 Sep 2007 08:27:21
Message: <46daac29$1@news.povray.org>
> excess of 3,000 W for the entire duration that you try to boil water with
> it.
That's about the most you will get out of a UK mains socket (230 V x 13
amps), but you'll probably find your electric cooker uses more when you have
everything switched on (it's usually wired directly into the distribution
board, so probably can't test it with your gizmo).
Subject: Re: Power
Date: 2 Sep 2007 08:46:49
Message: <46dab0b9@news.povray.org>
Believe it or not, but I started reading your blog a few days ago... But
I haven't gone through all the archives.
> Roughly £30.
Thanks
>> devices ?
> I should mesure this at home, to know for which devices it is meaningful
to put power off for energy savings (you know, global waarming etc.),
and for which devices it is not worth the effort.
5W on standby is quite a lot already : for one year (non-stop), it makes
roughly 44kWh, which is comparable to your kettle running at 3000W for
~14h (and how many cups of tea :-P ?) !
Thibaut
Subject: Re: Power
Date: 2 Sep 2007 10:00:47
Message: <46dac20f@news.povray.org>
Yeah, it is really.
I was quite surprised that my PC uses 4 W even when it's "turned off"...
(I'm not sure I *want* to know what my laser printer uses. That's
permanently turned on too!)
Subject: Re: Power
Date: 2 Sep 2007 10:04:02
Message: <46dac2d2$1@news.povray.org>
>> with it.
> have everything switched on (it's usually wired directly into the
> distribution board, so probably can't test it with your gizmo).
You're right: I can't. I have a gas cooker. ;-)
I just find it bizzare that this huge washing machine, spinning away to
violently that it's deafening to stand near and you'd probably be
injured if you touched it, uses about 5% of the power of a teeny little
kettle. Far out!
I'm currently measuring the fridge. Surprisingly, it uses a whole 100 W
when the compressor is running. (I was expecting lower.) OTOH, it
doesn't run for long...
PS. 230 V? I thought it was 250 V...
Subject: Re: Power
Date: 2 Sep 2007 10:19:18
Message: <46dac666@news.povray.org>
46dac2d2$1@news.povray.org...
> violently that it's deafening to stand near and you'd probably be injured
> if you touched it, uses about 5% of the power of a teeny little kettle.
> Far out!
Did you measure your washing machine while it is warming water?
Marc
Subject: Re: Power
Date: 2 Sep 2007 11:05:34
Message: <46dad13e$1@news.povray.org>
"Orchid XP v3" <voi### [at] devnull> wrote in message
news:46dac2d2$1@news.povray.org...
Heh, touché!  :-)
> Far out!
A. Didn't you say it uses 600W at final spin speed?  That's 20% of 3000...
B. It only seems bizarre because you already had decided on the way things
are before learning even the first fact about them (ie. do an experiment
like this, or study electrical theory).  It's really cool to go "wow!" and
be excited about new discoveries.  But you are kinda saying that things you
haven't seen should behave exactly as your head imagined it, rather than
work the way it always has done, only waiting for you to come along and
discover it.  Actually, now I think of it, you do that rather too often,
which is unfortunate because you limit yourself then...   :'-s
N'est-ce-pas?   ;-)
Subject: Re: Power
Date: 2 Sep 2007 13:08:26
Message: <46daee0a@news.povray.org>
Does it support Wake on LAN?  If so, then there's got to be some power
consumed to keep it awake enough to recognise a signal coming in saying
"wake up now".
Jim
Subject: Re: Power
Date: 2 Sep 2007 13:09:43
Message: <46daee57$1@news.povray.org>
>> still applies.  Doesn't mean things can't be more efficient than they
>> currently are, though.
> too...
I'm with you on that....we've got an old Wedgewood stove (very nice
stove) with dual ovens, but our evaporative cooler blows the burners, so
we have to turn the cooler off while using the stove, or the flames dance
everywhere.  That just makes it that much more difficult to cook in 100
degree+ temps.
Jim
Subject: Re: Power
Date: 2 Sep 2007 13:56:47
Message: <46daf95f$1@news.povray.org>
> "wake up now".
Yes, but 4 W!!!!  4 mW should be enough.
Subject: Re: Power
Date: 2 Sep 2007 14:00:09
Message: <46dafa29@news.povray.org>
> Far out!
And then you'd probably also be surprised how loud your speakers are when
you feed just 5 W into them.
> when the compressor is running. (I was expecting lower.) OTOH, it doesn't
> run for long...
IIRC the spec was changed from 240 +/- 10% to 230 +15% -5% (or something
equally stupid) to get us inline with Europe.  Doesn't your meter tell you
the voltage too?
Subject: Re: Power
Date: 2 Sep 2007 15:28:41
Message: <46db0ee9@news.povray.org>
>>> off"...
>> "wake up now".
Perhaps, depends on what other features the kit has, though.
I know, for example, that the system I have here at my feet has an ATX
board, which means the "power" switch is solid state rather than a
physical switch.  That means the board is powered all the time (when the
power supply switch is on at the back of the system).
Jim
Subject: Re: Power
Date: 2 Sep 2007 15:56:50
Message: <46db1582$1@news.povray.org>
> "wake up now".
It probably does support Wake on LAN. I really, *really* hope I have
that disabled though... (It's hard to tell!)
Subject: Re: Power
Date: 2 Sep 2007 15:59:41
Message: <46db162d$1@news.povray.org>
>> saying "wake up now".
I notice that, for example, the battery charger for my mouse continues
to charge even while the PC is "off". Also, the LEDs on my MIDI
interface still twinkle. And the USB light on my external audio card
still lights up. All of these things go out when I unplug the PC from
the mains. (Or just flip the switch on the PSU.)
Even so... that takes it up to, what, 19 mW? I don't know what the other
3,981 W is for...
(That's actually slightly unfair. The meter is only accurate to the
nearest 1 W, and I don't know what its rounding mode is...)
Convesly, the PC uses *less* power than I was expecting when turned on,
so...
Subject: Re: Power
Date: 2 Sep 2007 16:04:04
Message: <46db1734$1@news.povray.org>
>> to violently that it's deafening to stand near and you'd probably be
>> little kettle. Far out!
> when you feed just 5 W into them.
Oh... no, not really. I mean, sound vibrations are really, *really*
tiny. (Think about it; even when the sound is turned up painfully loud,
the speaker cones move by such a tiny amount you can't even see them
move at all!)
AFAIK, the reason we have 200 W amplifiers and speakers isn't so much
because it takes that much electricity to move air around, but to reduce
RF pickup in the speaker wire... (Or rather, to reduce the
*signifigance* of such pickup.)
> you the voltage too?
The mater claims 249.98 V.
Also, 49.97 Hz. (So much for "they keep it to exactly 50 Hz to help all
those clocks that use it". The frequency waivers all over the place!)
Subject: Re: Power
Date: 2 Sep 2007 16:05:11
Message: <46db1777$1@news.povray.org>
>> Far out!
Yes. Then it goes up to about 25% of what the kettle uses. (Mind you,
the kettle *boils* the water, the washing machine merely makes it
slightly warm, and takes several minutes to do even that...)
Subject: Re: Power
Date: 2 Sep 2007 16:06:42
Message: <46db17d2$1@news.povray.org>
Your powers of mental arithmetic greatly exceed mine.
> things are before learning even the first fact about them (ie. do an
> experiment like this, or study electrical theory).  It's really cool to
> go "wow!" and be excited about new discoveries.  But you are kinda
> saying that things you haven't seen should behave exactly as your head
> imagined it, rather than work the way it always has done, only waiting
> for you to come along and discover it.  Actually, now I think of it, you
> do that rather too often, which is unfortunate because you limit
I didn't say I don't believe it. I just said it seems really bizzare and
puzzling, that's all.
Gee, I wonder what our lawn mower uses...
Subject: Re: Power
Date: 2 Sep 2007 18:03:38
Message: <op.tx1rkc0ucs6ysw@e6600>
On Sun, 02 Sep 2007 22:05:17 +0200, Orchid XP v3 <voi### [at] devnull> wrote:
>> something equally stupid) to get us inline with Europe.  Doesn't your
>> meter tell you the voltage too?
Still within tolerance.
http://en.wikipedia.org/wiki/Mains_electricity#Voltage_levels
http://en.wikipedia.org/wiki/Mains_electricity#Frequency_stability
http://www.dynamicdemand.co.uk/grid.htm
FE
Subject: Re: Power
Date: 2 Sep 2007 22:48:49
Message: <46db7611@news.povray.org>
>> raise a single gram of water by one degree celsius, is the same amount
>> of energy required to lift that same gram of water about 387 meters in
Heat already does useful things.  For instance, it causes cute girls to
wear skimpy clothing.
John
Subject: Re: Power
Date: 2 Sep 2007 23:42:17
Message: <46db8299$1@news.povray.org>
On Sun, 02 Sep 2007 20:58:04 +0100, Orchid XP v3 wrote:
>  I really, *really* hope I have that
BIOS settings.  But it's not exactly easy to learn the wake-up code from
outside a NATted connection.  You've got to know the MAC address of the
system, IIRC.
Yep, according to http://en.wikipedia.org/wiki/Wake-on-LAN the magic
packet is set over a connectionless protocol (UDP, IPX) with "FF FF FF FF
FF FF FF" (in hex, hopefully obviously) plus 16 repetitions of the target
machine's MAC address, plus a 4-6 byte password.
So I don't think you have to worry about me turning your machine on from
half a world away.
Jim
Subject: Re: Power
Date: 2 Sep 2007 23:50:29
Message: <46db8485$1@news.povray.org>
	They just are.
	I find it interesting that you're focusing on power rather than energy.
How long do you spend boiling water vs how long is the washer running?
Atheism is a non-prophet organization.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Subject: Re: Power
Date: 3 Sep 2007 02:45:39
Message: <46dbad93$1@news.povray.org>
How about running an LCD panel, transmitting and receiving data from a
base-station 10s of miles away, interpreting incoming data packets, waiting
for key presses?  All for 10 mW.
The main point is that mainboard and PSU makers have no incentive to make a
low power and efficient "off" state.  Really, such a small fraction of
people/companies will make a decision based on the efficiency of the off
state it is not worth it at all.
Subject: Re: Power
Date: 3 Sep 2007 02:46:56
Message: <46dbade0@news.povray.org>
> 3,981 W is for...
Heat.
> so...
Is that with or without POV rendering? ;-)  Go on then, tell us how much it
would cost to do a 9 month render...
Subject: Re: Power
Date: 3 Sep 2007 03:04:20
Message: <46dbb1f4$1@news.povray.org>
> Oh... no, not really. I mean, sound vibrations are really, *really* tiny.
> (Think about it; even when the sound is turned up painfully loud, the
> speaker cones move by such a tiny amount you can't even see them move at
> all!)
Huh?  Even at normal listening volumes I can see the bass cones move on
mine...  Try feeding a 20 Hz sine wave in and watch the cone...  These are
only perhaps 6" drivers, nothing spectacular.  Mind you, I have never
noticed the tiny 2" cones move on my PC speakers.
> RF pickup in the speaker wire... (Or rather, to reduce the *signifigance*
> of such pickup.)
Huh?  You are saying that they deliberately make speakers less efficient so
that a higher voltage can be used to drive them?  I've never heard that
before.  Also I have never seen much "serious" hi-fi rated at anything like
200 W for home use.  IME 15 W per channel is plenty to fill a medium sized
room very loudly, perhaps if you live in a very large house and like
listening to music very loud you'd want 200 W.
Sounds ok to me, the voltage will fluctuate a lot depending on lots of
factors, like how much power people are using around you etc.  Try measuring
the voltage at different times of the day...
And you think your meter is accurate to +/- 0.03 Hz?  It's worth noting that
the national grid in the UK keeps all power stations interconnected so all
generators *must* make power at the same frequency.  If everyone in the
country turned on their kettles then the frequency and voltage would
probably drop significantly...
Subject: Re: Power
Date: 3 Sep 2007 04:09:52
Message: <46dbc150$1@news.povray.org>
> waiting for key presses?  All for 10 mW.
Well, the distance to the base station doesn't matter unless it's
wireless, then it's just the transmitter power.
>> the power supply switch is on at the back of the system).
> make a low power and efficient "off" state.  Really, such a small
> fraction of people/companies will make a decision based on the
> efficiency of the off state it is not worth it at all.
Very true.
Jim
Subject: Re: Power
Date: 3 Sep 2007 04:31:34
Message: <46dbc666$1@news.povray.org>
I was just illustrating that a normal mobile phone can do all that stuff
(both transmitting and receiving to the base station) for around 10 mW.
Subject: Re: Power
Date: 3 Sep 2007 14:03:05
Message: <46dc4c59$1@news.povray.org>
>> other 3,981 W is for...
> Heat.
>> on, so...
Without *anything* happening, it uses 110 W.
With my stonking-great video card with a fan the size of a plannet, it
uses 190 W. (Roughly. It waivers a lot.) During the boot sequence it
tops 280 W. (Presumably when all those electric motors all start up at
once...)
Actually, what the heck...
http://blog.orphi.me.uk/about/power
(Table of my work so far.)
Subject: Re: Power
Date: 3 Sep 2007 14:03:38
Message: <46dc4c7a$1@news.povray.org>
Hey, neat!
(Pitty it's too damn hot to do anything about it...)
Subject: Re: Power
Date: 3 Sep 2007 14:09:22
Message: <46dc4dd2$1@news.povray.org>
>> loud, the speaker cones move by such a tiny amount you can't even see
>> them move at all!)
> are only perhaps 6" drivers, nothing spectacular.  Mind you, I have
> never noticed the tiny 2" cones move on my PC speakers.
I have never seen any cone on any speaker move visibly - no matter how
much physical pain my ears were in. See, human ears are, like, *really*
sensitive...
> so that a higher voltage can be used to drive them?  I've never heard
> that before.
Yes.
> anything like 200 W for home use.  IME 15 W per channel is plenty to
> fill a medium sized room very loudly, perhaps if you live in a very
> large house and like listening to music very loud you'd want 200 W.
Hmm, I think my amplifier (nothing special) is rated at 60 W per
channel. (IIRC, into 8 ohms at 1 kHz.)
That's 60 W RMS by the way. Not like the "100 W" portable thing I once
owned that was actually 0.5 W RMS. ;-)
> measuring the voltage at different times of the day...
Wait... the *voltage* changes depending on how much you use it? That's
odd. I thought that potential difference was always constant, and it's
only *current* that changes...
>> all those clocks that use it". The frequency waivers all over the place!)
Actually, the instruction book (which is oddly large for such a simple
device) states the accuracy for all readings. I forget what it says for
the frequency...
Subject: Re: Power
Date: 3 Sep 2007 14:10:45
Message: <46dc4e25$1@news.povray.org>
> energy. How long do you spend boiling water vs how long is the washer
> running?
Well, that's the other part. The fridge doesn't use much power, but it's
permanently switched on. (Altough obviously it only draws any current
now and then.) So far it's clocked up a fair number of kWh...
Subject: Re: Power
Date: 3 Sep 2007 14:47:09
Message: <46DC57A9.1070307@hotmail.com>
> move at all!)
have you taken into account that the overlap in frequency resolution of
your ears and eyes is very small? You can not hear anything below 20 Hz
or see anything above 50 Hz.
At the same time the *rest* of Europe changed from 220 to exactly the
same specification. FYI the UK is *within* Europe.
>> Doesn't your meter tell you the voltage too?
RTFM The instantaneous frequency (how is that for an oxymoron) may vary,
but there will be exactly 432000 cycles in a day.
Subject: Re: Power
Date: 3 Sep 2007 15:13:34
Message: <46dc5cde$1@news.povray.org>
>> them move at all!)
And when I start up the engine of my car, the various parts move far too
fast for the eye to follow. But you *can* see the blur of moving
objects, and there is little doubt that they're moving. ;-)
Behold: Differential calculus. ;-)
Subject: Re: Power
Date: 3 Sep 2007 15:24:25
Message: <46dc5f69@news.povray.org>
Mine has a nifty engine that breaks down all sorts of bio matter into
simple carbohydrates and then burns them.  It's flexible enough to work
on matter as diverse as fruits, grains, and meats, although certain
spices have been known to give it trouble.  Also, you need a fair amount
of fiber mixed in, otherwise the whole thing can get clogged.
...Ben Chambers
Subject: Re: Power
Date: 3 Sep 2007 15:35:56
Message: <46DC6318.7020905@hotmail.com>
>>> them move at all!)
>> of your ears and eyes is very small? You can not hear anything below
>> 20 Hz
Why do you think that those frequencies are far above 50 Hz?
What sound does your motor make? Can you find the base frequency on your
keyboard?
Subject: Re: Power
Date: 3 Sep 2007 15:44:12
Message: <46dc640c@news.povray.org>
news:46dc4c7a$1@news.povray.org...
> Hey, neat!
Two words...
Swimming pool
Subject: Re: Power
Date: 3 Sep 2007 16:46:42
Message: <46dc72b2@news.povray.org>
I *think* the xmit power of a cell phone is a bit more than that...But
I'd have to check.
Jim
Subject: Re: Power
Date: 3 Sep 2007 19:40:09
Message: <46dc9b59$1@news.povray.org>
> I'd have to check.
Depends on the phone system. CDMA was originally designed to be an
undetectable transmitter for military use. IIRC, its power ranges
between 2.5mW and 5mw.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
