POV-Ray : Newsgroups : povray.off-topic : My first C++ program : Re: A test Server Time
12 Oct 2026 18:59:18 EDT (-0400)
  Re: A test
Date: 24 Sep 2008 09:35:12
Message: <48da4210$1@news.povray.org>
Warp wrote:
>   Or I could simply make an overloaded version of the fold function which
> takes an iterator range.
Now what happens if you want to only process elements having some
arbitrary property? (E.g., only the odd numbers.) Or what if the
function you're trying to fold is non-associative, and you want to
rearrange the list so the elements can be processed in a different order?
The idea behind Haskell's data processing function is that each function
does *one* job, which makes it possible to combine them in any possible
way. (This is not unlike the Unix idea of implementing complex
functionallity by "piping" data between multiple simple utility
programs, as seen in millions of shell scripts.) As soon as you start
trying to rely on particular pre-combined functions, you lose that
flexibility.
With lists in particular, the new stream-fusion library means that most
if not all common combinations of list processing functions get
automatically fused together by the compiler.
There used to be a function called "concatMap", which does the same
thing as "concat . map", but more efficiently. It's actually still there
for compatibility, but with stream fusion you don't actually need it any
more [because "concat . map" gets optimised into the same thing].
If you really need killer performance on a critical region of your
program... well actually, in that case you probably wouldn't be using
lists anyway, but still... if you really need killer performance
somewhere, you can manually fuse if the compiler somehow fails to do it
for you. But otherwise, the code is much more maintainable if you don't.
