POV-Ray : Newsgroups : povray.off-topic : Deconvolution : Re: Deconvolution Server Time
17 Oct 2026 18:58:19 EDT (-0400)
  Re: Deconvolution
Date: 18 May 2010 14:43:03
Message: <4bf2dfb7@news.povray.org>
scott wrote:
> My point was that the following are all valid solutions to the source
> image:
> {3,3,3,3,3,3,3,3}
> {2,4,2,4,2,4,2,4}
> {1,5,1,5,1,5,1,5}
> {6,0,6,0,6,0,6,0}
> In this case even the centre pixels could be anywhere from 0 to 6, and
> the "appearance" of the image is radically different in each case.
> Surely this is exactly the sort of detail a "deblurring" filter needs to
> recover, but it seems impossible.
Ok, I think I better understand what you were asking now.  To answer it
I think I should get into some stuff I had alluded to earlier (i.e. "use
an image prior").  This will probably be another semi-lengthy post, and
I'll break it into two parts:
1) Looking at your example in the frequency domain to get a good
theoretical grasp of what's happening.
2) Some discussion of the practical (as opposed to theoretical) issues
and solutions.
---------- 1) theoretical discussion
Throughout this section I'll be assuming that the image is "cyclic" so
that it's easy to analyze it in the frequency domain.  Fortunately your
examples above still work in a cyclic image.
As you've noted, it's possible to reconstruct multiple source images in
your example.  The reason for this is that you happened to choose an
"unlucky" kernel.  The reason why it's unlucky can be seen pretty easily
by looking at the kernel in frequency space.
In using the FFT on the kernel, I has to pad the kernel to make it the
same size as the image, yielding the padded kernel:
k = {0, 0, 0, 1, 2, 1, 0, 0}
If we now calculate abs(fft(k)), we get:
kf = {4.0, 3.4, 2.0, 0.6, 0.0, 0.6, 2.0, 3.4}
The key thing to notice here is that this contains a element which is
zero.  This means that the convolution kernel will "kill" certain
frequencies in the source image.  Basically, we'll get the same result
image for any source-image + c*ifft([0 0 0 0 1 0 0 0]). Unsurprisingly,
if we calculate 8*ifft([0 0 0 0 1 0 0 0]) we get:
{1, -1, 1, -1, 1, -1, 1, -1}
Which perfectly explains the nature of the examples you gave which all
convolve to the same result image.  IIRC most kernels in practice won't
contain exact zeros like this, and it turns out that even a slightly
different version of your kernel wouldn't have had this problem:
abs(fft([0 0 0 0.01 1.98 1.01 0 0]))
   = {4.0, 3.4, 1.98, 0.55, 0.04, 0.55, 1.98, 3.4}
It also wouldn't work on images which are an odd number of pixels across
(still assuming a cyclic image of course), which is possible why you
chose an image that was an even number of pixels across.
In the code snipped I gave to deconvolve your example, I dealt with this
issue in a very simple way:
ifft(fft(y)./(fft(k2)+1e-8))
It's the +1e-8 that was the key here, and in your example it's necessary
to prevent a divide by zero.  The effect of this is that the
deconvolution didn't "hallucinate" any frequencies that weren't in the
result image, even if they would technically also be correct
deconvolutions.  This is why it gave the {3, 3, 3, 3, 3, 3, 3, 3} answer
rather than one of the others you gave.
---------- 2) practical discussion
As far as I'm aware in practice having a kernel like yours which happens
to kill certain "unlucky" frequencies isn't really an issue.  What can
be an issue is that your kernel will suppress high frequencies to the
point that they fall below the accuracy of your camera sensor (or even
numerical precision).  This is why undoing a depth of field blur won't
always be possible (even if everything is at the same depth), since the
blur kernel in that case heavily suppresses high frequencies.  This
means that only a limited amount of deblurring is possible (as an aside,
there's also been work on designing camera apertures so as to minimize
this).
Fortunately in the case of blur from camera shake the kernel is normally
a bit more kind and doesn't destroy high frequencies quite so much.
What is a much bigger issue is that you don't know what the blur kernel
was, and getting it wrong can induce artifacts into the image.
Fortunately, we can do quite a bit by assuming a good image prior.  The
artifacts produced by an incorrect deconvolution tend to pretty
obviously not look like any "real" image.  There's some examples which a
good explanation here:
http://www.mathworks.com/products/demos/image/ipexblind/ipexblind.html
The best image deblurring algorithms I know use this insight pretty
heavily, and optimize a deconvolution by comparing how the statistics of
the deconvolved image compare the expected statistics of "real" images.
  It turns out that even pretty weak models of what real images look
like can help quite a bit and often give surprisingly good results.
In some sense the simple deconvolution method I gave was also implicitly
using an image prior which favors smoother images (for a very particular
definition of smoothness).
Did this answer your questions?
