POV-Ray : Newsgroups : povray.off-topic : I cannot set up Github 2FA! : Re: I cannot set up Github 2FA! Server Time
1 Apr 2026 23:57:34 EDT (-0400)
Date: 11 Oct 2023 00:15:30
Message: <65262162$1@news.povray.org>
On 2023-10-08 07:12 (-4), Chris Cason wrote:
> If you think the issue is with Github, try using one of the sites that
> allows you to test TOTP, such as https://www.verifyr.com/en/otp/check
> (just enter junk in the label and issuer fields). Import the generated
> key then test it using the same page. It should work. If it does and you
> still can't get Github to work then that would be puzzling.
I tried verifyr.com, and it worked.  But GitHub still doesn't.
