POV-Ray : Newsgroups : povray.off-topic : Other people dislike regexes too : Re: Other people dislike regexes too Server Time
28 Nov 2026 02:42:54 EST (-0500)
Date: 17 Jul 2012 06:03:49
Message: <50053884@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Well, you can say "I estimate that it's X", and I can say "well I
> estimate that it's Y", and without some actual facts to back any of this
> up, it's a bit of an empty discussion.
The difference is that I have actual extensive personal experience using
systems where regexes are very commonly used, and with people who use them.
Now, granted, I really don't know if you are really a unix guru who has
been using unixes all of his life, but I have got the impression that
you aren't.
> Also, if the most common search terms really are just literal strings,
> that doesn't really prove that regexes are a valuable search tool. It
> proves that /literal strings/ are a valuable search tool, no?
Please read again my original reply. The beauty of regexes is that if you
want to just search for a literal string, you usually need no ancillary
syntax at all, and if you need a simple wildcard or other simple pattern,
the search string still remains short and simple. And these two are by
far the most common usages for regexes.
A search (or other pattern matching) system that *only* supported literal
strings and nothing else would be significantly less useful.
> >> Or how about
> >>     dmesg | egrep '(s|h)d[a-z]'
> > If you want to build your straw man, at least use examples that conform
> > to your straw man. That's a bad example because it can be understood in
> > about 2 seconds.
> OK, so what does it do?
I can't believe that you are arguing that a regex is complicated because
you have never used regexes and don't understand their syntax.
Imagine this:
A: "Haskell sucks. It's really hard to understand!"
B: "How much Haskell have you ever written?"
A: "I once tried to write one small program but couldn't figure it out."
B: "Right."
Don't complain about the complexity of a syntax if you haven't even
learned the syntax.
> Come on, regexes are the number one use-case for the entire Perl
> programming language.
If you want to complain about perl, then complain about perl.
