I see that there is interest in the Object Collection among new users
and old timers who have returned. You may or may not know that the
Object Collection is a formal repository that was hosted on an entire
subdomain of povray.org, namely lib.povray.org. Early in 2021 there was
a site-wide server crash, and while most of the site was quickly
restored (mostly), lib.povray.org remains offline.
Most of the user contributions have been mirrored at
https://github.com/LeForgeron/PovContributions
but the infrastructure of lib.povray.org, which included user
registration, upload, search, and general instructions, is not
duplicated there.
As a formal repository, the Object Collection has certain rules. If you
wish to submit your objects to lib.povray.org when it comes back online,
you'll need to be familiar with these rules to make whatever edits are
necessary to prepare your files for submission. I will summarize them here.
The main considerations are the license, namespace compliance, and what
files should be bundled.
TL;DR
- All modules must be licensed under the LGPL.
- All modules have a unique name and an optional unique prefix.
- All filenames and most identifiers must be prefixed with the module
name or prefix to avoid namespace collisions with other Object
Collection modules.
- Scene files and include files may contain ASCII only.
- Your submission should include a sample image and a 160x120 thumbnail.
LICENSE
All contributions must be licensed under the GNU Lesser General Public
License (LGPL). To that effect, every .inc and .pov file must contain a
comment with this text:
This file is licensed under the terms of the CC-LGPL
This exact wording is required by the upload software; you will not be
allowed to upload your module without it. The "CC" is due to Creative
Commons having once provided an online deed for the GNU licenses.
If you borrow someone else's work, you will need to certify that you
have the legal right to republish it under the LGPL.
You will note that the above required text does not specify a license
version. However, the link in the Object Collection documentation
(currently offline) does point specifically to version 2.1 of the LGPL.
No formal decision has been made about upgrading to version 3.0.
MODULE NAMES
Every module has a unique name and, optionally, an additional unique
prefix, which are registered with the upload software. The names and
prefixes must begin with a Latin letter and comprise only letters and
digits--the same rules as for POV-Ray identifiers, except underscores
are not allowed. The name and prefix are not case sensitive; for
example, if there is a module called "NetBall," it is not allowed to
create a new module called "NETball."
NAMESPACE COMPLIANCE
One of the goals of the Object Collection is interoperability. The
Collection has naming standards to avoid namespace conflicts between
modules. Modules are rated for compliance on a scale of 0 (not at all
compliant) to 3 (fully compliant). By default, only level 3 modules
appeared in search results.
For compliance level 3:
1. All filenames must begin with the module name or prefix, followed
by either a dot or an underscore. This allows all level 3 modules
to share the same directory, so your Library_Path list doesn't grow
out of hand. Filenames should be all lowercase for operating
system portability.
For example, if the name and prefix are NetBall and NB,
respectively, then netball.inc and nb_example.pov are acceptable
filenames. netball1.pov and nb-example would not be accepted, as
the name or prefix is followed by a character other than a dot or
an underscore.
2. All identifiers introduced in the main library files must be the
module name or prefix, or must be prefixed with the module name or
prefix followed by an underscore. Due to namespace scope leakage
within POV-Ray, this rule must also apply to #local identifiers and
any function formal parameters other than u, v, x, y, and z. Macro
formal parameter names are exempt from this rule, as are any demo
scene description files you may bundle to demonstrate how to use
your module.
Using the above example, Netball and NB_BallRadius are acceptable
identifier names, but NBRadius is not.
3. A third rule that has been proposed, but not formally adopted, is
to require all identifiers to have at least one uppercase letter.
The modules are currently self-rated by the author. If the author rates
their module at compliance level 3, the upload software will reject
filenames that are out of compliance. Identifiers are not scanned for
compliance at this time.
No detailed guidance has been provided for self-rating your module at
compliance level 1 or 2.
FILES TO BUNDLE WITH YOUR SUBMISSION
These are not hard and fast rules, but are typical of Object Collection
contributions.
- A .inc file containing the necessary macros and other features.
- An example .pov scene description file demonstrating how to use your
module.
- A 160 by 120 pixel thumbnail image to be displayed on the Object
Collection search page and index page. The name of this file must be
the module name or prefix, followed immediately by _thumbnail, dot,
and the image type extension; for example, netball_thumbnail.jpg or
nb_thumbnail.png.
- A main image file to be linked to the thumbnail. The name of this
file must be the module name or prefix, followed immediately by dot
and the image type extension; for example, netball.jpg or nb.png.
- HTML documentation. In order to be automatically linked to the Object
Collection search page and index page, the name of the file must be
the module name or prefix, followed immediately by .html; for example,
netball.html or nb.html.
HTML documentation is optional; many existing contributions just have
the documentation as a block comment within the main include file.
Files are limited to the following types: .bmp, .css, .csv, .gif, .htm,
.html, .inc, .ini, .jpeg, .jpg, .js, .mac, .mcr, .mdl, .pgm, .png, .pov,
.ppm, .tga, .tif, .tiff, .txt
CONTENTS OF SDL FILES
As of the time of the crash, the upload software allowed only 7-bit
ASCII characters in .inc and .pov files. Greek, Cyrillic, special
characters, etc. could only be used via the "\u" notation. For an
example of this, see:
https://github.com/CousinRicky/POV-BrightStar5/blob/main/brightstar5.inc
and find bsc5__s_Gr_chars.
OTHER CONSIDERATIONS
There are other considerations, such as keyword list and topic
categories, but these will not be important to detail until the Object
Collection site comes back online. If you are interested, the upload
instruction page is archived at:
https://web.archive.org/web/20150923194204/http://lib.povray.org/usersguide/04contributing.html
Note that these instructions have an incorrect name for the license.
The name has been corrected since that page was last archived.
ADMINISTRATION
The initial administrator of the Object Collection has not been heard
from since 2009, and there has been no successor. So far as I can see,
there is no formal process in place for overseeing the collection. See
the thread "License reassessment and other matters" for my thoughts on
this situation.
I have additional comments on these rules.
On 2023 21:37 (-4), Cousin Ricky wrote:
> LICENSE
> [snip]
Creative Commons has since removed the deed from their website, and the
link now redirects to gnu.org. It has been proposed that the "CC" be
removed, but the upload software had not been updated to accept this as
of the time of the crash.
> [snip]
> 2. [snip] Due to namespace scope leakage
> [snip]
Note that identifier name collisions are possible even with modules
self-rated at level 3. There was some sort of process for verifying
compliance, the details of which I do not know, but the only modules so
"verified" happen to have been submitted by the administrator
himself--in other words, *none* of the modules can be considered
verified. As my father once told me, "A priest does not hear his own
confession."
I am very careful about keeping my own contributions level 3 compliant,
yet I have discovered noncompliance in my own code. To my knowledge, no
one has independently verified my modules, so there could still be some
stray violations. And I know for a fact that some other contributors
have been less diligent than I. Caveat emptor.
Add to this, that the scope leakage of #local variables was not
discovered until about 50 modules had already been contributed, so many
of those were rendered de facto non-compliant when the rule was changed.
Thus far, function formal parameters are not specifically addressed in
the Object Collection rules, but these newsgroups are scattered with
POVers who have been burned by using an identifier that just *happened*
to share a name with a function parameter in some include file. Caveat
emptor.
LeForgeron's mirror does not record the compliance level of the modules,
but from the information I had collected previously, all of the
contributions were self-rated at level 3 except for the following:
ConvexLens, TextureGen, and TextureGen4. These 3 modules should *not*
share a directory with other Object Collection downloads. Two other
modules were once self-rated as non-compliant, but they have since been
edited into full compliance. All remaining modules are fully filename
compliant, and may share a single directory, even if their identifiers
are not compliant. All this is to say that you'll probably want to make
your contributions namespace compliant as well.
I hope this will change.
hi,
for now, yes. however, it "is being looked at".
? the thread "License reassessment and other matters" for my thoughts on
> this situation.
I share the impression that the OC has been handled without such a laid down
procedure/process. quick scan in 200 most recent threads did not find the
above, will try find/read it. thoughts on how (future) administration
can/should be made more "robust" will be useful/appreciated (but see below).
thank you. will look at the "self-rated" vs confirmed.
ok, thanks. will add some utf8 to the "mock" object I use while working on
submission.
fyi. since the crash, no one had (apparently) offered help restoring it (Chris
is .. running at capacity much of the time, aiui), so late last year I jumped
in. fwiw, it (site code) is an excellent example of why code ought not be
"intertwined" with global variables. anyway, there were[*] other, real problems
regarding the database, it seems that at least one of those with admin access
missed their calling as comedian. :-( it seemed opportune to move the OC db
from the server-based implementation to a file-backed one, without changes to
the UI as such (except fewer admin options). the current state of things: a
fair few things done, but more still to do. (sorry to be so .. oblique)
[*] and, to an extent, continue to be. would, personally, prefer the db schema
fully normalised, but cannot afford to break the Javascript + stuff.
admin changes - little from the web UI, only suspending versions/users/feedback
and "health check", for all else person will have to log in to an admin account,
and use utility(-ies) provided.
regards, jr.
Thank you for this review, I really didn't know about the formal side of
this group. Now I see that this is the wrong place for my previous
posts, sorry for the inconvenience.
YB
hi,
> > LICENSE
> > [snip]
so what, exactly, are/ought-to-be the implications? the submission as such, and
aiui, would still require some form of (permissive) licensing by the author(s).
what, ideally, would the check upon upload look for?
regards, jr.
>>> LICENSE
>>> [snip]
I am not proposing that we move away from the LGPL. I'm thinking that
the upload software could accept "GNU-LGPL" as well as "CC-LGPL," that
the phrase "Creative Commons" be dropped from the documentation on
lib.povray.org, and that the documentation link directly to gnu.org.
But as long as the Creative Commons link redirects to gnu.org, this is
not a major issue.
I got some files mixed up in my mind. The README file that comes with
each download has been updated. I cannot tell if the instructions have
been updated.
hi,
> >>> LICENSE
> not a major issue.
after a cursory look at the code, I think the upload could be modified to accept
either with little work. re the whole issue, decisions are for Chris, will
bring it up at the earliest opportunity.
regards, jr.
hi,
> TL;DR
> Collection modules.
the GNU/CC licensing and the ASCII only issues have been mentioned, and, final
decision pending, will be acted on. there is one new, added requirement now:
the descriptive text, ideally including documentation and scene/.inc file
comments, is expected to be in English.
the reason is a legacy of several dozen objects submitted in Spanish, only.
those will likely remain unavailable until translated. (any native speakers, or
fluent + conversant with Central American cultures, with a little time on their
hands ? ;-))
> edited into full compliance. ...
so, in the "legacy" data for TextureGen I see three versions, with the following
'standardsconformance:status' values recorded (in order): 3:2, 0:1, 1:1. :-(
seems to me that when an administrator assesses an object / version for
compliance, all versions need taking into account, and there should only be "one
score", per object ?
(if you have a "private" list of assessments of various contributions, that
could (perhaps) serve as base going forward (o/wise most of the db's content
will remain "self-assessed"))
regards, jr.
hi,
> decision pending, will be acted on. ...
the licensing mention/requirements have been updated, the text only uses 'GNU',
and files can be submitted with either 'GNU-LGPL' or 'CC-LGPL.'
the remaining item (another request for help :-)) is replacing the
'cc-LGPL-a.png'; would appreciate if you could suggest (locate! :-)) a suitable
file; same WxH, and ideally monochrome (the latter just a personal preference).
tia.
elsewhere you wrote:
> I have updated the procedural wood texture I used for my hand plane,
> prepared it for the Object Collection when it comes back online ...
currently faced with .pov etc files having different mimetypes/'signatures' if
they include utf-8. to (mis)use Leroy's phrase: 'Have Fun!' </grin>
regards, jr.
> not a major issue.
... And the Creative Commons link is now dead. CC-LGPL apparently is no
longer a thing.
Regarding the LGPL version, section 13 of the CC-LGPL allows the user to
choose any version of the LGPL if the work does not specify a
version--which is the case with the Object Collection's required license
text.
While the CC-LGPL remains valid for existing contributions, the GNU-LGPL
and a similar license will be offered going forward. Stay tuned...
