POV-Ray : Newsgroups : povray.off-topic : Wolfram's rule 110 bit : Re: Wolfram's rule 110 bit Server Time
1 Nov 2026 05:10:42 EST (-0500)
Date: 5 Jan 2011 12:05:42
Message: <4d24a4e6$1@news.povray.org>
clipka wrote:
> "An initial state (time t=0) is selected by assigning a state for each
> cell."
> (Wikipedia)
> Isn't that plain enough? You assign a state for /each/ cell. CA's don't
> seem to make any limitations on this.
Well, from that same page:
It is usually assumed that every cell in the universe starts in the same
state, except for a finite number of cells in other states, often called a
configuration. More generally, it is sometimes assumed that the universe
starts out covered with a periodic pattern, and only a finite number of
cells violate that pattern. The latter assumption is common in
one-dimensional cellular automata.
So you "generally" don't start with an infinite aperiodic pattern.
What I was really interested in was a proof that starting with a periodic
pattern (except a finite number of cells) didn't give more computing power
to the CA than starting with a single state (except a finite number of
cells). Because Wolfram is arguing about the computational power of Rule 110.
> Just name /any/ rule for that pattern
I don't think that works, because then it lets the CA calculate stuff a TM
cannot, and I think that would lead to a trivial disproof of the
Church-Turing thesis.
Now, a pattern that differs from a regular repeating pattern in only a
finite number of places? Sure, that's likely good.
But if Wikipedia says a repeating pattern for linear CAs is common, I'll
assume that's sufficient to quell my disquiet with the Rule 110 proof in
that regard. I'd still like to see a proof that having the repeating pattern
doesn't add computational power, which is what the Crawley paper was
apparently discussing. I'll have to take time to look at that closer.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
