POV-Ray : Newsgroups : povray.object-collection : Browser issues with Search page Server Time
28 Apr 2026 13:35:44 EDT (-0400)
  Browser issues with Search page (Message 1 to 7 of 7)
Subject: Browser issues with Search page
Date: 21 Nov 2008 06:57:26
Message: <4926a226@news.povray.org>
I've updated the Search/Browse page
http://lib.povray.org/searchcollection/index.php on the POV-Ray Object
Collection to attempt to circumvent a Firefox issue. I've tested this fix
with Firefox 2.0.0.18 and IE 7.0.6001.1800 on Windows Vista and they seems
to work ok. I'm hoping my fix doesn't cause problems on other platforms that
I can't test on. If anyone gets a problem resulting from this, please post a
response on this thread.
The original problem was that, with Firefox 2.0.0.18 (the autoupdate from
13th November 2008), pressing the Search/Browse button displayed a category
box in the results panel but no actual results.
Techie stuff:
Firefox 2.0.0.18 contains what seems to be an AJAX bug where, under certain
conditions (with certain Plugins installed) the XMLHttpRequest object only
ever returns a readystate of 3 (loading) and never goes to 4 (complete). The
only page on the Object Collection that seemed to be affected was the main
Search/Browse page which uses AJAX to display the search results.
The Thumbnails page was unaffected as it's a Javascript free page.
I've updated the page to work around the problem by processing all
ReadyState 3 responses, which could theoretically cause flickering while
loading the search results (but doesn't seem to on my machine).
Chris B.
Subject: Re: Browser issues with Search page
Date: 26 Nov 2008 12:50:01
Message: <web.492d8c05c553f9cec007468e0@news.povray.org>
I may have asked this before... Please forgivemy error if this is the case.
Anyway, I notice that the URLs to each item contain the version number in them.
Would it be possible to change the URLs so that they remain constant no matter
how many times the item has been updated? I'd hate for links to go dead, or
(worse yet) for the links to lead to outdated versions.
-Mike
Date: 26 Nov 2008 15:37:58
Message: <492db3a6$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.492d8c05c553f9cec007468e0@news.povray.org...
> them.
> matter
> or
> -Mike
Hi. Yes it's possible.
The logic was that old versions should continue to be available and
downloadable so that, if anyone builds something with a dependency upon a
particular version of a macro, they can point to it without fear that a
newer version will overwrite it and be incompatible with what they've done.
I've added a little code, so that you can optionally link to the object
details using the index2 detail option without specifying a version number.
For example:
http://lib.povray.org/searchcollection/index2.php?objectName=FractalObjects&contributorTag=SharkD
Does that give you what you need?
Chris B.
Date: 26 Nov 2008 17:25:00
Message: <web.492dcc34c553f9ce49475c8b0@news.povray.org>
> For example:
> Regards,
> Chris B.
Are these links accesible from the index page, or do I have to cut and paste
whenever I want to link to them?
-Mike
Date: 26 Nov 2008 18:31:15
Message: <492ddc43$1@news.povray.org>
news:web.492dcc34c553f9ce49475c8b0@news.povray.org...
>> number.
>> For example:
>> Regards,
>> Chris B.
> paste
> -Mike
The full URLs (with the version number attributes) are shown on the index2
page.
To link to them you can copy the URL from there by right clicking on the 'i'
button and selecting 'copy link location'. You'll need to paste that into
your web page and edit out the version number parameter.
Chris B.
Date: 5 Dec 2008 04:50:01
Message: <web.4938f914c553f9ce663fd25e0@news.povray.org>
> page.
> Regards,
> Chris B.
Is there a way to drop the contributerTag as well? Projects could, feasably, be
authored by more than one person.
Thanks.
-Mike
Date: 5 Dec 2008 04:55:00
Message: <web.4938f9edc553f9ce663fd25e0@news.povray.org>
> > page.
> > Regards,
> > Chris B.
> Thanks.
> -Mike
I guess what I'd like is a generic link to the object, and then have the option
to select older versions from a list.
-Mike
