POV-Ray : Newsgroups : povray.off-topic : Curious C / C++ defined behavior question : Re: Curious C / C++ defined behavior question Server Time
28 Nov 2026 02:09:16 EST (-0500)
Date: 22 Jun 2011 18:16:44
Message: <4e0269cc$1@news.povray.org>
On 6/22/2011 14:32, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> On 6/22/2011 13:07, Warp wrote:
>>> (but the end result is probably an abort()).
>> I would be very, very surprised if it wasn't undefined behavior to violate
>> the limits of the stack space.  There's just no good efficient portable way
>> of checking on hardware that doesn't do per-access checks (i.e., like a Z80
>> or something).
>    You can violate any space by poking with pointers and offset at wild,
> but the question was what happens if a function recurses too much and the
> function calls run out of stack space.
I was aware of what question I asked, yes. :)
>    The official standard probably defines it as either undefined behavior
> or implementation defined, but in practice what happens in most systems
> is that the C runtime asks the OS to increase the stack space for that
> process, the OS says nope, and then the C runtime aborts with some message.
In most multitasking systems with virtual memory running user-space
applications, yes. And my point is that I don't think there's anything in
the standard that's going to restrict C to that sort of machine.
In practice, under UNIX and Windows and such, yes, that's what happens. On
the Amiga 1000? On a Z-80 or 68000 or 8086? No, that's not what happens.
>    AFAIK in most systems the C runtime does indeed ask the OS to increase
> the stack space as needed (in a similar way as it asks the OS to increase
> heap space as needed).
Again, assuming you're talking about a multi-user virtual-memory-based
operating system with demand paging, implying the hardware has per-access
memory checking.  On systems without per-access memory checking, you don't
get that, and it would be odd to include in the standard something that
would have egregious overhead to enforce on low-end hardware.
Am I missing something?  Was I unclear, or were you just not paying as much
attention as you usually do?  (Serious question, not intended as a
criticism. I'm just trying to improve my communication skills.)
   "Coding without comments is like
    driving without turn signals."
