POV-Ray : Newsgroups : povray.off-topic : Yes, that time : Re: Yes, that time Server Time
18 Nov 2026 09:50:56 EST (-0500)
  Re: Yes, that time
Date: 17 Jun 2008 10:59:37
Message: <4857d159$1@news.povray.org>
> Is that also why my LCD here at work is about 2°C warmer at the top than
> the bottom?
Most likely just because heat rises :-)  Don't know where the LEDs are on
your LCD, or it may even be a CCFL in there...
> But it doesn't ripple all that much... hmm.
That's because it has a touch screen on the front of it - not as easy to
distort the actual LCD.
> I wonder... If you wanted to go all mad-scientist, how hard would it be to
> concoct a chemical which forms a vaguely-functional LCD?
Read the first few parts of:
http://en.wikipedia.org/wiki/Liquid_crystal
It's relatively easy to get a "functional" liquid crystal nowadays, the
extremely hard bit is creating one that works over a wide temperature range,
gives a high contrast ratio, has a fast switching time, etc.
> [NB. I once tried to make an oscilator at school. The damn thing never
> actually produced any sound. It did, however, heat up the two power
> transistors with remarkable efficiency - I would never have believed that
> 9V was enough to burn your finger on...]
I tried to make a simple AM transmitter, my first design transmitted about
5cm.  I then proceeded to make the supply voltage higher and higher (in the
end I think I had 5 or 6 30V supplies in series) and eventually I made it
transmit about 3 metres while probably using half of the school's power :-)
