POV-Ray : Newsgroups : povray.object-collection : Descriptions : Re: Descriptions Server Time
21 Mar 2026 18:00:07 EDT (-0400)
  Re: Descriptions
Date: 23 Jun 2008 15:16:48
Message: <485ff6a0$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.485ff022d15f754e1729cc4e0@news.povray.org...
> 700 characters is a bit small for a description. Is there any way you can
> bump
> this up to around 2000 or so? Also, you need to separate the "Standards
> Compliance Ratings" section from the description with some white space. I
> would
> also suggest using a bold heading for the section titles.
> -Mike
The description is intended to be quite small. You can add more detail by
uploading an HTML file with the same name as the contribution, at which
point a 'More Detail' link will automatically appear next to the name of the
object in the search results. I'd be happy to upload such a file for any
existing entries.
For example, the 'Netball' entry includes a very simple HTML file called
'netball.html' that lists all of the settings that can be used with the
macro. The 'netball.html' file is at
http://lib.povray.org/collection/netball/chrisb%201.0/netball.html. Feel
free to take a copy and hack it around in a text editor to suit your needs
if you want. Note that all file names get translated to lowercase when you
upload them and the server is case sensitive, so, if you incorporate images
you'll need to consistently use lowercase in the IMG tag.
Chris B.
