POV-Ray : Newsgroups : povray.off-topic : Processor speed : Re: Processor speed Server Time
3 Nov 2026 21:51:29 EST (-0500)
  Re: Processor speed
Date: 31 Oct 2008 15:59:14
Message: <490b6392$1@news.povray.org>
Orchid XP v8 wrote:
> Right. So just to make sure I understand this... you're saying the cache
> is managed in chunks of 32 bytes at a time? Like, if you fetch 1 byte of
> data from memory, 32 bytes will be loaded into the least recently used
> cache line? (Or whatever the cache policy is.)
That's how I understand it. I believe it's more accurate to say that the
bus between the memory and the registers is actually 32-bytes wide. I
may be mistaken in that, tho.
> Are the cache lines aligned in any sort of way? (I'm wondering if it
> grabs 32 bytes at the nearest 32-byte boundary or not.)
I'm also pretty certain it is on 32-byte boundaries. Otherwise, the
addressing logic winds up being slower than the time you save caching stuff.
