POV-Ray : Newsgroups : povray.off-topic : Circular : Re: Circular Server Time
23 Nov 2026 13:28:02 EST (-0500)
  Re: Circular
Date: 28 Sep 2010 04:14:07
Message: <4ca1a3cf$1@news.povray.org>
Le 28/09/2010 10:09, Invisible a écrit :
> Question: If you have one of those gizmos that transforms rotational
> motion to reciprocating motion, what path does the reciprocating part
> trace?
> Answer: As far as I can tell, the path is
>   cos a + Sqrt(k^2 - sin^2 a)
> where k is the length of the connecting rod that is free to pivot. As
> you can see, that means that for large k, the path is approximately a
> sine wave. However, for small k it deviates significantly from a simple
> sine wave...
You are also forgetting in the equation the offset between the axes
(when the center of rotation is not aligned with the translation path).
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
