POV-Ray : Newsgroups : povray.object-collection : (First?) Contribution Drive: Office Supplies Server Time
17 Mar 2026 15:08:54 EDT (-0400)
  (First?) Contribution Drive: Office Supplies (Message 1 to 10 of 27)
Subject: (First?) Contribution Drive: Office Supplies
Date: 21 Jan 2008 12:09:18
Message: <4794d1be$1@news.povray.org>
OK, to try this out, I'll be collecting, for a period of one week,
submissions for office supplies.  Anyone can make a submission, or
multiple submissions.  There are only a few guidelines I'll stipulate:
1) Email me your submissions, rather than spamming the NG with binaries.
2) Try to use a macro parameter to define the size of your object.  If
you cannot, then please use a variable named 'meter', and place the
following at the beginning of your code:
#ifndef(meter)
#declare meter = 1.0;
Then, create all your objects based on this variable.
3) It is assumed that all submissions are given with permission to post
them in the POV-Ray Library.  It is also assumed that I am being given
permission to be the one posting them there.  It is also assumed that
you would like credit for your work, so I will ensure that the final
upload contains credits for all contributors.
4) Try to make objects that would require more than a few minutes of
mucking about in SDL to replicate.  The point is to have quality
objects.  If you can't make a whole set of quality objects, just make
one or two - that's why we're doing this as a group.
Any other questions or suggestions, post them here.  After next Sunday,
I'll package all the contributions together and upload them.
...Ben Chambers
www.pacificwebguy.com
Subject: Re: (First?) Contribution Drive: Office Supplies
Date: 21 Jan 2008 12:45:00
Message: <web.4794d9f421a87b7e773c9a3e0@news.povray.org>
fine enough.  So it closes next monday?  oh, sunday...
how about a standard title?  "Povray Object Collection:  office supplies"?
> #ifndef(meter)
> #end
hmm, how about abbrevs?  m is traditional for meter, cm for centimeter etc.  I'd
very much like to spell <1.2,.86,.2>*m rather than <1.2,.86,.2>*meter or
centimeter...  what about yankees and their weird measure units?
that sounds great!  I'm guessing you're expecting pure CSG, no meshes?
Date: 21 Jan 2008 13:53:37
Message: <4794ea31@news.povray.org>
  Do you think that's enough?
> #ifndef(meter)
> #end
  I would like to suggest what I suggested in the other post:
  If possible, try to make the different dimensions of the object
configurable. For example, if you are making a table, try to make
it possible to define either the width and depth or the "aspect
ratio" of the tabletop, the length of the table legs, etc. instead
of just creating a fixed model. In some cases it may be feasible to
put some limits on the given measures.
  The most flexible way to do this is to put something like this in
the include file:
#ifndef Someid_Table_Leg_Length
  #declare Someid_Table_Leg_Length = 5;
  Or, alternatively:
#local Table_Leg_Length = 5;
#ifdef Someid_Table_Leg_Length_Factor
  #local Table_Leg_Length = Table_Leg_Length * Someid_Table_Leg_Length_Factor;
  This way people can either use your #include with its default settings,
or they can fine-tune some settings like:
#declare Someid_Table_Leg_Length_Factor = 1.2;
#include "theinclude.inc"
  It would also be nice to be able to configure other things about the
object in a similar way. For example, if you are making a lamp, it should
be possible to tell if the lamp is on or off, and its brightness/color,
for example like:
#declare Someid_Lamp_Light = on;
#declare Someid_Lamp_Light_Color = <1.2, 1, .6>;
#declare Someid_Lamp_Light_Fade_Distance = 4;
#include "thelamp.inc"
  Likewise for other similar things, eg. object which can be open or close,
objects which can have parts which are rotated (ie. it should be possible
to define the rotation angle for that part), etc.
Date: 21 Jan 2008 14:17:37
Message: <4794efd1@news.povray.org>
As long as its emailed to me, I'll see it.  I haven't had a problem with
my spam filters catching legitimate mail.  Then, I'll composite them
into a single package to be uploaded.
>> #ifndef(meter)
>> #end
Try to use macro parameters.  If you can't, then we should use a
standard sizing system.  Rather than argue about it here, I'd recommend
just using the above.
If you use parameters, however, then the above is unnecessary.
That's the idea, of course.
...Ben Chambers
Date: 21 Jan 2008 14:24:47
Message: <4794f17f$1@news.povray.org>
For office supplies?  Sure.  I don't expect everyone to push out a dozen
objects or so; one per person should be enough, and the given time frame
is fine for that.
<snip>
Exactly.  If they can't do that, then using a standard sizing system is
best.  I didn't want to argue about a sizing system, so I kept it simple.
Of course, macro or defined parameters are best :)
...Ben Chambers
Date: 21 Jan 2008 14:30:19
Message: <4794f2cb@news.povray.org>
Although it probably wouldn't hurt to post here if you're working on
something.
Personally, I've been working on a ball point pen, and I plan on doing a
handheld (ie small) stapler, as well as a 3 hole punch.
...Ben Chambers
Date: 21 Jan 2008 14:58:45
Message: <4794f975@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:4794efd1@news.povray.org...
     In this day and age, that's a real shame.
       ~Steve~
> ...Ben Chambers
Date: 21 Jan 2008 17:03:28
Message: <479516b0$1@news.povray.org>
>        ~Steve~
Ohhh!  Glad that got said before I put too much time in.  That should be
made clearer on the web page.
Date: 21 Jan 2008 17:58:24
Message: <47952390@news.povray.org>
news:479516b0$1@news.povray.org...
    Heh, well, I can't think of anything better than mixing a good mesh
modeler with PoV. For me at least, it = perfect.  :)
      ~Steve~
Date: 21 Jan 2008 18:50:55
Message: <47952fdf$1@news.povray.org>
>        ~Steve~
Don't get me wrong - there's no way I'd turn away a good model if one
got submitted.  I just prefer CSG for its flexibility (through macros
and / or parameters), compactness, and the fact that it uses real curves.
...Ben Chambers
