POV-Ray : Newsgroups : povray.object-collection : RoundEdge 1.3.1: elimination of torus artifact Server Time
13 May 2025 04:40:53 EDT (-0400)
  RoundEdge 1.3.1: elimination of torus artifact (Message 1 to 2 of 2)
Subject: RoundEdge 1.3.1: elimination of torus artifact
Date: 25 Jan 2016 13:20:00
Message: <web.56a666251a5eb08b566b73360@news.povray.org>
See
http://news.povray.org/povray.general/message/%3C5682b65f%241%40news.povray.org%3E/
This artifact rears its ugly head when merging a torus and a cylinder into a
very fat discus-like object.  See p.b.i for an illustration.
I thought surely I had discovered this problem while I was fiddling with the
meniscus code for CoffeeMug in 2013.  But checking the dates on my test files,
it turns out I'd discovered it in 2008, a mere three days after starting work on
RoundEdge.  (I'm not too surprised at this recall failure; meat-based brains are
known to be unreliable.)
I almost immediately realized why my torus-cylinder merges showed this artifact,
which is why I never reported this as a bug.  But bug or not, it is annoying, so
it is fixed in RoundEdge 1.3.1.
http://lib.povray.org/searchcollection/index2.php?objectName=RoundEdge&contributorTag=Cousin%20Ricky
Why I didn't take steps to correct the problem in RoundEdge 1.0 is a mystery.
Another meat brain failure, perhaps?
Subject: Re: RoundEdge 1.3.1: elimination of torus artifact
Date: 25 Jan 2016 14:25:14
Message: <56a6769a$1@news.povray.org>
Am 25.01.2016 um 19:15 schrieb Cousin Ricky:
... and it is also fixed (kind of, that is) in POV-Ray 3.7.1 ;)
You may want to change your RE__torus macro as follows:
#macro RE__torus (RMajor, rMinor, Use_merge)
  #if (RMajor * 2 < rMinor & Use_merge)
    #if (RoundEdge_Inc_Temp >= 3.7.1)
      torus { RMajor, rMinor merge }
    #else
      merge
      { difference
        { torus { RMajor, rMinor }
          sphere { 0, re_R }
        sphere { 0, (re_R + rMinor) / 2 }
  #else
Specifying the "merge" keyword after the major & minor radii of a torus
will cause interior surfaces of a spindle torus to be suppressed.
The "difference", "intersection" and "union" keywords also work there as
you might expect (though "union" is only included for completeness, as
it's the default anyway).
