POV-Ray : Newsgroups : povray.off-topic : ze moon Server Time
3 Nov 2026 21:21:52 EST (-0500)
  ze moon (Message 1 to 32 of 32)
Subject: ze moon
Date: 28 Aug 2007 06:26:50
Message: <46d3f86a@news.povray.org>
Tried taking a pic when it was fully in shadow but was too dark to find
thru camera.  :(
Tim Cook
Version: 3.12
Download 'moon.gif' (61 KB)
Preview of image 'moon.gif'
Subject: Re: ze moon
Date: 28 Aug 2007 07:29:05
Message: <46d40701@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:46d3f86a@news.povray.org...
> thru camera.  :(
> Tim Cook
I can't get a stable-enough image.  I have a tripod, but it is set on grass
and with no lead for bulb exposure, I still must touch the camera for
time-lapse photography - and it moves, however careful I am.  My lens only
extends to 125 mm so I can't zoom very close -- not that a 400 mm would be
any  good anyway with the mechanical instability I have to deal with.
And for any exposure longer than a few seconds, I'd need a tracking mount.
1 degree Earth rotation per every four minutes -- bah.
Brian
Download 'mooneclipse1.jpg' (40 KB) Download 'mooneclipse2.jpg' (30 KB)
Preview of image 'mooneclipse1.jpg'
Preview of image 'mooneclipse2.jpg'
Date: 28 Aug 2007 07:40:47
Message: <46d409bf$1@news.povray.org>
"Brian Elliott" <NotForSpam@AskIfUWant> wrote in message
news:46d40701@news.povray.org...
>> thru camera.  :(
>> Tim Cook
> grass
BTW, I notice that your image is upside-down compared to mine (fuzzy, but
can still tell).  Shows that you're in the Northern hemisphere and I'm in
the Southern.  Here (Brisbane, Australia) the shadow grew from the
bottom-left corner until the last fingernail vanished top-right.  My pics
here were taken after peak coverage but before direct light has struck the
Moon yet.
Anyway, still disappointed I haven't succeeded in getting a good image.
Date: 28 Aug 2007 08:32:29
Message: <46d415dd$1@news.povray.org>
> grass
Hold a black card infront of the lens (but not touching) as you press the
shutter, then move the card away a split second after you release the
shutter.  That might help.
Date: 28 Aug 2007 09:27:21
Message: <46d422b9@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message
news:46d415dd$1@news.povray.org...
>> grass
On camera bulb setting, it holds its shutter open as long as the
shutter-release button is held pressed, irrespective of any light hitting
the meters.  Which means unfortunately, I have to keep a finger pressed on
it for the entire length time I want the exposure.  Or get a proper bulb
cord.  Actually I do have one with another old Pentax SLR that I have had
for many years, but its screw thread doesn't fit into THIS modern camera.
Dammit.
Date: 28 Aug 2007 09:47:25
Message: <46d4276d$1@news.povray.org>
> the meters.
Oh I see, I had assumed you were setting the shutter time manually as
anything more than 30 seconds is going to get blurry (as you suggested).
On my camera (Canon 300D) the remote shutter release is just a stereo 2.5mm
jack, easy to pick up from electronics stores and wire up 2 simple switches
if you can solder.
I suppose another alternative would be to use some sort of clamp to hold
down the shutter button, then you can use the black card trick while
attaching it and removing it.
Date: 28 Aug 2007 09:57:23
Message: <46d429c3$1@news.povray.org>
> mount. 1 degree Earth rotation per every four minutes -- bah.
http://strobist.blogspot.com/2006/09/on-assignment-how-to-light-comet.html
They have some nice guides to cheap camera tricks. I think they left out
the required distance from the center of the screw to the center of the
hinge, 11 and 7/16 inches, but it's there in the comments some place.
Date: 28 Aug 2007 10:14:26
Message: <46d42dc2$1@news.povray.org>
> 2.5mm jack, easy to pick up from electronics stores and wire up 2 simple
> switches if you can solder.
Simple way of getting around spending what they want for a remote. Might
want to look for a switch that closes one contact on a half press, and
another on full press to emulate the way the shutter button works. I
don't know how easy or difficult it would be to find a SPDT pushbutton
switch, though.
(Searching...Aha, found one!)
http://tinyurl.com/323qqz
Date: 28 Aug 2007 10:28:42
Message: <46d4311a$1@news.povray.org>
> another on full press to emulate the way the shutter button works. I don't
> know how easy or difficult it would be to find a SPDT pushbutton switch,
> though.
For mine I used two toggle switches.  I found ones where you could flick
them either way, to the left and they stay there (for long exposures) or to
the right and they spring back (for repeated fast shots).  I just mounted
them side-by-side in a small box and another 2.5mm socket, connected them up
with a pre-made 2.5 mm stereo lead (I hate soldering those tiny plugs and
they always come unstuck after a few weeks), and it all worked fine.
Date: 28 Aug 2007 10:31:41
Message: <46d431cd$1@news.povray.org>
Hmm, My guess now is not quite. Not enough information about that
switch, but more info gives that SPDT pushbuttons are usually on-on,
which means they don't have a center position. :/ if anyone can find a
SPDT pushbutton that is off-on-on let me know.
Date: 28 Aug 2007 10:36:56
Message: <46d43308@news.povray.org>
> to the right and they spring back (for repeated fast shots).
RS (rswww.com) part number 448-0810 if you are interested.
Date: 28 Aug 2007 10:57:10
Message: <46d437c6$1@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> a écrit dans le message de news:
> thru camera.  :(
We like the moon
coz it is close to us
we like the moooon!
but not as much as a spoon
'cause that's more use for eating soup
and a fork isn't very useful for that
unless it has got many vegetables
and then you might be better off with a
chop-stick
unlike the moon
it is up in the sky
it's up there very high
but not as high
as maybe
dirigibles or zeppelins
or lightbulbs
and maybe clouds
and puffins also I think maybe
they go quite high too
maybe not as high as the moon
coz the moon is very high
we like the moon
the moon is very useful everyone
everybody like the moon
because it light up the sky at night
and it lovely
and it makes the tide go and we like it
but not as much as cheese
we really like cheese
we like zeppelins
we really like them
and we like kelp and we like moose
and we like deer and we like marmots
and we like all the fluffy animals
we really like the moon
Sorry I can't resist
Date: 28 Aug 2007 18:49:07
Message: <46d4a663@news.povray.org>
news:46d4276d$1@news.povray.org...
Hmmm, <looks at camera>.  Pentax *iST DS here.  I can see it is a coaxial
socket, but my impression is the bore is too small for a 2.5mm jack.
Squinting into it with a magnifying glass, I think I can make out sleeve,
ring and tip contacts.  I think I have some in my old electronics junk box,
so it won't be too hard to check.
Uh-oh, carpentry and metalwork were my two worst subjects!  :-D
Date: 28 Aug 2007 18:49:49
Message: <46d4a68d@news.povray.org>
news:46d4311a$1@news.povray.org...
>> switch, though.
> to the right and they spring back (for repeated fast shots).  I just
> mounted them side-by-side in a small box and another 2.5mm socket,
> connected them up with a pre-made 2.5 mm stereo lead (I hate soldering
> those tiny plugs and they always come unstuck after a few weeks), and it
> all worked fine.
Soldering the plugs is never easy.  Not only are they small, but the
stainless finish on the tags often resists bonding with solder.  It can take
a lot of heat and time with the iron to get a metal bond.  By then your
cable insulation is damaged.
Date: 28 Aug 2007 19:03:16
Message: <46d4a9b4@news.povray.org>
"Sabrina Kilian" <"ykgp at vtSPAM.edu"> wrote in message
news:46d429c3$1@news.povray.org...
Sabrina, thanks!  Even with my limited ability, I should be able to put
together a barn-door mount.
Brian
Date: 28 Aug 2007 19:07:18
Message: <46d4aaa6@news.povray.org>
"M_a_r_c" <jac### [at] wanadoofr> wrote in message
news:46d437c6$1@news.povray.org...
>> thru camera.  :(
> We like the moon
> we like the moooon!
> chop-stick
> unlike the moon
> it is up in the sky
> but not as high
> as maybe
> or lightbulbs
> and maybe clouds
> we like the moon
> and it lovely
> we like zeppelins
> we really like them
You read tha book, now see tha show.  :-)
Download 'we_like_the_moon.swf.dat' (424 KB)
Date: 29 Aug 2007 02:47:35
Message: <46d51687@news.povray.org>
"Brian Elliott" <NotForSpam@AskIfUWant> a écrit dans le message de news:
46d4a68d@news.povray.org...
> take a lot of heat and time with the iron to get a metal bond.  By then
> your cable insulation is damaged.
You can scratch the tags finish with a cutter blade before soldering.
Marc
Date: 29 Aug 2007 04:08:59
Message: <46d5299b@news.povray.org>
> box, so it won't be too hard to check.
A quick google seems to suggest it actually uses the same 2.5mm plug as
mine...
http://www.digicaminfo.btinternet.co.uk/hmcablerelease.htm
Seems like you can pick ones up on ebay for £5-£10 anyway.
Or just get a small clamp from a DIY shop.  Like this one:
http://www.roger-russell.com/cameras/clamp.jpg
Depending on how much the shutter button is recessed you might need to
blu-tak something on to it so that the clamp works - but shouldn't be too
hard.
Date: 29 Aug 2007 05:33:54
Message: <46d53d82@news.povray.org>
The key to soldering this sort of thing is to use hollow core
solder with acid flux, or use paste flux. It doesn't hurt to rough
it up either, or to tin the end of the wire with solder first.
Date: 29 Aug 2007 07:15:44
Message: <46d55560@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message news:46d5299b@news.povray.org...
> mine...
Yeah, I found this today:
http://cgi.ebay.com.au/Shutter-Release-For-Pentax-ist-D-DS-DS2-DL2-MZ-6-ZX-L_W0QQitemZ230164995316QQihZ013QQcategoryZ43443QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
$8.99 Australian plus $6.99 postage.
> hard.
If either one costs basically just a few dollars, then might as well pick
the one designed for the job.  Besides, as I look at my camera sitting next
to the keyboard, I can see potential difficulties with a clamp, possible
scratch or damage to the camera, etc.
Date: 30 Aug 2007 04:33:32
Message: <op.txu5til8c3xi7v@news.povray.org>
And lo on Tue, 28 Aug 2007 11:26:36 +0100, Tim Cook
<z99### [at] bellsouthnet> did spake, saying:
> thru camera.  :(
Thanks for the inspiration
http://flipc.blogspot.com/2007/08/hello-autumn.html
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
Date: 30 Aug 2007 07:03:41
Message: <46d6a40d@news.povray.org>
>> thru camera.  :(
Oh noes, my NAME is on the internet, in plain public view! *puts on
tinfoil hat*
Tim Cook
Version: 3.12
Date: 30 Aug 2007 07:05:06
Message: <46d6a462@news.povray.org>
don't you know that with just one piece of information about you, like
your abbreviated first name, They can find out every detail about your
entire life and steal your identity/soul/ham sandwich?
Tim Cook
Version: 3.12
Date: 30 Aug 2007 07:17:31
Message: <46D6A847.7030605@hotmail.com>
Ah, your full first name is actually "Timothy" I'll tell the internet ;)
> they can find out every detail about your
as long as they don't steal your top hat.
Date: 30 Aug 2007 07:23:52
Message: <op.txvdy5lwc3xi7v@news.povray.org>
And lo on Thu, 30 Aug 2007 12:04:47 +0100, Tim Cook
Not my ham sandwich! The fiends. Oh and you know studies have shown that
tinfoil hats increase the power of any brain-altering rays. The original
premise was a scam concocted by the CIA/NSA/MJ12 to make anyone who
thought they'd need mind protection more susceptible to it.
Thoughts on the photos by the way?
Phil Cook
Date: 30 Aug 2007 12:30:26
Message: <46d6f0a2$1@news.povray.org>
Absolutely, and let me just say, it was delicious..... ;-)
Jim
Date: 30 Aug 2007 14:24:44
Message: <go2ed3lb6jen60csgjgq80kclh3i6e939j@4ax.com>
On Thu, 30 Aug 2007 07:03:23 -0400, Tim Cook <z99### [at] bellsouthnet> wrote:
>tinfoil hat*
The fact that I read your "About Me" page before makes this all the more humorous...
http://bellsouthpwp.net/z/9/z993126/e_about.html
Date: 31 Aug 2007 00:40:26
Message: <46d79bba$1@news.povray.org>
"Phil Cook" <phi### [at] nospamrocainfreeservecouk> wrote in message
news:op.txvdy5lwc3xi7v@news.povray.org...
Thet are most lovely!  I particularly liked the moon filtered through trees.
Date: 31 Aug 2007 00:42:00
Message: <46d79c18@news.povray.org>
news:46d6a40d@news.povray.org...
>>> thru camera.  :(
> tinfoil hat*
Don't panic, Flippy was obviously talking about Tim the Enchanter and Brian
of Nazareth.
Date: 31 Aug 2007 06:03:23
Message: <op.txw4vfj2c3xi7v@news.povray.org>
And lo on Thu, 30 Aug 2007 17:30:26 +0100, Jim Henderson
<nos### [at] nospamcom> did spake, saying:
Noooooooooooooooooooooooo and it had just the right amount of mustard too.
Phil Cook
Date: 31 Aug 2007 06:05:59
Message: <op.txw4zqp2c3xi7v@news.povray.org>
And lo on Fri, 31 Aug 2007 05:40:28 +0100, Brian Elliott
<NotForSpam@AskIfUWant> did spake, saying:
>> that tinfoil hats increase the power of any brain-altering rays. The
>> original premise was a scam concocted by the CIA/NSA/MJ12 to make
>> anyone who thought they'd need mind protection more susceptible to it.
Ta muchly.
> I particularly liked the moon filtered through trees. :-)
They came out better then I thought, or to be more precise of the
half-hourish spent arranging and taking the shots I got at least four I
was happy with :-)
Phil Cook
Date: 1 Sep 2007 00:40:41
Message: <46d8ed49$1@news.povray.org>
> too.
Yes, it most certainly did. :-)
Jim
