Invisible escribió:
> I have the following HTML:
> <span>A<span>B<span>C</span>D</span>E</span>
> I've set up some CSS to put borders round span elements. It's supposed
> to display as follows:
> |A|B|C|D|E|
> However, no matter what I do, it actually renders like this:
> |A|B|C|D|E|F|
> Any idea how I fix this?
I tried giving it both padding and margin, but didn't get what you
wanted. However, display:block did the trick. It makes the span behave
just like a div (and a div with display:inline would be identical to a
span). You need to give it explicit width though; the default is 100% of
the container block (the whole page in my test).
