POV-Ray : Newsgroups : povray.object-collection : Vector images Server Time
16 Oct 2026 15:59:46 EDT (-0400)
  Vector images (Message 1 to 7 of 7)
Subject: Vector images
Date: 28 Feb 2019 12:10:12
Message: <5c7815f4$1@news.povray.org>
I created some vector images that I (after converting them to PNG) used
for axis, label, measurement, etc. graphics. I want to keep them with my
collection, but I don't think I am allowed to upload them. Would it be
possible to make an exception for a vector format of some type? I use
SVG, but I understand that can be a risk since it is possible to insert
JavaScript into it. Maybe a different format would be better? Thanks.
Mike
Subject: Re: Vector images
Date: 2 Mar 2019 14:42:26
Message: <5c7adca2$1@news.povray.org>
The JavaScript risk is probably not a big issue, since JavaScript can
also be inserted into HTML documents.  The biggest problem with the
Collection right now is access to the server; the Collection
administrator (Chris Bartlett) has not been heard from in almost 10
years.  Le Forgeron has some level of access, but there's only so much
he's permitted to do.
Date: 3 Mar 2019 11:00:05
Message: <5c7bfa05$1@news.povray.org>
On 3/2/2019 2:42 PM, Cousin Ricky wrote:
> Chris Bartlett
Does he own the server the collection is residing on?
Mike
Date: 5 Mar 2019 23:11:50
Message: <5c7f4886$1@news.povray.org>
>> Chris Bartlett
I do not know.  I doubt it, though; it would be highly unusual for a
server to be running this long with no sign of its owner.  At the very
least, bills must be paid and/or collected.
Date: 9 Mar 2019 09:40:01
Message: <web.5c83cf3eaed5b1df765e06870@news.povray.org>
> Mike
How large are the SVG files?
Aren't they all just a text-based format like HTML?
You could rename them to .txt and likely post them.
Alternatively, you can embed them into the header of a jpg file of the same
image.   Then I think you can just rename it to .svg and it's instantly useable
as one.
Date: 13 Mar 2019 02:07:59
Message: <5c889e3f$1@news.povray.org>
>> Mike
> as one.
They are not very large at all. Renaming the extension is a good idea. I
will try that.
Mike
Date: 4 Mar 2021 06:05:00
Message: <web.6040be19aed5b1dfea5d10390@news.povray.org>
> >> Mike
> > as one.
> will try that.
> Mike
Hello,
As I saw elsewhere here, you can just add .txt (or .dat) at end : file.svg ->
file.svg.txt
