POV-Ray : Newsgroups : povray.off-topic : Today's WTF : Re: Today's WTF Server Time
4 Oct 2025 16:49:00 EDT (-0400)
  Re: Today's WTF
Date: 27 Oct 2015 03:23:10
Message: <562f265e$1@news.povray.org>
Le 26/10/2015 23:43, Orchid Win7 v1 a écrit :
> I've always wanted to know... why is the framebuffer arranged so
> weirdly? Like, as you load a picture file, rather than filling from top
> to bottom, it seems to fill every Nth line...
Probably because Pal is an interleaved image: there is odd and even
frames. It was probably easier for the electronic in charge of
generating the lines in that order instead of obvious linear order.
IIRC the memory was not a dual access memory (that's expensive), so for
the chip to generate the signal, it might have been easier to read
consecutive address (an hardware counter is cheap).
Oh, it was a time in which accessing memory was easy: presents an
address on the address bus, read the data on the data bus. No column &
no row selection, no wasted cycles to wait for the data (no CAS Latency !)
