POV-Ray : Newsgroups : povray.object-collection : Swivel Stool, possibly for object collection Server Time
15 Sep 2025 08:04:41 EDT (-0400)
  Swivel Stool, possibly for object collection (Message 1 to 3 of 3)
Subject: Swivel Stool, possibly for object collection
Date: 28 Mar 2008 01:41:42
Message: <47ec9326@news.povray.org>
With the recent talk about the object collection I thought I might
contribute an object I've been meaning to add.  It's simple, it lacks
bolts, it's got a lot of messy looking calculations, and most of the
dimensions are hard coded, but I think it gets at the gist of what it's
supposed to be.
I posted it in p.t.scenes:
http://news.povray.org/povray.text.scene-files/message/%3C47ec91d7%40news.povray.org%3E/#%3C47ec91d7%40news.povray.org%3E
Anyway, before I submit it, I was hoping to get some feedback, in
general and specifically on this:  I like using a system where something
like Main_Scene_File is a global variable and if it's already defined, a
given include file knows not to use a self-contained demo scene.   It
means an include file can stand alone as exactly one file.
Un-comment the line near the beginning which starts with
"//#ifndef(Main_Scene_File)..." and render the file itself.
I know I've asked this before, and I've even wished for a
main_scene_file keyword, but I don't remember how it turned out for the
object collection.  What gobals can be truly global?
Thanks,
Charles
Subject: Re: Swivel Stool, possibly for object collection
Date: 28 Mar 2008 08:26:46
Message: <47ecf216$1@news.povray.org>
"Charles C" <"nospam a nospam.com"> wrote in message
news:47ec9326@news.povray.org...
> bolts, ...
> Anyway, before I submit it, I was hoping to get some feedback, in general
> and specifically on this:  I like using a system where something like
> Main_Scene_File is a global variable and if it's already defined, a given
> include file knows not to use a self-contained demo scene.   It means an
> ... I know I've asked this before, and I've even wished for a
It looks fine to me the way you've done it, with the line commented out and
a description of how to use it at the top of the file. Those wishing to use
this system can readily uncomment the line. I think it would cause problems
if it were distributed without the line being commented out because it would
break the scene file of anyone who didn't know the system.
I too would like some system defined way of interrogating the include file
chain. My preference would probably be for a read-only array listing the
chain of files. If the array dimension length is '1' you'd know that the
file you're in is being rendered directly. Anyone needing additional info
about the include file sequence could start trolling back through the
contents of the array.
I don't recall ever seeing a concensus or any agreement from the POV-Team to
include such a feature in a future version of POV-Ray. I seem to remember
rather that the discussion exploded into one about rewriting the whole
language. It might be worth re-opening discussions about this on
povray.general on the off-chance of getting some simple solution into 3.7.
I've explored quite a few alternative ways of achieving similar results with
the current version of POV-Ray and I've not found any solution that I would
claim to be 'best' in all situations.
Chris B.
Date: 28 Mar 2008 12:39:01
Message: <47ed2d35@news.povray.org>
OK, I'll submit it as is.  I try to check for things that might be
defined already, Red or camera, but that definitely remains a drawback
of doing this in SDL.  If main_scene_file were an actual keyword, it
wouldn't break it.
That sounds like an even more robust version of what I had in mind... :)
   Would that be an array of strings?  Do you mean a special array which
changes length dynamically?  If the starting-file performs some
ifndef()'s and includes whatever it happens to need, then the array
would grow.  But unless it shrinks by the time the parsing returns to
the starting-file, you wouldn't be able to use that test.  OTOH, a
strcmp() on the fist element should work.  Another possibility might be
a float value/keyword like include_layer_number.
As far as a keyword and POV-Ray itself goes, Chris Cason responded to my
   suggestion saying it may have some merit but took it in a slightly
different direction: He implemented the alternate-file-render feature
starting in beta 20b.  That addressed the convenience-of-editing include
files, but not the self-demoing of include-file-objects that I was
dreaming about.    (I guess I have a thing for standalone files whenever
possible :-)
IIRC, I think he did mention that if there were such a variable, it
might work better letting POV-Ray keep track of whether it's parsing the
first file and have the keyword be a binary variable which toggles
accordingly.  Maybe I'm mis-remembering.  It's been a while.
> Regards,
> Chris B.
I'd be interested to know what other ideas you've had.  Anything that
does not break people's scenes if they don't use that system and makes t
possible to do what I'm trying to do would satisfy me.  I suspect it's
not possible without adding a keyword of some sort.
Charles
