POV-Ray : Newsgroups : povray.object-collection : noisy rendering of a polynomial "cube" Server Time
14 Oct 2026 12:21:36 EDT (-0400)
  noisy rendering of a polynomial "cube" (Message 1 to 9 of 9)
Subject: noisy rendering of a polynomial "cube"
Date: 31 Mar 2014 09:16:43
Message: <53396abb$1@news.povray.org>
Problem: The object looks noisy, even with "sturm" enabled. :-(
How can I get a smooth rendering? Is it possible for "poly" objects to
enforce some "precomputing" or the like?
I rendered with
  -ibutterfly.pov +d +v -p +w800 +h600 +sp8 +ep8 +a0.1 +am2 +r3
it took 3½ minutes, with -a it took 27 seconds but looks very ugly due
to the noises. :-(
Lars R.
Download 'butterfly.pov.txt' (1 KB)
Subject: Re: noisy rendering of a polynomial "cube"
Date: 31 Mar 2014 11:17:06
Message: <533986f2$1@news.povray.org>
> I rendered with
> to the noises. :-(
> Lars R.
  The noisy look is a combined effect of the filtered color of the
object and the checkered plane which is reflected on and in the object.
If you want no noisy effect here, you have to set filter to 0 or change
the pattern of the plane.
Lionel.
Do not judge my words, judge my actions.
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la
protection avast! Antivirus est active.
http://www.avast.com
Date: 31 Mar 2014 11:33:22
Message: <53398ac2$1@news.povray.org>
I have said some stupidity, the checkered plane is not in cause, only
the filtered color cause the noisy effect. Maybe it is a side-effect of
the polynomial object, since the noise is not present with a box.
Lionel.
Date: 1 Apr 2014 04:23:00
Message: <533a7764$1@news.povray.org>
>> object. If you want no noisy effect here, you have to set filter to
>> 0 or change the pattern of the plane.
> only the filtered color cause the noisy effect. Maybe it is a
> side-effect of the polynomial object, since the noise is not present
> with a box.
I know. But how can I fix that? (No, replacing the poly with a box is
not an option. ;-))
L.
Date: 1 Apr 2014 05:25:32
Message: <533a860c$1@news.povray.org>
>> with a box.
> not an option. ;-))
> L.
If you don't need transparent object, you just have to change the color
like this:
pigment { color rgb <1,0.7,0.2> }
and remove the interior statement.
Lionel.
Date: 1 Apr 2014 07:19:56
Message: <533aa0dc$1@news.povray.org>
I need it, hence I made it semi-transparent and refractive. I like the
"gummi bear look".
Lars R.
Date: 1 Apr 2014 15:32:39
Message: <533b1457@news.povray.org>
> "gummi bear look".
> Lars R.
I don't know why but, after some tries, it seems that only the
polynomial and poly objects are affected by this noise with filtered
colors.
We need developper's help here, I can't explain more, sorry.
Lionel :(
Date: 3 Apr 2014 09:58:20
Message: <533d68fc$1@news.povray.org>
>> "gummi bear look".
>> Lars R.
> colors.
> Lionel :(
See the post /noise with polynomial object/ in p.bugreports.
Lionel.
Date: 6 May 2014 20:25:01
Message: <web.53697b96a6b2aa33192ae5f10@news.povray.org>
> I rendered with
> to the noises. :-(
I converted it to an isosurface.  It takes 80% more time, but at least it's
smooth.
________________________________________________
isosurface
{ function
  {   pow (x, 6) + pow (y, 6) + pow (z, 6)
    - 3 * (pow (x, 4) + pow (y, 4) + pow (z, 4))
  max_gradient 115
  contained_by { box { -2, 2 } }
  pigment { color rgbf<1,0.7,0.2,0.5> }
//  normal { granite 0.1 }
  finish { phong 0.6 }
  interior { ior 1.5 }
