POV-Ray : Newsgroups : povray.object-collection : noisy rendering of a polynomial "cube" : Re: noisy rendering of a polynomial "cube" Server Time
26 Mar 2026 22:48:02 EDT (-0400)
Date: 1 Apr 2014 04:23:00
Message: <533a7764$1@news.povray.org>
>> The noisy look is a combined effect of the filtered color of the
>> object and the checkered plane which is reflected on and in the
>> object. If you want no noisy effect here, you have to set filter to
>> 0 or change the pattern of the plane.
> I have said some stupidity, the checkered plane is not in cause,
> only the filtered color cause the noisy effect. Maybe it is a
> side-effect of the polynomial object, since the noise is not present
> with a box.
I know. But how can I fix that? (No, replacing the poly with a box is
not an option. ;-))
L.
