POV-Ray : Newsgroups : povray.off-topic : Electronics research : Re: Electronics research Server Time
29 Oct 2026 18:13:29 EDT (-0400)
Date: 24 May 2010 10:08:36
Message: <4bfa8864@news.povray.org>
On 5/24/2010 7:56 AM, Invisible wrote:
>>> Yes, the "label" is so that if you have a dozen subcircuits, you can
>>> tell which type each one is. It's _not_ for labelling a specific
>>> instance. (E.g., if you insert a register, you can't label it with a
>>> register name. You can only label it with the kind of register it is.)
>> Right, but sometimes it would be nice to have a label that identifies
>> the particular instance. At least, that's what I would expect when
>> clicking on the item.
> I won't disagree with that... ;-)
>>> All I know is that I seem to spend more time trying to figure out how to
>>> move a component slightly to the side to make more space than actually,
>>> you know, designing my stuff! >_<
>> Yeah, Routing can be a pain when moving components. You can turn on an
>> experimental feature where it allows you to sort of autoroute the
>> wires in some cases when moving a component, but I've found if you
>> move too far it will make bad connections. The algorithm that
>> autoroutes needs to be a bit smarter, but I think it may be an
>> instance of the halting problem.
> The Halting Problem is unsolvable. I doubt wire routine is unsolvable.
> Finding the "perfect" wire routine sounds a bit like the Travelling
> Salesman problem, which is NP-Complete, not *not* unsolvable. And a
> routing algorithm which doesn't alter topology and gives "reasonable"
> results ought to be quite possible, though possibly not easy...
I suppose that's correct.
http://www.freerouting.net/index.php?page=home
But can be rather difficult to calculate an optimal route. Of course,
the program above treats wires as physical obstacles.
On thinking a bit more about it, it's probably not horribly difficult.
> I tried it on Friday. Jesus, it sucks so hard! Eats RAM like candy,
> locks up for minutes at a time for no apparent reason, and doesn't even
> look particularly good anyway. Basically there's nothing to recommend
> it. (Plus I had to wait 30 minutes for the .Net framework to install...)
Yeah, I didn't get that far.... about the point where I had to drag and
drop components to the circuit was when I decided it wasn't a viable
solution.
>>>> http://www.falstad.com/circuit/
>>> I didn't even know that thing had logic gates...
>> It does. While it makes a great general circuit simulator, for
>> anything non-trival its far from ideal for logic simulation, though.
> Yeah, it's designed to show you examples, not for serious design work.
Yup, but a great learning tool :)
>> Now I'll finish it just to prove you wrong, so ... Nyah!
> Heh. I'd like to see that. ;-)
You'll see... you'll see.
~Mike
