I have extracted some of the data fields from the Yale Bright Star
Catalogue and converted them to SDL. This catalog contains all
nighttime stars of magnitude 6.5 and brighter (roughly all nighttime
stars visible to the naked eye), plus a few dimmer ones. The
BrightStar5 module includes more data fields than the include file
Rarius published a while back, including catalog designations and color
data. Macros are included for star coloration and Bayer designation
labels. You can also seek individual stars by Bayer, Draper, Flamsteed,
or SAO designations.
Rarius stated that the catalog is in the public domain. I could not
determine the intellectual property status from the published sources,
and in the process of trying to find out, I ended up having a very nice
phone conversation with one of the authors, Dr. Warren!
The 5th edition of the catalog, as it stands, is in a preliminary state.
(The primary author died in 2007.) There is no projected date for
final publication.
POV-Ray 3.7.1 beta 2 will crash hard with this module. Think Bayer
designations, and if you've been following p.beta-test, you'll know
exactly why it crashes. Some of the 3.7.1 alphas (including some 2015
vintages) also crashed, but 3.7.0 works fine. The latest master passes,
so everything should be fine when beta 3 is released.
http://lib.povray.org/searchcollection/index2.php?objectName=BrightStar5&contributorTag=Cousin%20Ricky
Cousin Ricky wrote on 08/02/2017 14:08:
> final publication.
It seems very interesting.
I hope to see soon some examples,
Paolo
Thanks Richard! Great way to use the data. All of it impressive work.
POV-Ray 3.7.1 beta 3 works fine with this module.
> Catalogue and converted them to SDL. [snip]
I have uploaded BrightStar5 version 1.1, which has indexes on the data
arrays. The seek macros run *much* faster now.
> final publication.
The fuzzy circles don't look so great. I don't know if anything can be
done to improve them however. In video games, stars are often reduced to
1 pixel. But I don't think in POVray there's an easy way to make a star
exactly 1 pixel big. Maybe with some trigonometry?
Mike
I worked that out obtain a constant-apparent-width cylinder for a bounding box,
and a Dupin cyclide for orbital trajectories.
Obtaining a constant 1-pixel width is pretty trivial with the orthographic
camera, since with the default camera, IIRC, 1 POV-unit = 1 pixel.
not really.
Unless your default camera is
up image_height*y
right image_width*x
but that's not the camera you get from
camera{ orthographic }
|| up: 0.000, 1.000, 0.000
|| right: 1.330, 0.000, 0.000
|| direction: 0.000, 0.000, 1.000
Le_Forgeron <jgr### [at] free fr> wrote:
> not really.
> up image_height*y
> right image_width*x
> || location: 0.000, 0.000, 0.000
Well, then I guess I didn't remember correctly ;)
I vaguely recalled this discussion:
http://news.povray.org/povray.advanced-users/thread/%3Cweb.5845a06cc97737fcc437ac910%40news.povray.org%3E/
So modifying that so Pixel "size" is described in POV-units, then we could have
#macro Zoom (PixelSize)
orthographic
location <0, 0, -PixelSize>
look_at <0, 0, 0>
right (x*image_width )*PixelSize
up (y*image_height)*PixelSize
(I haven't entirely determined what the best camera-to-lookAt distance is to
avoid some weird things happening)
I kinda wish there were a POV-Ray object that would be guaranteed to
always be 1 pixel big.
Mike
>> not really.
>> up image_height*y
>> right image_width*x
> camera {
> orthographic
> look_at <0, 0, 0>
> #end
I snipped this out of something I wrote last April, and haven't tested it out
tonight in a scene all by itself, but it gives you the broad strokes.
Location is the camera location.
(So do
#declare Location = <0, 0, -10>;
camera { ... location Location ...}
Vector is the center of the object you want to be 1 pixel.
The macro returns the radius of a sphere/cylinder so it is a pixel wide.
you can work the rest out from there.
// Minimum radius for solid visibility is (Z/image_width)*Aspect
// Minimum radius for threshold visibility is (Z/image_width)
#macro MinRad (Vector)
#local Aspect = image_width/image_height;
#local Dist = vlength (Vector-Location);
#local M = (0.5*Aspect)/tan(radians(Angle/2));
#local ZA = Dist/M;
#local Rad = (ZA/image_width)*Aspect;
Rad
#end // end macro MinRad
> (So do
> #local ZA = Dist/M;
> Rad
Interesting. Would it work better with a cube oriented to face the
camera? I suppose the perspective distortion might make the cubes look
weird if they're toward the edges of the image. But spheres would end up
looking distorted too.
Mike
> Mike
E.g. a true "one-pixel" POV-Ray object would not be distorted by
perspective, which I think is realistic since stars are so distant and
tiny that visual perspective has no effect on their perceived
dimensions/brightness.
Mike
Yes, of course they can be improved! The purpose of the demo was merely
to demonstrate how to use the data. I consider attempting a realistic
sky beyond the scope of the demo.
This works if you are representing the stars as actual objects:
----------[BEGIN CODE]----------
#version 3.7;
#declare Cam_angle = 60;
#declare RSky = 10000; // arbitrary distance to the stars
#declare R = RSky * tan (radians (Cam_angle / 2)) / image_width;
camera
{ location 1.64 * y
look_at <0.5, 2.64, 2.5>
angle Cam_angle
plane { y, 0 pigment { checker } }
#include "brightstar5.inc"
#default { finish { ambient 0 diffuse 0 emission 1 } }
union
{ #for (I, 0, BSC5_N - 1)
#if (BSC5_Data [I] [BSC5_HD] != BSC5_NO_DATA)
sphere
{ RSky * y, R
pigment { rgb BSC5_fn_Brightness (BSC5_Data [I] [BSC5_MAG], 0) }
rotate
< 90 - BSC5_Data [I] [BSC5_DEC],
-15 * BSC5_Data [I] [BSC5_RA],
0
rotate <0, 120, 71.7>
-----------[END CODE]-----------
I disregarded image_height in the formula because the POV-Ray camera
considers only image_width for its field angle. Also note that if the
camera is significantly distant from the origin, you will need to make
appropriate adjustments.
Note that with a diameter of 1 pixel, an adaptive anti-aliasing trace
will miss quite a few stars. To avoid this, you'll need to either use
+A0.0 (slow), or use a diameter slightly larger than 1 pixel (times
sqrt(2) should do). As far as using boxes instead of spheres, I don't
think it would be worth the effort.
If Orion looks strangely oriented in the above code, it's because I'm
stargazing from the northeast Caribbean.
Yes, there is some distortion as you move away from the center of the
image, as explained in the knowledge base:
http://wiki.povray.org/content/Knowledgebase:Misconceptions#Topic_3
The orthographic camera will preserve the star shape, but the star
positions will still be distorted, for the reason you learned in 4th
grade geography. Also, the orthographic camera would be quite awkward
to use if you are rendering, say, a landscape.
A sky sphere would use a different formula, but the math would be similar.
Has anyone to date used the catalogue to generate a fairly realistic spherical
sky shell or a flat image useful for uv-mapping a sphere?
I'd like to be able to incorporate this into the solar system scene I've worked
on, if I get the time to focus on it, and I have another project where I'd like
to be able to look up from a given position on earth at a certain angle at a
given date and time and see a reasonably accurate view.
Does anyone here know [how to contact] this chap?
https://www.youtube.com/watch?v=bvpEWuxBBRw
Am 1/14/20 8:38 PM, also sprach Bald Eagle:
How many Geoff Dallimore(s) can there be? Google thinks you want the
UK patent attorney, who looks like the guy in the thumbnail on youtube.
If you comment on the video, I'm pretty sure he'll get an email. Or you
can try his contact form: http://xpatent.co.uk/contact/
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
> Catalogue and converted ...
Hum when it comes time to generate a view if this library,
if your library is in 3D points, not ra dec, you'll save thousands of trig
functions, and the time.
seta(1,146180222.862047,-139516389.855953,-37392435.96208,5.1);
seta(2,65647206.128445,-80763375.119065,-16312013.815614,4.7);
seta(3,135031719.98319,-145513040.060053,-31389042.949954,5.3);
times 10,000,000 = miles, and there's your distance.
I already made a bright star catalog converted to pov, in 3D points, if anyone
is interested.
> is interested.
Yes, that would be a very useful thing, indeed.
Are there comments of any sort to assist in highlighting the various
constellations, or is it just bare-bones at the moment?
I still have to wrap my head around the ephemerides and the orbital elements to
be able to position everything where it needs to be at the proper times...
> > is interested.
Constellation boundaries points is another set of points.
Got it all in 3 languages.
POV
http://trueinnerbeing.x10host.com/charts/planetarium45.zip
JS
http://trueinnerbeing.x10host.com/charts/jtarium232full-opac.zip
http://trueinnerbeing.x10host.com/charts/jtarium.html
(ctrl-F8 titles are links to APOD)
OpenGL
http://trueinnerbeing.x10host.com/code/gamemode.zip
http://trueinnerbeing.x10host.com/code/code.html
all to grok really, is that camera matrix is "inverted"
and you just pipe everything thru the world matrix.
POV
http://trueinnerbeing.x10host.com/planetarium45.zip
JS
http://trueinnerbeing.x10host.com/jtarium232full-opac.zip
maybe those?
well I should have checked the links, server is being finicky.
I can ftp /charts/ links, browser says not there.
> POV
here's the fleet,
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.485747fce7b65d90d361a0c10%40news.povray.org%3E/fleet05.
png
using the glow function for the stars, (too much glow)
and type for the color.
so you want to go star trek, then, I got many models.
> POV
Yes, that worked.
When trying to run pld.pov, I get:
Parse Error: Cannot pass uninitialized identifier to non-optional LValue.
at File: megatime.inc Line: 80 Col: 17
/////////////////////////////////////////////////////////////// AutoDate
MegaPov
//#version unofficial MegaPov 1.21;
#version 3.63;
#declare Time = date("%H:%M:%S")
#declare Date = date("%B %d %Y")
////////////////////////////////////////////////////////////// TimeZone
#declare DST = 1;
#declare GMT = 0;
#declare TimeZone = -6 + DST;
#declare JulianDate = julian(val(date("%Y")),val(date("%m")),val(date("%d")));
#declare ctime = j2ctime(JulianDate);
j2datetime(JulianDate)
presumably that needs to be updated to use datetime()
http://wiki.povray.org/content/Reference:Numeric_Expressions
#local CurrentTime = datetime(now); // current date and time as a string
I will fiddle with it as time allows.
Very nice little site you have. Lots of very interesting information.
I need whatever vitamins you take :D
> > POV
> Yes, that worked.
lol
Don't know if the last one posted. Version 3.63 or Mega POV for date.
That will not run. thought you just wanted the data. to run that you need maps.
http://trueinnerbeing.x10host.com/maps1.zip
but that link is not working yet. is there another place?
10 meg for the maps
3 sub dirs
clouds
maps
sats
One thing you can't do without is the ability to easily sort and rewrite text
files to your needs. One of those "vitamins" that give u a boost to what you can
get done, why there is something like Poseray. Got data and can't use it? No
problem. Even without Poseray, you'd do it DIY.
I see that Flam_Bayer.inc is not in 3D. That's used in java script, which can
generate a library view in a split sec, it doesn't have to use trig.
Could be quickly rewritten to any format you want.
ra dec is simple, just get the right order.
#local v = <cos(radians(ra))*cos(radians(dec)),
sin(radians(dec)),
sin(radians(ra))*cos(radians(dec))>;
dec * -1
if you want to y+ down output
I had been thinking about this around the beginning of the year, but the
more I pondered, the more complications there seemed to consider. How
bright? How to deal with dynamic range? What resolution? In general,
how would I make one tool that would apply across various scales and
lighting conditions? (Similar considerations are why I haven't put
beverage materials in the CoffeeMug include file.)
I just punted in despair, figuring each project might require a somewhat
specialized solution, but I didn't notice the new thread activity until now.
Well, I think that something like the sunpos include file is mostly what I'm
looking for.
Given a longitude and latitude, a date, and an hour of the day, create a
celestial sphere. Make it so that no matter what, each star is at least 1 pixel
wide.
I'm primarily interested in the geometry - the proper alignment.
"Look - that notch in that rock at Stonehenge really DOES line up with Rigel at
midnight on the winter solstice..."
Aside from that, you could add some sort of mechanism that allows the _USER_ to
tweak the catalogue.
So - whatever array you use to do the basic stuff, and then maybe a user array
that modifies the values or sets some flags before rendering.
That way someone could highlight a star with an object{} (torus, [under]line,
arrow, etc), put a text label, change the apparent size, replace the simple
sphere for the star with a fancy object{}, or apply a multiplier to the star's
brightness/color.
I'd probably start with like 10 stars or a few constellations, and give it a
whirl, and then get some user feedback before doing anything bigger.
Thanks for that, and ulterior versions (1.1.1).
I currently have a strange interest on constellations, is there a way to
have them nicely drawn as the sample for Orion ?
I tried to have a look at the include files, and the sample scene, but
I'm afraid the data to connect the stars as per the constellation is
missing and hard coded for orion in the sample.
A general procedure would not be straightforward. I chose Orion
specifically because it is on the celestial equator, and would not
require a fancy map projection. I had not considered map projection
within the scope of the module, as different persons would have
different needs.
There is no official set of constellation lines. It is up to the
imagination of the person drawing the chart.
