POV-Ray : Newsgroups : povray.off-topic : Not a geek : Re: Not a geek Server Time
14 Oct 2026 09:35:23 EDT (-0400)
  Re: Not a geek
Date: 13 May 2010 12:47:15
Message: <4bec2d13$1@news.povray.org>
Invisible wrote:
> Right. My point was that if companies are just left to their own
> devices, they will all invent and deploy incompatible technologies.
Not really. One network will be bigger, and others will make their stuff
compatible so they can connect to the network. Or you build interface
converters.
Wow, good thing the internet uses ethernet everywhere, and we never had
these dial-up modems, ADSL, or cable modems to deal with.
> For something like washing machines, the fact that one machine is
> "incompatible" with another is largely irrelevant. For anything which
> could be described as a "network", compatibility is usually a Big Deal.
Which is exactly why the companies tend not to deploy incompatible
technologies, once a sufficiently good technology has proven itself.
The main reason the telephone networks in the USA were monopolies is they
were analog, and you had to carefully design the routing so that long
distance calls didn't go thru so many switches that you lost all quality.
> The other problem is assigned numbers. Can you imagine if there were
> three different postal services, each of which assigns completely
> different postcodes to the same addresses?
We have that here.  Well, at least two.  There's an "address" for postal
mail, and a "legal description" for ownership, taxes, etc.  The postal
address is technically only for mail delivery. The post office assigns it,
if they don't like the one the builder provided. (I.e., the post office
decides what the house numbers are, and they may rename the streets as
well.)  The legal description applies before any house is built that you
could deliver mail to, and applies to things that have either lots of
addresses or no addresses. It refers to a surveying map on file at the county.
FedEx and UPS and GPS driving directions and such all use the postal
address. Why wouldn't they? Why would UPS go to the trouble of making up
their own sets of addresses?
 > Even if the format of a
> postcode is standardised, you still need a single entity to assign them.
Because ethernet MAC addresses and worldwide telephone numbers are all
managed by the same entity.
> Also, networks usually require some kind of "capacity planning"
> activity. If you let independent parties all do their own thing, you'll
> end up with duplicated effort.
Yes. But that doesn't matter as much.
> All of this is presumably why almost all services are monopolies.
Maybe in your country. Our services fight like cats and dogs to avoid
letting the government make monopolies.
> (Still, I guess it's plausible that you could have a single entity in
> charge of *planning* a service, and have the service actually
> *performed* by several independant companies...)
Hey, welcome to Bellcore. Have a nice visit.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
