POV-Ray : Newsgroups : povray.object-collection : Compliance: local variable scope Server Time
13 Jul 2025 07:33:24 EDT (-0400)
  Compliance: local variable scope (Message 1 to 4 of 4)
Subject: Compliance: local variable scope
Date: 8 Jul 2008 17:40:00
Message: <web.4873de0a2d11efca5d2e82c0@news.povray.org>
In order for an object to be compliant, can I simply change all the variables in
the include file to local scope? Or, must I also rename them all using the
object's abbreviation?
I'm guessing that best practices is to do both.
-Mike
Subject: Re: Compliance: local variable scope
Date: 8 Jul 2008 19:10:05
Message: <4873f3cd$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.4873de0a2d11efca5d2e82c0@news.povray.org...
> variables in
> -Mike
The main objective is to avoid collisions with names chosen by someone using
your include file, so in theory either would normally suffice and could be
considered compliant. On the other hand, I've started using the unique
prefix for the names of all identifiers (even local ones) because I noticed
some circumstances where it removes some less usual potential conflicts.
Normally someone using your include file would simply include it in their
own higher level scene file which should make using identifiers in your
include file with a local scope quite safe. However, it's also possible that
they may elect to do things a little differently, for example by adding
their own stuff into your include file or by copying and pasting parts of
your file into their own scene file. In these circumstances there is
potential for the names you use in your local definitions to conflict with
their own global declarations. I would therefore say that it is preferable
to use the unique prefix everywhere as it makes it that little bit more
robust in a wider range of circumstances.
Chris B.
Date: 8 Jul 2008 22:35:01
Message: <web.487423b4f1a99dbbe2244ea70@news.povray.org>
Thanks. I will labor to do so in my projects in the future.
-Mike
Subject: Local variable scope
Date: 31 Aug 2008 08:47:36
Message: <48ba92e8$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4873f3cd$1@news.povray.org...
>> variables in
>> the
> I would say that it is preferable to use the unique prefix everywhere as
> it makes it that little bit more robust in a wider range of circumstances.
Ricky has documented a condition (over on povray.general) that means we'll
need to actually make this a requirement for contributions to the Object
Collection. He's pointed out that if the person is already using a
particular Macro name in their scene files or include files (Macro names are
always global in scope) and uses an object from the collection containing a
local variable with the same name, then they will get errors when they try
to render it.
For future contributions to the Object Collection can everyone please
therefore prefix all variable names (even for local variables) with the
unique prefix by which their contribution is known (same as with global
declarations). Over time we'll need to go through and retro-fit that into
existing contributions.
Chris B.
