POV-Ray : Newsgroups : povray.off-topic : Haskell vs Java: Building a ray tracer : Re: Haskell vs Java: Building a ray tracer Server Time
28 Nov 2026 15:12:44 EST (-0500)
Date: 3 Jul 2012 14:24:03
Message: <4ff338c3$1@news.povray.org>
Le 2012-07-03 10:29, Invisible a écrit :
> On 03/07/2012 02:35 PM, Francois Labreque wrote:
>> Le 2012-06-29 17:59, Orchid Win7 v1 a écrit :
>>>> Assuming your sphere is to the "right" of your ray starting point.
>>> No assumption.
>>> The result of this equation is the distance along the ray that you need
>>> to travel to get to the intersection. Therefore, the lowest solution is
>>> guaranteed to be the one you want. (Unless the camera is /inside/ the
>>> sphere, which won't work for several other reasons besides this one.)
>> No assumption, except for this one, that one, and these other ones,
>> too...
>> :P
> No assumption, assuming the camera isn't inside a solid object.
Huh...
Ok, and even though you're building this just for your own amusement, is
this limitation of the software fully documented?  Will you remember it
when you get to version 13 and you decide to add CSG support or POV SDL
parsing?  What if you mess up a rotation or translation and your camera
inadvertantly ends up inside an object?
Call me paranoid, but I'd prefer to expect the unexpected and program
for it right away, instead of simply assuming it won't ever happen.  At
the very least, you should test for it and bail out gracefully rather
than invoke undefined behaviour.
> If the camera /is/ inside a solid object, you need to adjust several
> things beyond just the ray intersection tests.
Agreed.  But that does not negate our original point that in order to
find the nearest intersection, you need to find them all.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
