POV-Ray : Newsgroups : povray.off-topic : Hypothesis: OO does nothing for reusability : Re: Hypothesis: OO does nothing for reusability Server Time
30 Oct 2026 10:53:32 EDT (-0400)
Date: 21 Aug 2008 11:47:57
Message: <48ad8e2d$1@news.povray.org>
Invisible wrote:
> Darren New wrote:
>> (I count "reuse" as the ability to take code already written and use
>> it in ways not anticipated when it was written.)
> Isn't that "extensibility", not "reusability"? You want to *extend*
> existing software to do something it wasn't designed to do.
Well, the claims of the OO proponents were that the extensibility (via
inheritance) would make the reusability much better. (Along with the
encapsulation, of course.)
Extensibility is actually something different, when speaking in
technical terms. Extensibility is the ability to add your own
domain-specific stuff to your environment and have it have all the
powers and basically be indistinguishable from the stuff that is
privileged to come with the environment. E.g., there's nothing built-in
functions can do that you can't, there's nothing programs that come with
the OS can do that your programs can't, etc.
>> But particular OO libraries are IME limited to doing exactly what they
>> were designed to do, without really being any more extensible than a
>> procedural language with carefully crafted callbacks.
> You're still talking about "extensible", not "reusable".
Well, no.
> With any half-decent OO language, this problem immediately goes away.
Not really. Not in C++ or Java, for example. (Yes, you can do it in C++,
but not because of the OO nature of it.)
> You can now write a sorting algorithm once for each container type (or
> even once overall if you desire, but that's probably less efficient) and
> you're done. This one sorting algorithm can then be reused anywhere you
> need to sort data.
I can already do that in C. Look at the qsort routine. You're not
talking about OO here. You're talking about how statically typed
something is regardless of whether it's OO.
> These days OOP isn't the only paradigm that actually offers this
> benefit, but the benefit is real none the less.
There are definitely benefits to OO. Being able to reuse existing code
by subclassing it and overriding just that which isn't quite right (when
the original designer hadn't anticipated you'd subclass it in that way)
isn't one of them.   Certainly less so than some of the other mechanisms
that have been invented without nearly as much hype.
