POV-Ray : Newsgroups : povray.off-topic : C++ questions : Re: C++ questions Server Time
23 Nov 2026 18:49:13 EST (-0500)
  Re: C++ questions
Date: 27 Sep 2008 06:58:13
Message: <48de11c5@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> >> Oh, er... can you have a vector of vectors? Or would it have to be a
> >> vector of vector pointers?
> >   It's perfectly possible.
> OK. I just wasn't sure if it's permissible for the element type to be of
> variable size, that's all.
  As Fredrik pointed out, a type in C++ always has the same size.
"std::vector<int>" is an example of a type, and each instance of it
will have the same size.
  In fact, there's a keyword in C++ (and C) which can be used to get
the size (in bytes) of a type, at compile time: sizeof(YourType)
  The std::vector class itself consists of a pointer and maybe a few
data members. Its contents do not change. What the vector does is that
it allocates memory dynamically. That allocated memory does not affect
the size of the std::vector object.
  Anyways, these are technical details you don't have to worry about.
