POV-Ray : Newsgroups : povray.newusers : question about user defined float functions Server Time
9 May 2025 08:32:31 EDT (-0400)
  question about user defined float functions (Message 1 to 4 of 4)
Subject: question about user defined float functions
Date: 31 May 2024 07:15:00
Message: <web.6659b0f23151b3296e558a71fde6c206@news.povray.org>
In the reference manual I do not find a formal definition of a user defined
float function. Instead, several examples are provided. I assumed a conditional
expression could be used to define a function, but apparently I was mistaken. I
get an error "Parse Error: Expected 'operator', ? found instead"
Is there any way to create a float function which is a conditional expression?
Thank you.
Subject: Re: question about user defined float functions
Date: 31 May 2024 08:10:00
Message: <web.6659bde35e4f6a6917bac71e8ffb8ce3@news.povray.org>
> Thank you.
You may look at: select(A, B, C [,D])
ingo
Date: 31 May 2024 09:50:00
Message: <web.6659d46d5e4f6a696e558a71fde6c206@news.povray.org>
> > Thank you.
> ingo
Okay, if I understand this correctly, if the input parameter A is boolean, I can
provide any value I want for B, and C is the value returned when A is false, and
D is the value when A is true. I hope I got that right. Thanks for the tip!
Date: 31 May 2024 11:01:58
Message: <6659e666$1@news.povray.org>
I'll add, folks sometimes lose track of the fact the virtual machine
(VM) select() functionality is mirrored in the Scene Description
Language (SDL). In other words, you can test your logic outside of the
function {} wrapper prior to use in the function itself - or alongside.
Bill P.
#version 3.8;
#declare A=-1;
#declare B=-2;
#declare Z=0;
#declare C=+2;
#declare Fn_select3 = function (_a,_b,_c)    { select(_a,_b,_c) }
#declare Fn_select4 = function (_a,_b,_z,_c) { select(_a,_b,_z,_c) }
#debug concat("A = ",str(A,3,1),"\n")
#debug concat("B = ",str(B,3,1),"\n")
#debug concat("Z = ",str(Z,3,1),"\n")
#debug concat("C = ",str(C,3,1),"\n")
#debug "\n"
#debug concat("select(A,B,C)       = ",str(select(A,B,C),3,1),"\n")
#debug concat("Fn_select3(A,B,C)   = ",str(Fn_select3(A,B,C),3,1),"\n")
#debug "\n"
#debug concat("select(A,B,Z,C)     = ",str(select(A,B,Z,C),3,1),"\n")
#debug concat("Fn_select4(A,B,Z,C) = ",str(Fn_select4(A,B,Z,C),3,1),"\n")
#debug "\n"
#error "Stop early\n"
